Old 04-22-2014, 07:58 AM   #757
grostoine
Drives: Subaru BRZ
Originally Posted by glamcem View Post
Just curious, did you guys pay attention to the oil reservoir level as mentioned in the instructions? Maybe, this might be the root cause of your oil leakage issues
Mine was brand new. On the first start up it was leaking. Oil level was correct.
grostoine is offline   Reply With Quote
Old 04-22-2014, 11:58 AM   #758
glamcem
glamcem's Avatar
Drives: 2022 BRZ Limited
Sorry for the confusion, I meant the say the oil canister level compared to supercharger.. it should sit level or below the supercharger level to prevent leaks according to the Rotrex Technical handbook..
I believe @digital_assassin also mentioned this one of his earlier posts
glamcem is offline   Reply With Quote
Old 04-22-2014, 12:03 PM   #759
KraftWerks
KraftWerks's Avatar
Drives: Kraftwerks BRZ
It hasn't been mentioned that we are on top of this rare case, and new parts are already on the way to your door.
KraftWerks is offline   Reply With Quote
The Following User Says Thank You to KraftWerks For This Useful Post:
grostoine (04-22-2014)
Old 04-22-2014, 12:09 PM   #760
grostoine
Drives: Subaru BRZ
I can't thank you enough. I think that it's the fastest service i've ever have with a companie that is so for away from home!!
I can't wait to have it tune!!
Old 04-22-2014, 02:33 PM   #761
mit_peid
Boosted Noob
mit_peid's Avatar
Drives: '13 FRS MT KW SC, '05 4Runner 4WD
Both KW and JR says having the reservoir higher than the blower is a non-issue with the C30-94. It is an issue for the C8 and C15, but Rotrex just had it in the instructions as an added precaution.
http://www.rotrex.com/Home/Technology/Important_Update
mit_peid is offline   Reply With Quote
Old 04-22-2014, 02:50 PM   #762
glamcem
glamcem's Avatar
and they also mention at the end
Nevertheless it is always best to position the supercharger above the canister and oil cooler to avoid any risk of leakage in case of wear or damage to the high speed spindle seal.
I will just position below the supercharger level just to be safe
Old 04-22-2014, 09:26 PM   #763
wrohdejr
Drives: 2013 subaru limited wrb brz
Glamcem
I had my kw installed at Drift Office in Auburn. Bob is great and did my tune as well. If you need help give them a call.
Portland 86ers
wrohdejr is offline   Reply With Quote
The Following User Says Thank You to wrohdejr For This Useful Post:
glamcem (04-22-2014)
Old 04-23-2014, 02:15 PM   #764
mit_peid
Boosted Noob
mit_peid's Avatar
Question on catch cans, which is more useful/likely to catch oil: 1) PCV or 2) Crankcase? Are they equally as likely to catch oil?
Old 04-23-2014, 02:58 PM   #765
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Not sure what you mean. PCV stands for positive crankcase ventilation so the hose off the back/passenger side of the motor is the PCV and the crankcase. If you only put a catch can on one of them, then make sure it is the PCV hose. If you don't run a vented can, then make sure you have a check valve in the line so that your can and crankcase don't get pressurized with the boost.
Old 04-23-2014, 03:06 PM   #766
mit_peid
Boosted Noob
mit_peid's Avatar
I guess I'm trying to understand what's the difference between going with one vs two of the cans being offered here: http://www.radiumauto.com/Catch-Can-...Z-86-P374.aspx
Old 04-23-2014, 04:15 PM   #767
grostoine
Drives: Subaru BRZ
I just install the new rotrex, primed the system and started the car. Everything wnet fine and was running great!!!
Thanks @KraftWerks again!!
The Following 6 Users Say Thank You to grostoine For This Useful Post:
Calum (04-23-2014), djdnz (04-23-2014), glamcem (04-23-2014), KraftWerks (04-24-2014), Mad1723 (04-24-2014), mit_peid (04-23-2014)
Old 04-23-2014, 09:30 PM   #768
post_break
Professional Smartass
post_break's Avatar
Drives: White Out FRS
Looking at this bolt I shouldn't have an issue with the oil cooler. Then again I hope it doesn't fall off heh. Getting really excited to install this.
post_break is offline   Reply With Quote
Old 04-23-2014, 09:33 PM   #769
captain_jack
captain_jack's Avatar
That bolt is short, i wouldnt run with it personally. Id call kraftwerks if it was me. Mine was to long so i cut it in the chop saw.
sent from your mom
Old 04-23-2014, 09:38 PM   #770
post_break
post_break's Avatar
@KraftWerks can you comment on that bolt?
Kraftwerks Rotrex Supercharger Discussion nelsmar Forced Induction 697 01-18-2022 12:06 PM
All SUPERCHARGER kits compilation thread subatoy Forced Induction 76 03-10-2016 12:38 PM
Kraftwerks Supercharger?? umpadupa Forced Induction 1 08-05-2013 05:27 PM
