Old 04-16-2014, 05:12 PM   #4369
fenton
Originally Posted by Jac View Post
Stupid question, should I expect performance (more specifically the batteries) to be noticeably impacted by ambient temperatures? Took the car out for a few pulls (temp 40-45F) and it was certainly less peppy than the days before (55-65F).
Pretty sure the answer is yes, although I'm more curious by what margin performance would be impacted (10%/30%?).
The problem i have is when my temperatures get cooler (-20C to 0C) i cant get any traction anyways because it is usually accompanied by the white stuff.
fenton is offline   Reply With Quote
Old 04-16-2014, 05:13 PM   #4370
DAEMANO
Time Traveller
Originally Posted by Thatruth2001 View Post
Mentioned this approach to Rob a few months ago as an alternative prior to the controller redesign. Remember this adds more cost and complexity to the installation.
Indeed, posted as kind of a joke, but at the same time, kinda not.
Old 04-16-2014, 11:51 PM   #4371
silent runner
Drives: 93'Camry, 82'Corolla, 76' Celica
I note that out of the heated garage, on a very cold day, I can pull some truely crazy acceleraton (traction limited, due to cold pavement). Warm batteries, and cold air are the best combo. No surprise really. Wanted to put my summer tires on this weekend, but we had a forcast of snow coming over the next couple of days... it snowed.... Maybe this weekend?
I really want to see what I can hook-up with proper tires,... these snow tire things are great on snow, but cruddy everywhere else.
silent runner is offline   Reply With Quote
Old 04-17-2014, 11:31 AM   #4372
nlowell
nlowell's Avatar
Drives: 2013 Scion FRS
I've been thinking about the upcoming options and have questions for @Robftss -
1.) With the 1.x5 battery, what happens when the .5 depletes? Does it trip the protection?
2.) With the 1.5x and 2x battery options, does it take twice as long to recharge?
3.) This may be a stupid question but any way to configure the setup to switch between race and street mode where race mode would use one set of batteries until depleted then switch to the other set? In essence doubling the battery run time but only at the single pack power?
Thanks in advance!
nlowell is offline   Reply With Quote
Old 04-17-2014, 11:35 AM   #4373
robwbright
Drives: '13 BRZ Limited WRB Phantom ESC 1.5
Thanks in advance!
I'm no expert on this, but as far as I understand from reading this thread, the 1.5 and 2x battery pack options reduce the recharge time. I'll leave the other issues to the experts.
'13 BRZ Ltd MT WRB Phantom ESC 1.5
2012 Honda Accord Coupe
2006 Saab 9-3 2.0t
1997 Honda Accord Coupe
1995 Honda Prelude VTEC
robwbright is offline   Reply With Quote
Old 04-17-2014, 11:41 AM   #4374
fenton
1.) No. With the 1.x5 battery, what happens when the .5 depletes? Does it trip the protection?
Thanks in advance!
I can answer these for Rob.
1. No. With the 1.5 dump pack you get 50 percent more capacity. the original dump and the additional .5 sync up to act like one big battery. Because the individual mass of all the batteries is small they heat up quick and dump charge better than just getting a larger Amp Hour battery.
2. If you could deplete the 1.5 dump it would take longer to charge, same goes for the 2.0 but with the added capacity it gets harder and harder to deplete them on the street. The addition of the aux charger is very beneficial with the 1.5 and the 2.0 because not only do you have more capacity it also recharges at 4:1 instead of 8:1.
3. This would be very complicated as you would need a switching mechanism. In this case you are best to go to the dual dump and dual recharge.... that is going to be good for 99% of scenario's....Remember that this system is not meant to be always on. The track does not allow for the 4:1 recharge to fill the battery back up when not on the throttle.
Hope that helps
Old 04-17-2014, 11:42 AM   #4375
fenton
1.5 and 2.0 increase the battery capacity, you still have to fill them up when you use them.
They actually allow for more stable dump of current to the motor, increasing the effect PSI the compressor puts out as the voltage droop is much lower.
