Old 04-19-2014, 12:37 AM   #29
Fett4Real
AKA Mugen Dom
Fett4Real's Avatar
Drives: 2013 FR-S, 2007 FJ Voodoo Blue
Trevorovert Id like to see how your cutoff looks with a retrofit...
Fett4Real is offline   Reply With Quote
Old 04-19-2014, 10:11 AM   #30
86-tundra
Troll Hunter
86-tundra's Avatar
Drives: fr-s, tundra
sure I will get a pic whenever I get back to austin. took my FJ down to houston to visit family. monday sometime
86-tundra is offline   Reply With Quote
Old 04-19-2014, 03:17 PM   #31
LittleMonster
Drives: Scion FR-S
Because there is power flowing through that black wire you left hooked up... you need it to have its own ground. The red wire is hot all the time unless you turn on your lowbeams... theres a few points I looked around while the bumper was off to ground to.. just find a bolt on the metal part of the car....wire brush a little or sand paper to get it to the bare metal...and connect the black wire to that.
Great! I isolated the ground wires from each light and they work perfectly now. Thanks for the help guys, it looks sick!
LittleMonster is offline   Reply With Quote
Old 04-19-2014, 03:30 PM   #32
Fett4Real
AKA Mugen Dom
Fett4Real's Avatar
Cool there are two grounds you can use...Ill snap a pic later for others...its right on the chasis...maybe 12 inches from the harness connection on the back of the light
Old 04-20-2014, 03:23 AM   #33
Fett4Real
AKA Mugen Dom
Fett4Real's Avatar
Sent from my SCH-I545 using Tapatalk
Old 04-21-2014, 04:15 PM   #34
FRSHunter
Drives: Asphalt FRS
Is the chrome paint really that bad? Might go with a combination of newspaper and 3m blue tape.
FRSHunter is offline   Reply With Quote
Old 04-21-2014, 04:42 PM   #35
86-tundra
Troll Hunter
86-tundra's Avatar
yeah its awful. I would advise newspaper and 3m
Old 04-21-2014, 06:19 PM   #36
Fett4Real
AKA Mugen Dom
Fett4Real's Avatar
If you goto home depot and get the day old paint easy release 3M BLUE painters tape it wont peel any of the chrome up. I had no issues with the chrome paint...
Had some issues with the HID kit for the H11 bulb however, they came with the bulb upsidedown basically giving me a dead spot on each headlight, HOWEVER easy fix flip them over after trimming the plastic surround.
Old 04-21-2014, 06:27 PM   #37
FRSHunter
Drives: Asphalt FRS
I'm assuming something like this? [ame="http://www.amazon.com/ScotchBlue-Painters-Advanced-Delicate-94-Inch/dp/B000BQWD12/ref=sr_1_5?s=hi&ie=UTF8&qid=1398118977&sr=1-5&keywords=3m+painters+tape+safe-release"]http://www.amazon.com/ScotchBlue-Painters-Advanced-Delicate-94-Inch/dp/B000BQWD12/ref=sr_1_5?s=hi&ie=UTF8&qid=1398118977&sr=1-5&keywords=3m+painters+tape+safe-release[/ame]
Old 04-21-2014, 06:46 PM   #38
Fett4Real
AKA Mugen Dom
Fett4Real's Avatar
YUP that exactly!
Old 07-18-2014, 04:06 AM   #39
l0aded
Addicted
l0aded's Avatar
Drives: 2013 Asphalt FR-S 6MT
Is your method possible of turning the DRLs on possible if you don't want to take apart the headlight? Maybe with a T-tap?
Phantom Supercharger | Tsudo Cat-Back Exhaust | K&N Drop-in Filter | Winjet Headlights | Opti-coated | 35/20 Tint | Radar/Dashcam Hardwired | OFT tuned | OEM Audio+ Reference 400CF | Uber Sound Deadened | LED DRL strips | JPM Coachworks Kneepads
l0aded is offline   Reply With Quote
Old 07-18-2014, 05:06 AM   #40
Mad1723
Mad1723's Avatar
Drives: Asphalt FR-S
Any pictures of the output? I'm thinking about doing this eventually and this guide is perfect!
Mad1723 is offline   Reply With Quote
Old 07-22-2014, 08:27 AM   #41
86-tundra
Troll Hunter
86-tundra's Avatar
Yes of course, when you get the headlights you'll be able to route those red and black wires to wherever you want. I can't remember where they are originally designed to go, but you can hook them up to anything.
Old 07-22-2014, 08:29 AM   #42
86-tundra
Troll Hunter
86-tundra's Avatar
I actually hadn't thought of this. I will definitely take a pic next time I'm in my car at night.
The light cutoff is laser-beam like , but you will get a very slight amount of leak from the DRL's. When I say slight amount, I really do mean a slight amount.. they aren't really well defined, so it's not like you can watch them as you drive around. it looks like a very soft flashlight. It has never really bugged me
The Following User Says Thank You to 86-tundra For This Useful Post:
Mad1723 (07-22-2014)
DIY Retrofit Winjet headlights post_break DIY (Do-It-Yourself) Guides 6 07-15-2014 12:13 AM
WTT: Winjet Black Headlight for Winjet chrome dezmoondo Exterior Parts (Aero, Lighting, Etc.) 0 04-13-2014 03:02 AM
Install Morimoto Retrofit kit into Winjet lights? Khyron686 Cosmetic Modification (Interior/Exterior/Lighting) 2 03-17-2014 05:55 PM
Custom Purple Winjet and Black Winjet Headlights xclusive_brett Cosmetic Modification (Interior/Exterior/Lighting) 35 12-17-2013 08:28 AM
