Old 04-19-2014, 05:46 PM   #15
blackfireball5
blackfireball5's Avatar
Drives: Scion FRS Firestorm
You should post some pictures up here of yours using epoxy and give your experience with it when you finish.
Wheelwell Profile
Use code TWW-BOO5TED when shopping at Wheelwell to receive 10% off your order.
blackfireball5 is offline   Reply With Quote
The Following User Says Thank You to blackfireball5 For This Useful Post:
OjiGeorge (04-20-2014)
Old 04-20-2014, 12:03 AM   #16
gram
Drives: 2013 FRS Firestorm
glue
There is a glue called pl2000, or pl3000 It will bond anything. I would suggest trying that to bond the 2 materials. You will probably need a caulking gun to dispense it(last time I used it-it only came in that form)
gram is offline   Reply With Quote
The Following User Says Thank You to gram For This Useful Post:
blackfireball5 (04-20-2014)
Old 04-20-2014, 12:15 AM   #17
blackfireball5
Thanks! I'll look for that!
Wheelwell Profile
Old 04-20-2014, 07:31 AM   #18
mike the snake
There's another glue called Amazing Goop, similar to Shoe Goo. It is rubber based, and also glues anything, but has some give to it.
It can also be unglued easily with toluene or gasoline.
This is what I used to glue the wire mesh screens into the holes I cut into my front mouthpiece on my BRZ.
The Following User Says Thank You to mike the snake For This Useful Post:
Old 04-20-2014, 11:38 AM   #19
blackfireball5
Did it hold up to highway speeds?
Wheelwell Profile
Old 04-20-2014, 03:07 PM   #20
86-tundra
Troll Hunter
86-tundra's Avatar
Drives: fr-s, tundra
Wow I'm digging this mod. Nice thinking. Probably way more functional than fog lights!!!
86-tundra is offline   Reply With Quote
The Following User Says Thank You to 86-tundra For This Useful Post:
Old 04-20-2014, 11:47 PM   #21
ikkomaji22
ikkomaji22's Avatar
Drives: Subaru brz
Hope this helps someone.
[/QUOTE]
dude im not going to lie at first i was wth is he doing.. but the end result looks really impressive. Good alternative to the APR ducts.
ikkomaji22 is offline   Reply With Quote
The Following User Says Thank You to ikkomaji22 For This Useful Post:
Old 04-20-2014, 11:49 PM   #22
blackfireball5
Pictures don't do it justice. :-)
Wheelwell Profile
Old 04-20-2014, 11:51 PM   #23
86-tundra
Troll Hunter
86-tundra's Avatar
Originally Posted by blackfireball5 View Post
You can get the OEM bezels from diode dynamics for 40 bucks. Yeah, i didn't want to have to deal with all the work of cutting those shapes out.
http://www.diodedynamics.com/store/l...ezels-set.html
this is a broken link.. any idea where I can find a working link to buy from?
Old 04-20-2014, 11:55 PM   #24
blackfireball5
Here you are. I will update the link. Thanks!
http://www.diodedynamics.com/store/2...ezels-set.html
Wheelwell Profile
86-tundra (04-20-2014)
Old 04-21-2014, 12:01 AM   #25
blackfireball5
I'm thinking about pulling them out and trying to use this to adhere it. Gonna look a little more but I'm thinking this might do the trick.
http://m.lowes.com/product?langId=-1...lue=4294867169
Wheelwell Profile
Old 04-21-2014, 12:05 AM   #26
blackfireball5
Better yet :
http://m.lowes.com/pd_556899-81288-8...uctId=50149638
Wheelwell Profile
Old 04-21-2014, 12:31 AM   #27
retrosmiths
Drives: Scion FR-S Whiteout
So these vents air towards the wheel well liner? No pipes? Won't that change pressure under the hood, which might cause the hood itself to rattle at high speeds?
Sent from my phone. Might have typos. Sorry.
2013 Scion FR-S
retrosmiths is offline   Reply With Quote
Old 04-21-2014, 01:05 AM   #28
blackfireball5
I honestly don't think there would be that big of a change. I can tell you I don't notice any rattling at highway speeds. However, I haven't been to a track with them yet.
Wheelwell Profile
**Toyota 86 Fog Light Bezels $34.9, 86 Arm Rest, GT86 Badge, Fog Light Set for $112.9 nigel-jdmparts Exterior Parts - The Rest 524 02-28-2016 10:24 AM
WTB: fog light bezels natesparxxx Exterior Parts (Aero, Lighting, Etc.) 1 03-20-2014 11:44 AM
Pair of FR-S fog light bezels speedrye Exterior Parts (Aero, Lighting, Etc.) 2 02-21-2014 01:28 AM
Installing JDM Fog Light Bezels knewsom32 Cosmetic Modification (Interior/Exterior/Lighting) 13 01-22-2014 01:29 PM
Color matched fog light bezels NyC Zn6 Cosmetic Modification (Interior/Exterior/Lighting) 1 06-05-2013 12:10 AM
