Old 04-19-2014, 07:01 PM   #1
1Cor10:23
1Cor10:23's Avatar
Drives: '13 Whiteout FR-S (M/T)
Perrin 3" CBE - did I install correctly?
Hi everyone.
Just installed my perrin CBE this morning and wanted to ask if this looks about right...essentially my tips look a bit recessed (balanced on both sides) into the exhaust cut-out. Taking a look at my hangers (see photos below) you can see that they're tugging toward the front of the car.
From photos I've seen on the forum, the tips usually are fully protruding from the cutout whereas only the bottom of my tips are as such.
Any thoughts would be appreciated. As far as I know, install was smooth, everything fit and torqued to spec. Also, rest of exhaust is stock other than CBE.
oh, and yes it looks beautiful and sounds fantastic
@PERRIN_Mladen @PERRIN_Jeff would appreciate your thoughts on fit.
Thanks!
1Cor10:23 is offline   Reply With Quote
Old 04-19-2014, 09:56 PM   #2
RacerX
Drives: Subaru BRZ
Yeah It looks like yours are sucked in just a bit. I think rotating/adjusting the S-pipe affects how far the tips protrude.
Here are some pics of mine.
RacerX is offline   Reply With Quote
The Following User Says Thank You to RacerX For This Useful Post:
1Cor10:23 (04-19-2014)
Old 04-19-2014, 10:02 PM   #3
1Cor10:23
1Cor10:23's Avatar
@RacerX I guess rotate the s pipe counterclockwise? Seems like if I rotate clockwise it'll hit the diff. I'll give it a shot tomorrow
Old 04-19-2014, 10:16 PM   #4
RacerX
Drives: Subaru BRZ
I didn't really mess with mine too much when I installed it. It all just slid into place and the tips looked great on the first try. The whole install took less time than getting the car up on jackstands.
Loosen the V-Band clamps and see what effect rotating the S-Pipe has. It should swing the muffler towards the rear of the car.
Old 04-20-2014, 10:28 AM   #5
YangerD
YangerD's Avatar
Drives: 2017 Toyota 86
I actually like how the tips look on yours OP; the flush looks great in my opinion. BTW where did you get the exhaust from? From Toronto as well.
YangerD is offline   Reply With Quote
Old 04-20-2014, 10:50 AM   #6
dxero
Drives: 13 BRZ Sport Tech WRB
I too would like the know the pricing and where you got it. Because Canada.
dxero is offline   Reply With Quote
Old 04-20-2014, 03:29 PM   #7
1Cor10:23
1Cor10:23's Avatar
@YangerD yeah I do as well haha will leave as is. @dxero my parents live in MA, I'm here over Easter so just got it shipped here. However, alphamotorsports in Markham area has a really good price on the 2.5 and likely can get you the 3. Not affiliated at all but happy to pass on a good price when I find one
The Following User Says Thank You to 1Cor10:23 For This Useful Post:
dxero (04-20-2014)
Old 04-21-2014, 12:25 PM   #8
PERRIN_Mladen
PERRIN_Mladen's Avatar
Drives: '11 535i
Once you've got it set on your car, adjustment is pretty easy. Loosen the two V bands on the S pipe, the connection to the mid pipe, and the connection to the muffler. Then twist the S pipe to move the muffler to the desired location, then retighten the V bands, and you are done!
Mine slightly protrude out a bit, but nothing too crazy. I can get a few photos if you'd like.
PERRIN_Mladen is offline   Reply With Quote
Old 04-21-2014, 05:19 PM   #9
Efenys
Drives: Galaxy Blue 6sp BRZ LTD
This fixed helped me last summer. Check it out.
Efenys is offline   Reply With Quote
Old 12-07-2014, 05:24 AM   #10
Lokenzi
Drives: 2015 Blue.Series.BRZ
I would love to see pics!
Lokenzi is offline   Reply With Quote
Old 12-07-2014, 09:17 AM   #11
wparsons
wparsons's Avatar
My 2.5" resonated is exactly the same. You definitely need two people to adjust the tips. One to be a spotter, one to tighten the clamps.
flickr
Old 12-07-2014, 10:20 AM   #12
1Cor10:23
1Cor10:23's Avatar
I've since given up Haha - it's imperfectly perfect.
Old 12-07-2014, 10:59 AM   #13
wparsons
wparsons's Avatar
If you change your mind and want a second set of hands, just let me know!
flickr
1Cor10:23 (12-07-2014)
Old 12-08-2014, 12:20 PM   #14
PERRIN_Mladen
Drives: '11 535i
No problem! Let me run out to the car and see what I can come up with.
How to do E85 correctly? Anthony Engine, Exhaust, Transmission 95 12-11-2017 04:06 PM
Cusco intake pipe...did I install this correctly? Trmx2 Engine, Exhaust, Transmission 14 08-28-2017 03:25 PM
3" Perrin Resonated Cat-back w/ 3" Nameless Catted Downpipe Kevstra Engine, Exhaust, Transmission 28 05-20-2016 08:38 PM
DIY "Grimspeed/Perrin" license plate relocation BMHumanic Cosmetic Modification (Interior/Exterior/Lighting) 3 02-05-2015 12:44 PM
