#15 |
Drives: '07 350z
#16 |
Seems Legit
Drives: Toyota
We need a proper review of these
No build thread. I don't want to be reminded of how much money I spent.
[insert profound quote here] |
#18 |
Ridge Racerrrrrrrrr
#19 | |
Seems Legit
Drives: Toyota
There's there's this thread, the customer whose vehicle Thomas installed them on, with a few glamour shots. No video of them in use. No pics of the cutoff on the car against a wall at night. No night time shots. I'm looking for a bit more as are other perspective buyers.
#20 | |
Ridge Racerrrrrrrrr
#21 | |
Seems Legit
Drives: Toyota
#22 | |
Ridge Racerrrrrrrrr
| The Following User Says Thank You to SkAsphalt For This Useful Post: | boonFRS (05-01-2014) |
#23 |
So what is the final answer on needing the DRL mod or not?
#24 |
Seems Legit
Drives: Toyota
Updates
I received my Spec-D lights from UPS today. Thanks for the speedy shipping @fteightysix
So here's the low down. I have not installed mine yet but I did some bench testing. I'll post some pics momentarily. Wires: Headlamp harness (4 wires) Red (+12v), Red/Black (Ground) = These toggle the high beam actuator Blue (+12v), Blue/Black (Ground) = Positive trigger for the low beam headlight. Essentialy these turn the headlight on. Other 4 remaining wires. x2 Black (Ground) - x1 ground for the high beam actuator. x1 ground for the LED boomerang, turn signal and low beam headlight. Yellow (+12v) - Amber turn signal White (+12v) - LED boomerang Do you need a DRL mod? You DO NOT need a DRL mod for these lamps! Those with the FRS can essentially opt to NOT connect the yellow wire if you don't like the amber within the lamp, after all, you have turn signals in the lower bumper. For the FRS, if you want the boomerang to remain lit at all times as long as the headlights are on or the parking brake is dropped, you can wire them to the +12v in the turn signal harness. I'll verify which wire this is tomorrow when I complete the install. The LED boomerang color changes depending on what angle you look at it. I don't believe there is an HID kelvin temp perfect match. Once I complete the install with my D2S 5K HIDs i'll post more pics. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
[insert profound quote here] Last edited by ecko04; 04-17-2014 at 08:37 PM. |
| The Following 7 Users Say Thank You to ecko04 For This Useful Post: | 86SPEED (04-18-2014), Ammunition (04-17-2014), bobio64 (04-20-2014), Dadhawk (05-02-2014), DAEMANO (04-18-2014), kalamitykode (05-02-2014), STS-V (04-18-2014) |
#25 | |
Regional Moderator
Drives: 00-AP1 20-A90 06-Z33 07-FA5 93-NA1
#26 | |
Seems Legit
Drives: Toyota
I'll take some pics of where I tap for power with the wires that need to be connected. That should be enough to get you going.
#27 |
Seems Legit
Drives: Toyota
| The Following User Says Thank You to ecko04 For This Useful Post: | DAEMANO (04-17-2014) |
#28 | |
Thank you so much for this post. Basically I want the boomerang on whenever the ignition is on, with headlights on or off. Also, do you recommend a relay harness when using a D2S Hid kit? |
| Upgrading brakes on the lower spec GT86 (the standard spec outside of US market) | OnionTou | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 55 | 07-01-2016 01:36 AM |
| SPEC-D headlights Modellista body kit | laley81 | Southern California | 20 | 07-07-2014 09:14 PM |
| Trade FRS headlights for BRZ headlights? | Teknian_Culprate13 | Exterior Parts (Aero, Lighting, Etc.) | 10 | 07-14-2013 08:11 PM |