Old 04-17-2014, 12:02 PM   #4376
Urmyson
Any idea of pricing regarding the Aux charger and add pack for extra battery?
Urmyson is offline   Reply With Quote
Old 04-17-2014, 12:05 PM   #4377
robwbright
Makes sense. My bad. More battery capacity means it takes longer to deplete but still have to charge.
2006 Saab 9-3 2.0t
Old 04-17-2014, 12:07 PM   #4378
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
I went ahead and purchased the cooling mod materials. I ended up purchasing the following:
[ame="http://www.amazon.com/HPS-SSTC-76-84-76mm-Stainless-T-Bolt/dp/B0058W7X0A/ref=zg_bs_15710721_16"]Amazon.com: HPS (SSTC-76-84) 76mm - 84mm Stainless Steel T-Bolt Clamp for 2-3/4" Hose: Automotive[/ame]
[ame="http://www.amazon.com/Allstar-ALL42141-Single-Plastic-Cooling/dp/B006K8K8HG/ref=sr_1_1?ie=UTF8&qid=1397621501&sr=8-1&keywords=brake+duct"]Amazon.com: Allstar ALL42141 Black 5" x 9-3/4" Single Hole Offset Plastic Brake Cooling Duct: Automotive[/ame]
and last: [ame="http://www.amazon.com/Allstar-ALL42150-Black-Brake-Duct/dp/B006K8KBK0/ref=pd_bxgy_auto_text_y"]Amazon.com: Allstar ALL42150 Black 3" x 10' Brake Duct Hose: Automotive[/ame]
I actually don't need the full length of ducting so @nlowell and I are splitting the tubing.
It looks like its going to be fairly straightforward with little issues. I'll take pictures as I install the mod. And I will take surface temperatures of the controller before and after the mod.
We probably won't get definitive proof of concept until nlowell goes back on the track, but at least we will have some baseline.
I will also be receiving the 1.5 battery upgrade mod soon. I do not have the dual rechargers so I will just be testing with 8:1 recharging time which should not be an issue on the street. I'll be posting my impressions of that as soon as I receive all the parts, but I did already purchase the batteries.
Installed Mods:
Old 04-17-2014, 12:23 PM   #4379
fenton
I will query Rob and see if he knows the price targets for these two additions.
Old 04-17-2014, 12:41 PM   #4380
Robftss
Drives: VW
Thanks in advance!
Simply:
1.5 dump adds power by holding a higher voltage and a bit more current. It does not add to the duty cycle of the system. Recharge time will be similar since the boost event will be slightly shorter for the same acceleration. SLA's are self regulating so discharge and recharge is appropriate to the capacity.
Aux charger increases duty cycle...charge rate is ~5:1 ideal.
For track use, push to pass or KERS is possible.
For use, continuous , on a road course would require significantly more capacity and significantly more controller duty cycle....at that point I suggest the 5K + track upgrades mods needed conventional FI setup.
Realistic improvements will come along as this develops.
Thanks! Rob.
Robftss is offline   Reply With Quote
Old 04-17-2014, 04:46 PM   #4381
fenton
Holy mother of torque have you guys seen what the tq250 with a single dump does to a mx5?
Vishnu just tuned one... Imagine a 2300 pound car with this kind of torque curve!!!!
New saying should be "What can Phantom Sc and OFT do for you?"
A lot apparently.
Sent from my HTC One using Tapatalk
Old 04-17-2014, 04:48 PM   #4382
Luckrider
My Other Ride's a Jeep
Luckrider's Avatar
Drives: 2013 BRZ Limited
It doesn't impress me much. The MX5 is ~2550lbs according to Mazda's website.
Luckrider is offline   Reply With Quote
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras Circuit Motorsports Member's Car Journals 4 03-21-2013 04:45 PM
Subaru BRZ : Full Throttle, powerslide, hard revving & ride ESBjiujitsu BRZ Photos, Videos, Wallpapers, Gallery Forum 20 05-30-2012 06:43 PM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 07:07 AM
