Old 04-18-2014, 09:07 PM   #1
SalM
Drives: 2013 Whiteout FR-S
Twin Turbo Kit ?
Hey what's up guys ?
I've been searching around and couldn't seem to find anything. But are any companies releasing a twin turbo kit anytime soon ?
SalM is offline   Reply With Quote
Old 04-18-2014, 09:29 PM   #2
jflogerzi
jflogerzi's Avatar
I don't think it will happen due to the engine bay size.
Old 04-18-2014, 09:30 PM   #3
SalM
That's exactly what I was thinking. Cause two smaller turbos would be awesome.
~@SalMPhotography~
-Instagram
-Facebook
-Flickr.com/SalMPhotography
Old 04-18-2014, 09:36 PM   #4
the new guy
Drives: 2014 Asphalt FR-S/2018 Thunder GT
@kalengray on Instagram is working on a twin charge setup
Look at https://m.facebook.com/graydevelopments
the new guy is offline   Reply With Quote
Old 04-19-2014, 03:38 AM   #5
FAER
Drives: Silver BRZ
where is the star trek face palm MeMe when u need it
FAER is offline   Reply With Quote
The Following 2 Users Say Thank You to FAER For This Useful Post:
Boxer-86 (04-19-2014), JackSmiley (04-19-2014)
Old 04-19-2014, 04:20 AM   #6
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
Small engine and twin turbos? Why would anybody do that?
The Following User Says Thank You to EAGLE5 For This Useful Post:
Old 04-19-2014, 04:22 AM   #7
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
This engine doesnt move enough cubic air to require the need for two turbos when one midsized or larger turbo can do the job just fine
The Following User Says Thank You to cdrazic93 For This Useful Post:
Old 04-19-2014, 04:41 AM   #8
EAGLE5
Dismember
EAGLE5's Avatar
MeMe?
Ammonia (04-19-2014)
Old 04-19-2014, 07:14 AM   #9
carlitosway6891
Drives: white out project fr-s
IMO the only way a twin turbo setup would work because of the low displacement setup we have is if it was a compounded system like say a factory toyota supra setup or something where you have one small turbo for quick low end spool and then switch over to a bigger turbo for high RPM boost through switching valves...
but then you have the added weight and cost of running two turbos...im sure if sized right for your goal and needs, you could get great spool and power....with this cars high compression and direct injection features, lag with a bigger turbo is not as bad as ppl think it is. im running a gt3582r turbo and you can hear mine start spooling as low as 2800RPM and full song by 3200RPM then i still have over 4k RPM to play with. this motor loves to push big turbos for sure
carlitosway6891 is offline   Reply With Quote
The Following 2 Users Say Thank You to carlitosway6891 For This Useful Post:
ftc~brz (04-19-2014), suaveflooder (06-18-2014)
Old 04-19-2014, 09:30 AM   #10
mid_life_crisis
Drives: FR-S 10 #103 AT
They've been putting turbos on bikes that rev higher than these cars for a long time, so one liter spinning a turbo properly is not the issue. The problem is that a turbo designed for one liter takes up more than half the space of one designed for two liters, so it is just too much work to get a pair to fit for the minimal advantage you might get.
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West
Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid."
mid_life_crisis is offline   Reply With Quote
Old 04-19-2014, 11:40 AM   #11
SilverSkyline210
SilverSkyline210's Avatar
Drives: WRB BRZ
toxic detail and performance is doing it to their shop car
https://www.facebook.com/41337004539...type=3&theater
SilverSkyline210 is offline   Reply With Quote
The Following User Says Thank You to SilverSkyline210 For This Useful Post:
Old 04-19-2014, 11:52 AM   #12
raven1231
Because racecar! FRSUPRA!!!!! Twin turbos are always faster than single. MOAR IS MOAR ESPECIALLY WHEN IT COMES TO POWAH!!!!!!!!!!!!!!
Old 04-19-2014, 11:54 AM   #13
SalM
Thanks for the input guys !
~@SalMPhotography~
-Instagram
-Facebook
Old 04-19-2014, 02:23 PM   #14
glorydays
Remember me?
glorydays's Avatar
Drives: BRZ Series.Blue
Other than the cool factor, even I can't see the point. Twin charged makes sense but not twin turbo
glorydays is offline   Reply With Quote
Twin Turbo FR-S/BRZ? KidWonder Scion FR-S / Toyota 86 GT86 General Forum 44 06-27-2014 01:22 AM
what's the difference between twin screw, centrifugal, single turbo and twin turbo? warplane95 Forced Induction 86 04-17-2014 02:36 PM
Twin Turbo BRZ xn7485 BRZ Photos, Videos, Wallpapers, Gallery Forum 10 08-23-2013 07:13 PM
Dealership twin turbo brz... BRZ283 BRZ First-Gen (2012+) — General Topics 23 06-03-2013 10:59 AM
Twin Turbo kit? enjoi23 Forced Induction 15 12-03-2012 07:53 PM
