Sam Strano
Old 04-18-2014, 10:49 PM   #1037
Guff
Now w/ over 400 womprats!
Guff's Avatar
Drives: BRZ LZR
Originally Posted by travisb View Post
I did my first autox in the BRZ last weekend. I'm not new to autox, but my budget is very small this year. The only thing I will probably be able to do is tires and maybe something else not too expensive. I might be able to get dedicated wheels/tires next year.
The tires will be for DD and autox. I live in Virginia and we have plenty of rain and cold days. I won't be driving much in snow, if any at all.
My goal is not to win class. I just want to be more competitive than I was with the stock tires.
1) I am looking at Michelin Pilot Super Sport in either 215/45R17 or 225/45R17 on the stock wheels. With only 10MM difference is it worth going to 225?
2) Also, is it worth getting spacers to widen the stance and if so, how much could I do on the stock wheels. The spaces would have new studs.
3) While I am at it, it would be good to get camber bolts since they are cheap. What kind of alignment should I be looking at given everything I mentioned?
MPSS have decently soft sidewalls, so I would stick with the 215s. 225 might be a little too pinched.
- The Ancient BRZ Sacrament
by Zaku
Old 04-18-2014, 11:17 PM   #1038
Thrustin
Drives: 2014 BRZ Limited, 2013 Focus ST
Why is it that Michelin Pilot Super Sports seem to be such a favorite with Toyobaru owners? I never considered the tire, especially for autocross.
Thrustin is offline   Reply With Quote
Old 04-18-2014, 11:25 PM   #1039
Guff
Guff's Avatar
Drives: BRZ LZR
It's a great daily driver tire! Comfortable, decent in wet and cold, wears like a rock, and is decently grippy. And it has Michelin's killer warranty.
My Co-driver finished top ten in PAX at our last event, and there's a lot of intense competition at CCSCC autocrosses.
You just have to manage heat carefully and they grip with the rest of them...
by Zaku
Old 04-18-2014, 11:38 PM   #1040
Thrustin
I'll have to keep am eye out, but I don't remember many of that tire at our local SCCA events. It's mostly RE-11s, RS3s, Rivals, ZII, etc. It just seems that the love for that particular Michelin tire is a bit extreme for what it is.
The Following User Says Thank You to Thrustin For This Useful Post:
Guff (04-18-2014)
Old 04-18-2014, 11:42 PM   #1041
Guff
Guff's Avatar
Drives: BRZ LZR
If I had a second set of rims, I'd definitely have RS3s or Star Specs mounted, and I would use that set solely for autocross. But for those of us who need a daily driver tire that we can take out to autocross, MPSS are a fantastic option.
by Zaku
Old 04-19-2014, 10:05 AM   #1042
TRev
Originally Posted by TrqlessWonder View Post
And a +1 on the running away thing. It was covered a few pages back and sort of echoed by our resident SAC member. If no one tries, what reason (other than the mental masturbation of bench racing) would anyone have for making a change? Particularly when a strong signal tends to be necessary to push a change through. I say next person to see Daddio tosses him the keys.
It does require someone trying in the Twins but it can start to be fairly obvious too. For example Stuart running within a tenth of Heinitz is another data point. You see that pattern across a few events with a few different seasoned drivers and courses and it should start to be fairly obvious.
TRev is offline   Reply With Quote
Old 04-20-2014, 12:48 AM   #1043
Sccabrz192
Detroit Region, MI
Sccabrz192's Avatar
Drives: 13 BRZ, 13 Volt, 02 WRX
Full report tomorrow but a bit of a frustrating test and tune day today in Peru, IN... CEL for cyl 2 misfire, stability control intruding in the slaloms forcing brake-apply (looks like I need to start pedal dancing)
And at the end of the day, took 2 runs in the FP solstice and obliterated my own CS index by over a second. :-(
Not the result I was hoping for
Detroit / NWOR SCCA Member
2005-06: #192 ES 91 MR2 N/A Hardtop
2007-08: #54 STX 05 WRX Sedan
2009-12: #92 BSP/ASP 07 Solstice GXP
2013-14 : #192 CS 13 Subaru BRZ
Sccabrz192 is offline   Reply With Quote
Old 04-20-2014, 07:37 PM   #1044
xwd
Wow, I've never had the EBD stuff kick in on any course. The pedal dance is almost guaranteed to induce ABS ice mode, at least it did the one time I tried it.
