Old 04-10-2014, 05:53 PM   #617
CSG Mike
CSG Mike's Avatar
Originally Posted by fooddude View Post
Woah...sounds very dangerous indeed.
Starting to hate these electronic aids the more and more I read about them, lol.
Hopefully someday soon, someone will make a device or tune that will completely and permanently disable all aids, tc, vsc, ice mode, etc...leaving you with a fully analog rwd drivetrain (sans abs).
It won't kick in under normal circumstances.
I can only make it happen if I'm going out of my way to force it
Old 04-10-2014, 06:52 PM   #618
dradernh
Drives: Used to Drive:Grand-Am GS #54 E36M3
This unit has some, and maybe all, of that functionality: http://www.motec.com/m1package-86/m1package-86overview/
Datasheet: http://www.motec.com/filedownload.ph...pdf?docid=4502
dradernh is offline   Reply With Quote
Old 04-10-2014, 07:06 PM   #619
leicaboss
Coffee Snob
leicaboss's Avatar
Drives: '14 SWP BRZ Limited
Originally Posted by dradernh View Post
Holy price batman!
leicaboss is offline   Reply With Quote
Old 04-10-2014, 09:45 PM   #620
dradernh
Originally Posted by leicaboss View Post
Holy price batman!
What're ya talkin about - that's not even a month's rent in your zipcode!
Seriously, that's just another razor; it's the blades that kill ya.
Old 04-10-2014, 10:14 PM   #621
u/Josh
Drives: GBS Limited 6MT
Was great seeing you out there Josh!
Which corner was it? I got it in turn 11(?) last 180 before the pit exit and start/finish.
The sweeping right, two turns before the main straight.
It's weird I never felt the car braking the rear wheel, but I'll try the pedal dance next time.
u/Josh is offline   Reply With Quote
Old 04-16-2014, 12:28 PM   #622
I<3Twisties
I<3Twisties's Avatar
Drives: SUBARWD
Hey mike, I have a set of 17x7.5 wheels on stock suspension. Should I be using 215/45 or 225/45 tires on track?
I<3Twisties is offline   Reply With Quote
Old 04-16-2014, 12:40 PM   #623
AZP Installs
AZP Installs's Avatar
Drives: '11 STi->'14 BRZ | '14 Touareg TDi
Send a message via AIM to AZP Installs
I would say 225 but it also depends on what tires you are using.
Mike
AZP Installs is offline   Reply With Quote
Old 04-16-2014, 12:43 PM   #624
I<3Twisties
Drives: SUBARWD
I've been running Bridgestone s04's.
Old 04-16-2014, 01:00 PM   #625
CSG Mike
CSG Mike's Avatar
I'd stick to 215 regardless of model.
Old 04-16-2014, 01:20 PM   #626
BRZZZZZZZZZZ
Car Nut
BRZZZZZZZZZZ's Avatar
Drives: BMW 335d, Toyota Echo RS, FRS
How long can I expect my stock pads to last for lapping? (I know this is a pretty generic question) Stock power only wheel tire and suspension mods.
BRZZZZZZZZZZ is offline   Reply With Quote
Old 04-16-2014, 01:23 PM   #627
CSG Mike
CSG Mike's Avatar
100% dependent on you and your experience.
For me, they would fade in about 3-5 turn depending on the track, and be completely destroyed in a few laps.
I REALLY don't recommend you even attempt to track on stock pads and fluid.
Old 04-16-2014, 01:24 PM   #628
BRZZZZZZZZZZ
Car Nut
Damn I don't really think ill be able to get pads by the time the day comes. I have fluid already.
Old 04-16-2014, 01:39 PM   #629
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
IMHO a 7.5" rim will accommodate a 225 splendidly. However look at specs on the rolling diameter between a 215/45 and 225/45. You might find the rolling diameter changes and thus may want to opt for a 225/40.
PRO86 | WTCC | STL
Old 04-16-2014, 01:46 PM   #630
rice_classic
3-4 laps with aids turned on. Maybe 6-7 laps with them turned off before fade. Figures will vary depending on temperature of day and braking requirements of track. With stickier tires and better suspension.. maybe less. The OEM brakes are pretty good, the OEM pads are absolutely not but that's usually the norm for any car.
Also the OEM pad material has a high wear rate at those temps. I've done very lapping in my unmodified FRS but I had to replace my front pads at 20k miles. Needless to say I didn't buy another set of OEM pads, but an aftermarket OEM-ish ceramic pad.
PRO86 | WTCC | STL
Simple question, hard to find answer... Mango22 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 05-16-2013 06:23 PM
Silly question about protecting track rims sw20kosh Tracking / Autocross / HPDE / Drifting 16 04-25-2013 12:34 PM
Asking the question that I already know the answer to. Are the engines the same? Bigmaxy Engine, Exhaust, Transmission 10 01-19-2013 07:47 PM
Random dog-related question for those who have their BRZ GMU-BRZ BRZ First-Gen (2012+) — General Topics 11 05-31-2012 07:48 AM
Got my answer - BRZ comes with HID headlights as STD Z_Rocks BRZ First-Gen (2012+) — General Topics 20 01-10-2012 09:54 AM
