Old 04-18-2014, 06:22 PM   #15
IAmNotTheDriftKing
IAmNotTheDriftKing's Avatar
Drives: I own an FR-S. . . whatelse!
These stock headers aren't that bad actually(pretty good actually). Comparing it to something like a C63 AMG, which costs twice as much!!
I am sure you can guess which one is stock. Here are some headers off a R8 V8! A supercar, and they look like on par with ours(except theirs is probably EL where as ours is slightly UEL).
IAmNotTheDriftKing is offline   Reply With Quote
The Following 2 Users Say Thank You to IAmNotTheDriftKing For This Useful Post:
86-tundra (04-18-2014), Clipdat (04-18-2014)
Old 04-19-2014, 08:13 AM   #16
wparsons
wparsons's Avatar
Originally Posted by kurbkilla View Post
I'm impressed that the stock header is a stepped one (4-2-1) which is better then a 4-1 header. The only thing I think would make the stock header better is the size of the piping. Really this is a good stock header, all things considered.
Slight correction... 4-2-1 does not mean stepped.
A stepped header has the tubing diameter stepped up to a larger diameter somewhere between the head flanges and the collector.
You can have 4-2-1 non stepped, 4-1 non-stepped, 4-1 stepped, or 4-2-1 stepped (like the Nameless).
flickr
kurbkilla (04-20-2014)
Old 04-19-2014, 12:52 PM   #17
puma
crew chief
puma's Avatar
Drives: Race car FR-S
can you say what size is the piping if you still have it? I wonder if taking the cat off and welding a piece of pipe instead would yield the same results as an aftermarket header.
puma is offline   Reply With Quote
Old 04-19-2014, 01:38 PM   #18
kiichiro
corolla specs/GTR looks
Drives: ooh oooh pretty tail lights
Originally Posted by WNDSRFR View Post
As you can see the header is really not that bad a piece of work.
It is actually welded tubing rather than stamped steel as I expected it to be.
This may be why massive gains are not being seen with aftermarket headers. Because the stock one is really not that bad.
Another thing to notice is there is foam between the heat shield and the header. I'm guessing that this is the prevent rattling.
One thing you really have to think about is:
If Toyota went though all the trouble and expense of making this heat shield it must be there for a reason. (To prevent fires maybe?).
I think I'm going to wrap my header tomorrow.
Careful with the header wrap, I added some wrap I used to wrap two tubes at once with
I got a leak, it was very lite, soaked my wrap had a fire on my last track day
Took out belt, crank seal and cam position sensor plug
I'm looking at making the factory shields work with the hks header next
SOLD THEM BOTH
Hers: 2007 987S
Mine: 2012 991S
That was fun, thanks Hachi
kiichiro is offline   Reply With Quote
Old 04-19-2014, 01:52 PM   #19
ML
ML's Avatar
Drives: 13 White MT FR-S
There is a thread on here of someone doing this, and they didn't make any power if I can remember correctly.
The Following User Says Thank You to ML For This Useful Post:
tennisfreak (04-19-2014)
Old 04-19-2014, 02:08 PM   #20
Brahsbrah
Drives: 2013 BRZ Sport Tech White Pearl
This thread has got me thinking about using exhaust wrap as well...never used it before.
I thought I read somewhere that it can hold in heat and potentially cause problems because of that? It might not have been headers that they were talking about though...
Brahsbrah is offline   Reply With Quote
Old 04-19-2014, 03:47 PM   #21
tennisfreak
Drives: 2018 BMW M240i
No it mad good power. I think the dyno was in the 180 range.
Old 04-19-2014, 04:14 PM   #22
Muskokan
Drives: white Sport-tech
http://www.ft86club.com/forums/showthread.php?t=43436
Few posts down a member posts a pic of a dyno and says it has mad gains,
http://www.ft86club.com/forums/showthread.php?t=55770
This guy messes with it and says it could be better than some Ftermarket
Muskokan is offline   Reply With Quote
The Following User Says Thank You to Muskokan For This Useful Post:
ML (04-20-2014)
Old 04-19-2014, 05:33 PM   #23
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
topspeed made over 200whp gutting his manifold and running e85.
The Following 2 Users Say Thank You to Reaper For This Useful Post:
Bg8780 (04-20-2014), kiichiro (04-20-2014)
Old 04-20-2014, 11:00 AM   #24
IAmNotTheDriftKing
I wouldn't say that is a very good way to judge if that getting rid of the cat is worth it or not for these headers. E85 is powerful stuff. Like this, 201whp completely stock car! Clicky
Old 02-08-2016, 03:01 AM   #25
Rcsp24
Drives: 2013 subaru brz
One of our forum member (forum name DBW) made 213 whp and 172 tq on a dynojet out of our stock headers, e85, 3 inch catless exhaust and a drop in filter. He chops off the header cat and replace it with a 3 inch pipe.
http://www.ft86club.com/forums/showthread.php?t=57270
Rcsp24 is offline   Reply With Quote
Old 02-08-2016, 06:37 AM   #26
RichardsFRS
RichardsFRS's Avatar
Drives: 2013 Pearl White 6MT
Its a good looking header actually. What do you do for heat with aftermarket ones? Wrap them?
Last edited by RichardsFRS; 02-08-2016 at 01:27 PM. Reason: Pretty sure I wasn't talking about sexual satisfaction, and typing on this phone sux
RichardsFRS is offline   Reply With Quote
Old 02-08-2016, 08:02 AM   #27
Mikepage
Mikepage's Avatar
Drives: Scion FR-S 2013 Raven
Originally Posted by RichardsFRS View Post
Its a good looking header actually. What do you do for head with aftermet ones? Wrap them?
Or coating.
o= FR-S =o
Mikepage is offline   Reply With Quote
Old 02-08-2016, 11:34 AM   #28
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Originally Posted by Mikepage View Post
Or coating.
I have a feeling that saving up to have them ceramic coated is a better option. I've heard horror stories at car shows where the wrap gets some oil on it and begins to burn, not something I want to worry about on a daily driver
HKS Boxer Spec UEL Exhaust Manifold brz_star21 Engine, Exhaust, Transmission 73 02-06-2022 12:14 AM
Exhaust System/Exhaust Manifold Removal and Replacement GrimmSpeed DIY (Do-It-Yourself) Guides 52 11-11-2015 09:30 PM
Straight Manifold back exhaust (Kinda) SmsAlSuwaidi Engine, Exhaust, Transmission 6 11-25-2013 09:25 AM
Stock manifold changing collector Djen Engine, Exhaust, Transmission 7 06-15-2013 02:23 AM
Need factory exhaust manifold dorifuto Engine, Exhaust, Transmission 1 01-24-2013 01:05 PM
