#4369 | |
Grip>Slip
@DeliciousTuning - please correct me if i'm wrong. |
#4370 | |
Drives: Scion FR-S/Toyota Yaris
That's what I meant Delicious did the carb as far as I know, and they made a lot of discoveries to make it reliabale, That's what I heard. Ditto if I'm wrong.
2013 FRS Argento Silver 6MT
Mods: Clear fender side lights Tactrix ZA1JB01C 2014 Calib |
| The Following User Says Thank You to regal For This Useful Post: | DeliciousTuning (04-17-2014) |
#4371 |
Grip>Slip
Yeah, he made their carb tune. He also sells tunes that are more customized if you want to go that route (definitely worth the money, imho.)
| The Following User Says Thank You to xjohnx For This Useful Post: | DeliciousTuning (04-17-2014) |
#4372 | |
Drives: 2013 SWP BRZ
I think he was moving into his new shop this week. Anyway, he knows its not an excuse and he has to attend to his customers, but you are correct, hes not superman. |
| The Following 3 Users Say Thank You to xxscaxx For This Useful Post: |
#4373 | ||
Well you sir are ourspie, let us know what his plans are, I've got 14 months till warranty is up ![]() Quote:
Depends on what you want, I heard the carb tune can take more abuse than the factory tune, that's what you want for a daily with track days imho.
| The Following User Says Thank You to regal For This Useful Post: | xxscaxx (04-16-2014) |
#4374 |
Grip>Slip
meh, the carb tune is a cookie cutter boxed tune with no adjustments (by definition of being a carb tune, it can't be changed without going through another round of approval in California). I tend to think a tune that has gone through proper review/revision process will be more desirable, (especially when you consider that Bill will take your use case into account when creating that custom tune for you and can dial it back to be as safe as you so desire), but to each his own.
#4375 | ||
The problem with the tuner kits is your whole engine is reliant one one guy. If its Bill your in good hands, but beyond that I find it risky the quest for that extra 10 hp with limited dyno time, limited budget just gets risky imho. When it comes to teams who have tuners on the staff many end up with less hp than stock, they go for longevity and broad torque band (at the expense of emissions), surprisingly that's what we want in a daily. I hope a track tune like that is developed in the open source world for the innovate in a few years (wishful thinking.) Changing subject a tad I thought buy now the only pos disp blower would be the goto kit for these cars, what's holding it back? Did ther undersize the blower, Vortech made that mistake at the beginning, the high compression ratio is beyond the typical charts used to match a blower to an engine. Then there's the $700 for the Ecuteck surcharge. I'm interested to see whats on the table in a couple years. Certainly won't bee near as many pulley driven turbos on the market.
#4376 | |
Mr. Cranky Pants
Drives: 2013 Argento FR-S
#4377 | |
PhoneFlash by EcuTeK
Cheers, William Knose Delicious Tuning |
#4378 | |
Please be patient. Thank You, William Knose Delicious Tuning |
#4379 | |
Grip>Slip
#4380 | |
Non-Intercooled on Pump Gas Response The non-intercooled kit is good on the 75mm pulley but nothing smaller on standard pump gas. If you go with a smaller pulley the tune needs to pull out so much timing (due to the heat) that it basically makes it a gutless car and sort of pointless to drive. Because of this I am highly against offering tunes on non-intercooled kits with pulleys smaller then 75mm on standard pump gas. Now if you are running E85 daily then that is a different story but usually people running E85 are doing so with FlexFuel and more than likely using a smaller pulley. If so I would then recommend still running the intercooler so as to have the ability to run standard pump gas with your smaller pulley. The intercooler helps a lot more than people may think. We did a LOT of testing with Innovate on it and found it to have more benefits then drawbacks. Cheers, William Knose Delicious Tuning |
| The Following User Says Thank You to DeliciousTuning For This Useful Post: | TemeCal (04-17-2014) |
#4381 |
#4382 | |
Anyway the 8.54 should address most all the issues in the tune people are speaking about. There will be a new support hierarchy coming very soon. Standard Intercooled Setups - Standard Pump Fuels with 75mm pulleys - FlexFuel or E85 with 75mm pulleys Standard Non-Intercooled Setups - Standard Pump Fuels with 75mm pulley - FlexFuel or E85 with 75mm pulley Custom Intercooler Setups - Standard Pump Fuels with pulleys smaller then 75mm - FlexFuel or E85 with pulleys smaller than 75mm Custom Non-Intercooled Setups - Standard Pump Fuels with pulleys smaller than 75mm - FlexFuel or E85 with pulleys smaller than 75mm Also please note I currently have been offering these standard updates and even custom updates at no charge to anyone. I spend a lot of time developing updates for everyone so we can enjoy these packages as if they were a stock vehicle, so please understand this take my time to do this and it is a fair amount of time to update a custom tune, usually about 30-60 minutes each, especially with major updates like this one. Cheers, William Knose Delicious Tuning |
| Innovative ideas to increase interior storage capacity? | swift996 | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 01-30-2013 10:45 PM |
| AVO vs Innovative | diss7 | Forced Induction | 32 | 01-21-2013 06:15 PM |
| Not another need to drive topic | Sargy | Mid-Atlantic | 5 | 11-27-2012 12:18 PM |
| Technical topic sub-forums | OrbitalEllipses | Site Announcements / Questions / Issues | 1 | 07-17-2012 11:38 PM |
| Can you close the topic please? | Standardsuspension | Brakes, Suspension, Chassis | 14 | 06-26-2012 05:14 PM |
