Old 04-20-2014, 02:40 AM   #4271
Carlitoz3
Carlitoz3's Avatar
Drives: 2013 MT Asphalt FRS
Originally Posted by Shneegle View Post
Finally got all the files from my tuner and have the dyno below. All runs were done on the same day and same car. I included 3 pull in the dyno graph and they are as follows:
Blue - Stock FRS
Red - Nameless 4-2-1 Header + 3" Nameless Header-back Exhaust
Green- Header + Exhaust + Tune
Tuned By Aaron at ATSRacing in Denton, TX
Stock was putting up a battle at 3000 rpm
Carlitoz3 is offline   Reply With Quote
Old 04-20-2014, 04:11 AM   #4272
regal
Drives: Scion FR-S/Toyota Yaris
Yes there is significant loss in low end torque. The 4-2-1 HKS doesn't have this issue, is it tuning or the header?
2013 FRS Argento Silver 6MT
Mods:
Clear fender side lights
Tactrix ZA1JB01C 2014 Calib
regal is offline   Reply With Quote
Old 04-20-2014, 08:31 AM   #4273
wparsons
wparsons's Avatar
Anyone posting dynos have a tuned baseline vs re-tuned with header?
flickr
Old 04-20-2014, 09:40 AM   #4274
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Originally Posted by Tainen View Post
Was the flange flat? Gasket failure, or did it need some sort of extra thick gasket due to flange to header surface issues?
Part of the reason why I ask is some people were eviscerating nameless for a few leaks that appeared to be installer error or gasket failures. I'd prefer if the truth spoke for itself.
Thanks for the pic/info Raul!
He's at the track this weekend, but he's a friend and we spoke about this so before your post get buried down, it was gasket failure. @raul correct me if wrong or need to add any info.
PSA: Stock gaskets are a POS and if you are replacing any exhaust component, either get a good gasket or get Subaru Legacy turbo thick metal gaskets.
With all due respect and this is my worthless 2 cents, that is a really jumpy dyno curve considering it's already smoothing 5. You should take a 3rd gear WOT log just to confirm and make sure you are not knocking.
The Following User Says Thank You to Sportsguy83 For This Useful Post:
raul (04-20-2014)
Old 04-20-2014, 09:49 AM   #4275
kiichiro
corolla specs/GTR looks
Drives: ooh oooh pretty tail lights
I love my hks on street but it's built to tuck in under oe plate and just too hit for track time
I gonna give Jason my post tax dolla ... Stepped cat less?
But I want it so it doesn't tuck in oe plate
I want it to run cool for me in phx
Ready to order, can a one off be made for me?
SOLD THEM BOTH
Hers: 2007 987S
Mine: 2012 991S
That was fun, thanks Hachi
kiichiro is offline   Reply With Quote
Old 04-20-2014, 09:51 AM   #4276
kiichiro
Can't agree more, love my grim speed header gaskets, oe suck!
SOLD THEM BOTH
Hers: 2007 987S
Mine: 2012 991S
Old 04-20-2014, 09:53 AM   #4277
tennisfreak
Drives: 2018 BMW M240i
Wow thanks for the dynos! So from Shneegles dyno it looks like just a header without a tune is pretty much worthless. HP is about exact same and the torque curve is modified to move the dip around some.
Old 04-20-2014, 09:54 AM   #4278
mad_sb
Originally Posted by raul View Post
Well, I just finished fixing my leak with Grimmspeed gaskets. Here was the culprit:
Give me about 10 days and I'll have all my dynos gathered.
Was that gasket (the oem style that was pictured) new when you installed the header? I had just he opposite results twice now. the Grimspeed's leaked and the oem did not.
The Following User Says Thank You to mad_sb For This Useful Post:
Sportsguy83 (04-20-2014)
Old 04-20-2014, 10:05 AM   #4279
350matt
Drives: toyota mr2/ Toyota GT86
so the two results so far show about a 15-19Bhp gain at the wheels, at the top of the curve over a stock car - when its coupled with a decent exhaust and tuned
So how much $/HP is that then?
Nice results I feel for a simple bolt on part
350matt is offline   Reply With Quote
Old 04-20-2014, 10:19 AM   #4280
tennisfreak
Well for the header and tune its going to be ~$1800 so if you get a 18hp gain then its ~$100 per HP.
EDIT: If you factor in the rest of the exhaust parts then the cost goes way up and your HP return on investment goes down.
Old 04-20-2014, 11:49 AM   #4281
raul
Lap time enthusiast
raul's Avatar
Drives: Asphalt '13 FR-S 6MT
I replaced the OEM gaskets with Grimmspeed gaskets at the heads, and had to use the special Graphite gasket that Nameless provided to seal at the header/overpipe connection. I don't know if the flanges at the heads were flat, (it almost seems like the order in which you tighten things up can make a big difference with OEM gaskets) but I'm very positive the flange connecting to the overpipe has some slight warping, since I saw some slight waviness on the graphite gasket when removing the header to replace the gaskets for the heads.
raul is offline   Reply With Quote
The Following User Says Thank You to raul For This Useful Post:
Old 04-20-2014, 12:49 PM   #4282
fenton
Blue - Stock FRS
Is it safe to say you have 3000 invested between the stock run and the fully tuned run or does the stock run include all exhaust components already minus the header and tune?
Sent from my HTC One using Tapatalk
fenton is offline   Reply With Quote
Old 04-20-2014, 02:58 PM   #4283
Shneegle
Shneegle's Avatar
Drives: 2013 FRS, 2024 Trueno
First run was stock. Then we added all the exhaust components. So yes it is safe to say 3000+ invested between stock and fully tuned.
Shneegle is offline   Reply With Quote
The Following User Says Thank You to Shneegle For This Useful Post:
fenton (05-06-2014)
Old 04-20-2014, 03:09 PM   #4284
Sportsguy83
Drives: Limited BRZ
With all due respect to everyone in the thread, this exact thing is what pushed me over to go FI. A bolt on kit on low boost can be had for 4K, and will make much more power than bolt ons + tune.
I completely understand whomever does not want to deal with going FI though, I'm just sharing my train of thought.
WatchmaN (05-03-2014)
21 months no dyno, 22 months no vendor dyno, 22months4rattles&leakssmh, amazing warped qualiy, y u no tag
Nameless Performance BRZ Axleback Exhaust ESBjiujitsu Engine, Exhaust, Transmission 1377 04-21-2020 02:23 AM
Nameless Performance Axleback is available for pre-order. Nameless Performance Inc. Engine, Exhaust, Bolt-Ons 114 07-23-2012 10:38 PM
Nameless Performance Downpipe is available for pre-order. Nameless Performance Inc. Engine, Exhaust, Bolt-Ons 4 07-12-2012 04:57 PM
We are Nameless Performance. John@Nameless Announcements, Contests, Giveaways 22 06-18-2012 11:32 PM
Nameless Performance is here. Nameless Performance Inc. Engine, Exhaust, Bolt-Ons 16 06-06-2012 04:32 AM
