Old 04-18-2014, 12:07 PM   #1
klassick
Drives: Hot Lava Scion FRS
Left turn signal not working.
Hey guys not too sure if this is the right spot to post this but here it goes.
Yesterday I installed my winjet headlights but now my left turn driver's side signal doesn't seem to work. The light turns on when I turn on my night time lights but it doesn't seem to flash for my hazards, left turn signal or alarm. I tried replacing the flasher and also putting back the stock lights but still not luck. Any ideas? Thanks!
on the side note - these lights look great!
klassick is offline   Reply With Quote
Old 04-18-2014, 12:16 PM   #2
White64Goat
Did you check the rear bulb?
Old 04-18-2014, 12:25 PM   #3
klassick
Yes the rear bulb is working but is hyperflashing
Old 04-18-2014, 12:28 PM   #4
White64Goat
how about the right side? Normal flash?
Old 04-18-2014, 12:28 PM   #5
klassick
Yes the right side front and rear are working normally
Old 04-18-2014, 12:30 PM   #6
Diode Dynamics
Diode Dynamics's Avatar
Did you check your wiring going into the socket on that side to make sure it's still connected?
Check the bulb too, put it in the other side to test it
Nick C.
John C.
Diode Dynamics
Old 04-18-2014, 12:57 PM   #7
HapaHaole
Drives: Grocery cart
Sounds like a bad bulb for the front.
SOLD: 2014 BRZ Limited WRB 6 Speed.
HapaHaole is offline   Reply With Quote
Old 04-18-2014, 03:56 PM   #8
White64Goat
Update?
Old 04-18-2014, 07:42 PM   #9
White64Goat
Garage must have exploded and took down his interwebs.....
Old 04-18-2014, 08:30 PM   #10
klassick
Update?
Sorry for the late reply, i was at work. I haven't had a chance to try switching the bulbs but I'll test it out tomorrow
Old 08-10-2015, 04:11 PM   #11
Kuros
Drives: 2014 FRS Raven. 2011 sti red (gone)
Sorry to bring this back from the dead, but did you ever get this figured out?
Kuros is offline   Reply With Quote
Old 08-11-2015, 09:48 AM   #12
klassick
Hey, so yes I ended up fixing the issue. I think when I removed the bumper I damaged the bulb somehow so it wasn't flashing.
I just replaced it with a brand new bulb and it was good to go.
Old 08-12-2015, 12:09 PM   #13
Kuros
Hmm. Alright.
I'm have a very similar issue, but the bulb comes on with the parking lights.
Old 08-12-2015, 12:50 PM   #14
JDKane527
JDKane527's Avatar
Drives: Asphalt Scion FR-S
Hmm. Alright.
It's a dual filament, so the turn signal portion isn't working.
JDKane527 is offline   Reply With Quote
FRS turn signal mods subiestyle Cosmetic Modification (Interior/Exterior/Lighting) 19 03-07-2014 01:34 AM
Crystal eye tails turn signal not working. FRSfan111 Cosmetic Modification (Interior/Exterior/Lighting) 14 01-06-2014 05:54 PM
My front turn signal lights not working after shop installed LED DRL bezel speedy racer Cosmetic Modification (Interior/Exterior/Lighting) 6 10-11-2013 05:08 PM
Left fog light stopped working 2 days after LED switch, possible culprit? tracerit Cosmetic Modification (Interior/Exterior/Lighting) 5 09-18-2013 12:41 AM
Anyone seen these turn signal/drl less? djliquidsteele Cosmetic Modification (Interior/Exterior/Lighting) 7 07-15-2012 03:32 AM
