Old 04-17-2014, 09:24 PM   #29
Boss Paco
Subaru Certified Sales
Boss Paco's Avatar
Drives: '13 BRZ Premium, '05 WRX STi
Originally Posted by SmsAlSuwaidi View Post
California on the other hand isn't
Are you serious? Is it because of your nazi like smog laws?
[Subaru WRX STi] Benson Block - Kelford Cams - PTE6466 - ID2000s - AEM - E85
[Subaru BRZ] Speed by Design Turbo Kit - Invidia N1 - BC Racing BR Coilovers - Rota RT5s
[Subaru WRX] Prodrive - Subaru Tecnica International - APS - Tein - Rota Titans
"The only thing that I trust in this world is cars!" - Don 'The Goods' Ready
Boss Paco is offline   Reply With Quote
Old 04-18-2014, 07:02 AM   #30
onzippy
Drives: 2014 FRS
Originally Posted by DeliciousTuning View Post
Hi All,
We are now offering flash and go EcuTeK tunes for ANY forced induction kit (turbo or supercharged), including your own custom FI setups......
What does flash and go EcuTeK tunes mean? Is it like a remote or etune where logs and maps get sent back and forth or have you already developed maps for various FI setups?
Thanks. I think I'm interested to get off the base map that came with my kit.
onzippy is offline   Reply With Quote
Old 04-18-2014, 12:02 PM   #31
Hawaiian
That guy
Hawaiian's Avatar
Drives: Ultramarine mt FR-S
Like tut said, Prime motoring is right over the bridge.
Ultramarine mt FR-S
P&L stage 1 turbo
Prime Motoring Flex fuel
Jr Tuned 506whp @17psi (e73)
Hawaiian is offline   Reply With Quote
The Following User Says Thank You to Hawaiian For This Useful Post:
onzippy (04-18-2014)
Old 04-18-2014, 05:01 PM   #32
onzippy
Drives: 2014 FRS
Thanks. Ecutek lists a number of tuners in range of where I am; Prime isn't one of them. I was really asking about the terminology. Haven't seen "flash and go" before.
Old 04-18-2014, 07:38 PM   #33
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
Sorry for the poor grammer. We have developed maps for ANY application. So we have a solid base map that will work on any application designed around Speed Density. So drop in one of the map sensors we recommend and you are good to go.
Depending on the power level you are at we can tune your car on STOCK injectors to about 11-12 pounds of boost on E85. If you are planning on running 91-94 octane only then you will not run out of fuel on stock injectors. Saves you a little money by not needing to upgrade injectors and allows you to have a perfect startup and idle.
Cheers,
William Knose
Old 04-18-2014, 07:39 PM   #34
DeliciousTuning
"Flash and Go" is something we coined for our Speed Density maps. Literally drop it in and drive. Yes we can perform tweaks (custom tune) but the base Speed Density map we created is fairly robust and will make good power right out of the box.
Cheers,
William Knose
The Following User Says Thank You to DeliciousTuning For This Useful Post:
going forced induction ft86me Forced Induction 14 02-05-2014 08:23 AM
Forced induction for ATs? Lokutus Forced Induction 10 02-26-2013 03:42 PM
NOS or Forced Induction? v3rgil AFRICA 1 11-08-2012 07:17 AM
6AT (+) Forced Induction RYU Forced Induction 18 09-09-2012 11:14 PM
Forced Induction Primo86 Engine, Exhaust, Transmission 11 05-29-2012 07:50 PM