Old 04-20-2014, 09:02 PM   #1045
Kido1986
Dodging cones
Kido1986's Avatar
Drives: 2013 BRZ Limited, 93 Z28
If you brake when loose in the slalom, it WILL kick in (I've had it). But it is much less intrusive than the icemode when Ive used pedal dance.
Originally Posted by trevorovert View Post
Originally Posted by mrbillclintong View Post
If you guys spot any riced frs/brz post them here just for laughs no hating please.
Isn't there already a thread like this? It's called aggressive wheels or summat...
C Street Build/Progress Questions about C Street Autocrossing?
Kido1986 is offline   Reply With Quote
Old 04-21-2014, 07:05 PM   #1046
Simmons
Simmons's Avatar
Drives: 2024 GR86/ 2015 FRS
I am selling some 235/40/17 Yokohama AD08R tires....These would be great for C Street.
Simmons
2024 GR86 71 STR/ 2015 FRS 71 STX
Sponsors Xero-Limit//Karcepts
Simmons is offline   Reply With Quote
Old 04-21-2014, 08:13 PM   #1047
NLSP
NLSP's Avatar
Drives: 2014 Ultramarine FR-S
Hey all,
In the rules, it states:
Suspension bushings, including but not limited to those which carry the weight of the vehicle and determine ride height, may not be replaced with bushings of a different material or dimension
Is this implying we can use other bushings as long as it's the same size and also made from rubber? Otherwise, wouldn't they just state it has to be a "factory part"? The term "factory part" is used in the next point about control arms, so it raises my question on the statement about the suspension bushings.
Any clarification would be great, thank you.
Old 04-21-2014, 08:27 PM   #1048
tahdizzle
So elite I'm 1338
Drives: WRB Subaru BRZ
From my understanding, you can use poly urethane bushings, but not solid or metal bushings.
Old 04-21-2014, 08:32 PM   #1049
Rexpelagi
Drives: 2013 Subaru BRZ
This is not legal in street/stock and sends you to STX, as poly isn't the same as rubber.
I think they use the language they use in order to allow for non-OE factory replacements, such as rubber Autozone or Rock Auto ones. This is probably more relevant for older cars where stock stuff may be expensive or hard to find.
-John L.
2011 BMW M3 - 57 FS
2007 Ford SGT - 57 FS
2013 Subaru BRZ - Sold
Rexpelagi is offline   Reply With Quote
The Following User Says Thank You to Rexpelagi For This Useful Post:
NLSP (04-21-2014)
Old 04-21-2014, 10:06 PM   #1050
NLSP
NLSP's Avatar
Thanks, that makes sense. Then that leads me to my next question. If we can use non-OE bushings that are also rubber, doesn't that technically mean we can use TRD's rubber suspension bushings?
Cinco De Mayo SCCA SOLO Ryeong86 NY / NJ / CT / PA 0 04-23-2013 06:22 PM
Koni Sports in SCCA SOLO Ryeong86 Tracking / Autocross / HPDE / Drifting 4 04-22-2013 01:58 PM
2013 Preliminary SCCA SOLO and PRO SOLO National Schedule Scooby South Tracking / Autocross / HPDE / Drifting 13 12-05-2012 09:08 AM
Houston SCCA Solo #9 - 5 FRS, 1 BRZ hankster Tracking / Autocross / HPDE / Drifting 0 10-09-2012 02:35 PM
SCCA Solo Car Class for the FR-S/BRZ? MrVito Scion FR-S / Toyota 86 GT86 General Forum 31 06-15-2012 11:03 AM
