#617 | |
I can only make it happen if I'm going out of my way to force it |
#618 | |
Drives: Used to Drive:Grand-Am GS #54 E36M3
Datasheet: http://www.motec.com/filedownload.ph...pdf?docid=4502 |
#619 | |
Coffee Snob
Drives: '14 SWP BRZ Limited
#620 |
#621 | |
Drives: GBS Limited 6MT
It's weird I never felt the car braking the rear wheel, but I'll try the pedal dance next time. |
#622 |
Drives: SUBARWD
Hey mike, I have a set of 17x7.5 wheels on stock suspension. Should I be using 215/45 or 225/45 tires on track?
#623 |
#624 |
Drives: SUBARWD
I've been running Bridgestone s04's.
#625 |
#626 |
Car Nut
Drives: BMW 335d, Toyota Echo RS, FRS
How long can I expect my stock pads to last for lapping? (I know this is a pretty generic question) Stock power only wheel tire and suspension mods.
#627 | |
For me, they would fade in about 3-5 turn depending on the track, and be completely destroyed in a few laps. I REALLY don't recommend you even attempt to track on stock pads and fluid. |
#628 |
Car Nut
Damn I don't really think ill be able to get pads by the time the day comes. I have fluid already.
#629 |
Drives: Nevermorange FRS
IMHO a 7.5" rim will accommodate a 225 splendidly. However look at specs on the rolling diameter between a 215/45 and 225/45. You might find the rolling diameter changes and thus may want to opt for a 225/40.
PRO86 | WTCC | STL
#630 | |
Also the OEM pad material has a high wear rate at those temps. I've done very lapping in my unmodified FRS but I had to replace my front pads at 20k miles. Needless to say I didn't buy another set of OEM pads, but an aftermarket OEM-ish ceramic pad.
PRO86 | WTCC | STL
| Simple question, hard to find answer... | Mango22 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 05-16-2013 06:23 PM |
| Silly question about protecting track rims | sw20kosh | Tracking / Autocross / HPDE / Drifting | 16 | 04-25-2013 12:34 PM |
| Asking the question that I already know the answer to. Are the engines the same? | Bigmaxy | Engine, Exhaust, Transmission | 10 | 01-19-2013 07:47 PM |
| Random dog-related question for those who have their BRZ | GMU-BRZ | BRZ First-Gen (2012+) — General Topics | 11 | 05-31-2012 07:48 AM |
| Got my answer - BRZ comes with HID headlights as STD | Z_Rocks | BRZ First-Gen (2012+) — General Topics | 20 | 01-10-2012 09:54 AM |
