Old 04-21-2014, 01:16 PM   #743
post_break
Professional Smartass
post_break's Avatar
Drives: White Out FRS
Can someone who has installed this kit please do me a big favor and measure the distance from the oil filter lip, to the bolt on the second pulley? How many inches from the lip to the bolt is it? Need to know if my oil cooler will fit before I install my kit.
post_break is offline   Reply With Quote
Old 04-21-2014, 01:18 PM   #744
captain_jack
captain_jack's Avatar
Do a search here as they have done this already.
may the schwartz be with you....
Old 04-21-2014, 01:33 PM   #745
post_break
post_break's Avatar
Thanks I'll just read all 35 pages to find it.
*I'm just fussy, ignore me*
The Following 2 Users Say Thank You to post_break For This Useful Post:
captain_jack (04-21-2014), glamcem (04-21-2014)
Old 04-21-2014, 01:43 PM   #746
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
This is the best page I could find with dimensions and photos. Looks like the bolt is very close:
http://www.ft86club.com/forums/showt...=48406&page=23
The Following 2 Users Say Thank You to King Tut For This Useful Post:
CSG Mike (04-21-2014), post_break (04-21-2014)
Old 04-21-2014, 01:47 PM   #747
post_break
post_break's Avatar
Originally Posted by mit_peid View Post
Believe it or not, it was actually kind of difficult to get a decent shot with the tape measure. From the top of the stock oil filter pan to the top of the idler nut, it is about 1-10/16" (estimated).
Thank you, I had to read through this entire thread to find this. Somehow I missed it.
Old 04-21-2014, 02:02 PM   #748
mit_peid
Boosted Noob
mit_peid's Avatar
Drives: '13 FRS MT KW SC, '05 4Runner 4WD
Let me know if everything fits. I'm 99% certain that you will need to use a slightly shorter idler bolt/nut to make the Forester DIT oil cooler work. The KW kit's idler bolt/nut juts right over the lip of the OEM oil pan. Assuming the Forester oil cooler goes straight up, there will likely still be some interference.
mit_peid is offline   Reply With Quote
The Following User Says Thank You to mit_peid For This Useful Post:
Old 04-21-2014, 02:37 PM   #749
KraftWerks
KraftWerks's Avatar
Drives: Kraftwerks BRZ
The distance from the top of the oil filter lip to the bottom of the bolt is approximately 35.2mm
KraftWerks is offline   Reply With Quote
The Following User Says Thank You to KraftWerks For This Useful Post:
Old 04-21-2014, 02:38 PM   #750
post_break
post_break's Avatar
If anything I will grind down the lip of the oil cooler as it's not needed. The oil cooler itself is the same thickness as an oil filter, right up to the top lip, which can be ground down.
Old 04-21-2014, 09:19 PM   #751
post_break
post_break's Avatar
Sorry to keep bumping this lol. But it looks like it's going to be real close. The lip starts at 1"3/4. This picture is the best I could get.
In the mean time I will see if I can find a riser. If so I can get the WRX bolt that is longer and raise the lip up a bit. Either that or I bust out the dremel and remove that lip all together.
This solution will perform the best since you won't have to worry about over cooling your oil in the winter, and it will bring the engine oil up to temp faster. Win win.
Old 04-21-2014, 11:14 PM   #752
mit_peid
Boosted Noob
mit_peid's Avatar
It MIGHT fit... if you can confirm it'll work I'll be the first person to buy one myself since I'm in the market for an oil cooler as well.
Even if the lip of the Forester oil cooler assembly can be made to clear the idler bolt/nut, don't you have to screw the assembly with the inlet/outlet pipes sticking out down? Perhaps it may be as simple as having to loosen & remove the idler bolt/nut to install.
Old 04-21-2014, 11:43 PM   #753
glamcem
glamcem's Avatar
Drives: 2022 BRZ Limited
I received my OEM oil cooler and KW kit, when/if I can fit it I will provide some pictures
glamcem is offline   Reply With Quote
The Following 2 Users Say Thank You to glamcem For This Useful Post:
mit_peid (04-21-2014), post_break (04-22-2014)
Old 04-21-2014, 11:46 PM   #754
glamcem
glamcem's Avatar
Originally Posted by grostoine View Post
It can be your rotrex. Mine was broken and oil was coming from the back of the rotrex and could not see it installed. I could see the oil dripping but not where it came from. Uninstalled it and inspect it!!!
I wanted to know if any of you tried to take the BPV and turn it into a BOV. I think I'm gonna try but wanted your feedback first!
Just curious, did you guys pay attention to the oil reservoir level as mentioned in the instructions? Maybe, this might be the root cause of your oil leakage issues
Old 04-21-2014, 11:51 PM   #755
mit_peid
Boosted Noob
mit_peid's Avatar
I think I totally overfilled my oil reservoir (primarily because I read somewhere in this thread I should have about 2" left it the plastic rotrex bottle). The rotrex instructions tell you to take the measurement while the engine is running between 2k-3k. I still have coolant coming out of the top of the reservoir, dripping, & smoking up on the header (even after having siphoned a decent amount out) when I drive it on the street or freeway for a bit.
Old 04-22-2014, 12:08 AM   #756
captain_jack
Yeah i thought i was low, however i wasnt. I had help while checking level and it is fine. I also had a slight amount on top of resovoir but it was just a bit and hasnt leaked since.
sent from your mom
The Following User Says Thank You to captain_jack For This Useful Post:
glamcem (04-22-2014)
Kraftwerks Rotrex Supercharger Discussion nelsmar Forced Induction 697 01-18-2022 12:06 PM
All SUPERCHARGER kits compilation thread subatoy Forced Induction 76 03-10-2016 12:38 PM
Kraftwerks Supercharger?? umpadupa Forced Induction 1 08-05-2013 05:27 PM
