Northwest AK, ID, OR, WA
Old 04-16-2014, 02:05 PM   #967
Jmonty
Realtor/ Principal Broker
Drives: JRSC BRZ GBS LTD 2010 LTD Outback
Originally Posted by DarrenDriven View Post
Friday late afternoon would be best. Text me when you are ready to get over here and I'll see if I can swing it.
Sounds good, I will confirm delivery of the springs it show Friday, lets hope morning so I can be on for the afternoon install
Jmonty is offline   Reply With Quote
Old 04-16-2014, 03:58 PM   #968
Chen
Regional Moderator
Chen's Avatar
Drives: 00-AP1 20-A90 06-Z33 07-FA5 93-NA1
Lmk when you go. I wanna get my car up on the lift to check out what's rumbling underneath.
Chen is offline   Reply With Quote
Old 04-16-2014, 07:36 PM   #969
Turbo95eg6
Turbo95eg6's Avatar
Drives: 2014 BRZ SWP LTD
Darren, would you guys be able to swap transmission/ rear diff fluid in the garage?
Old 04-17-2014, 12:15 AM   #970
DarrenDriven
NW Region Moderator
DarrenDriven's Avatar
Drives: FR-S No More
Yeah.... we need to schedule it when someone else isn't using the lift, though. When are you thinking?
Old 04-17-2014, 01:52 AM   #971
XanRules
A Very Powerful Wizard
XanRules's Avatar
Drives: 2014 BRZ LTD WRB (RIP), 2017 FiST
Hey pal,
Let me know when you've got time for a backup camera install
XanRules is offline   Reply With Quote
Old 04-17-2014, 10:24 AM   #972
Ris
Ris's Avatar
Drives: 2013 Whiteout FRS
Send a message via MSN to Ris
i'd def do this if i knew what days you had in mind
Ris is offline   Reply With Quote
Old 04-17-2014, 12:52 PM   #973
Turbo95eg6
Turbo95eg6's Avatar
No rush, maybe in a month or two I'll hit you up.
Old 04-17-2014, 01:50 PM   #974
DarrenDriven
NW Region Moderator
Originally Posted by XanRules View Post
Hey pal,
You thinkin this weekend? Maybe on Sunday during the day... text me Sunday morning when you get up.
Old 04-17-2014, 01:51 PM   #975
DarrenDriven
NW Region Moderator
It all comes down to when ppl can do it. What days work best for you @Rio and @sweetfrs?
Old 04-17-2014, 01:55 PM   #976
Rio
Rio's Avatar
Drives: 2014 Scion FR-S ハチ
I think you meant @Ris instead of me.
Rio is offline   Reply With Quote
Old 04-17-2014, 02:09 PM   #977
DarrenDriven
NW Region Moderator
OOPS! @Ris!
Old 04-17-2014, 04:39 PM   #978
XanRules
XanRules's Avatar
Sounds good.
Old 04-18-2014, 09:59 AM   #979
BRZPDX
Boosted Member
BRZPDX's Avatar
Drives: 2013 SWP BRZ Limited
Sportline springs are 90% for looks only on a budget. It rides and performs like shit imo. The stock struts were not designed for the shortened springs, and harder spring rates so it throws off the balance for grip cornering. The stock dampers/springs are pretty damn good, according to some very credible track drivers.
The buttdyno will suggest that it rides stiff, thus it must be cornering better. It will lower your CoG, so maybe better for drifting.
I have the Sportlines just to get rid of the fender gap, but any spring or sub $1k coil over setup will be a downgrade from the stock suspension system, pure performance wise.
You will get camber in the rear once its lowered, I have -2.1L -2.2R. There is a possibility that you might get "wacky" camber, where it does not even out in the rear, in that case you will need to get LCA's to fix the issue.
There will be camber wear with -2 in the rear.
The biggest improvement I felt handling wise, was adding camber in the front with camber bolts (-1.4). Sway bars will make a difference over tower bars (upper strut bars), and I always believed to stiffen up the suspension from ground up, not the other way around. Put some thoughts into sway bars, if you want over steer or under steer correction. This will change with spring rates/damper settings with your suspension so it should be one of the last things to touch.
Don't forget sway end links, the OEM ones will not hold after you stiffen up the sways.
Suspension work is very very difficult, more so than adding power. This is why I'm falling behind on this part of modding, add the power to satisfaction first, then upgrade suspension.
Suzuki Swift GTI '89, Subaru Impreza L '96, Lancer OZ '03, Subaru Impreza WRX '06, Honda CBR600RR Graffiti, Volvo c30 T5 R '11, Subaru BRZ '13, Audi RS4 2007
SUV's: Mercedes Benz R500 '06, Mercedes Benz ML350 '12
BRZPDX is offline   Reply With Quote
Old 04-18-2014, 08:00 PM   #980
Ris
Ris's Avatar
@DarrenDriven i work every other weekend and have this weekend off. soo may 2-4... 16-18.. and so on.
SoCal: any local shop to install springs jgonx213 Southern California 12 12-16-2013 02:20 PM
Coilover and Springs Install at Performance Shop F-T Mechanical Maintenance and Tools 22 12-12-2013 01:12 PM
WTB RCE spring or RS*R spring mounted on stock strut jshum Want-To-Buy Requests 1 10-11-2013 02:47 PM
Need to find a shop in Chico area for spring install Senzai Northern California 1 08-08-2013 05:59 PM
Garage FR-S at home or pay a shop/someone else? ProTekk Scion FR-S / Toyota 86 GT86 General Forum 34 10-30-2012 12:17 PM
