#295 | |
![]() humfrz |
| The Following User Says Thank You to humfrz For This Useful Post: | SirBrass (04-16-2014) |
#296 | |
Trust me, I'm the Doctor
On phone I am. Therefore, if mistakes I make, Frank Oz blame you should.
Daily Driver: 2014 BRZ 6MT Limited ^GT5 Replay Photo Mode^ |
| The Following User Says Thank You to SirBrass For This Useful Post: | dnieves (04-16-2014) |
#297 | |
| The Following User Says Thank You to SirBrass For This Useful Post: | humfrz (04-16-2014) |
#298 |
Drives: FR-S 10 Series
I'm all for making issues known to get them remedied but a class action lawsuit about the crickets results in the lawyers getting rich, bad publicity for the car, and we get a $10 coupon to shut us up.
Not exactly a worthwhile proposition. Last edited by dnieves; 04-16-2014 at 06:38 AM. |
| The Following User Says Thank You to dnieves For This Useful Post: | SirBrass (04-16-2014) |
#299 |
Drives: 2016 WRX, 2016 Corvette Z51 3LT
I'm basing this on the stories of "I'm on my third fuel pump, car was in the shop for 15 days" etc
Those of you who still think I'm a troll (1) I went to the dealer to BUY this car. When it made the tick tick tick sound, LOUD, I didn't buy it (2) I LOVE the FRS. It is way better than the Camaro and Mustang (3) I will buy an FRS in a few years once the "quirks" are under control I'm hoping I will have fewer issues with the Camaro. We already had issues with the Challenger (ECU replaced), so I'm not under the illusion that new cars are without issues. The Camaro has been out since 2010 so issues should be under control. |
#300 |
So the crickets should be a class action lawsuit, but you would happily buy a car from GM.... Perhaps you have not read up on the ignition issues at GM recently that resulted in many deaths. One poor girl brought her car to them three times and they told her nothing was wrong. She is now dead. All for a part GM knew was faulty and cost less than $1 to manufacture.
| The Following User Says Thank You to thill For This Useful Post: | SirBrass (04-16-2014) |
#301 | |
Drives: 2013 red FR-S, OFT. 2000 Miata SE
John |
#302 | |
Drives: 2006 Cayman S, 2007 Outback 2.5i
#303 | |
Drives: '13 FRS - STX
The way Toyobaru are treating it, these 'quirks' will not be solved as long as the car utilizes Toyota's D4-S injection system. They've already been on the road for nearly 2 years at this point. |
| The Following User Says Thank You to strat61caster For This Useful Post: | SirBrass (04-16-2014) |
#304 | |
Welcome to direct injection & federally mandated E10 gas. Don't like the sound, don't get a DI motor. But there's no unhealthy sounds in those motors or overly annoying chirps. The real cricket issue does crop up, where the cricket chirps are quite louder, but in those much rarer instances they can clearly be heard in the cabin at idle with radio on & hood down. But, again, those are rarer instances & still not an actual reliability issue. These aren't going to sound like port injection only v6's or the grumbling marble sound of a 5.0L v8, or the whispering wussiness of an ecobox's low compression inline 4. The high compression & DI are going to make an engine sound akin to a singer sewing machine. It's not what you're used to, but it's still a healthy sound. And with the hood down, in the cabin you can't hear the very quiet chirping of the high pressure fuel pump. You're basically going bonkers over absolutely nothing. So instead yo settle for a car you know you (by your own admission) won't enjoy nearly as much (if at all) and which has actual very serious potential failure issues. Yet you did so b/c you didn't like this very minor, very normal sound from a di hpfp & believed the chicken Littles who call the rarer loud hpfp chirps a reliability problem. Riiiiiiiiiight. We'd be way more chill if you'd said something like "cool car, but I simply want more power" or "I'm just into bigger cars" or something preference-based. Those are fine. We all have our tastes & preferences, but to come in here, praise the car for what it is, say you love it, but walk away citing reliability & how the (very quiet) chirps are simply "not right" (when they are)... Well, that's just being disingenuous in some of our eyes. On phone I am. Therefore, if mistakes I make, Frank Oz blame you should.
#305 |
Drives: Scion FR-S/Toyota Yaris
I owned a mechanical direct injected diesel '85 Golf, you think our engines idle load you haven't hear real direct injection.
Direct injction is a great thing, it saves gas and gets the most power out of the gas. To me that noise is a non-issue, I could care less about crickets are ticking its the nature of the tech. What is possibly bother some is the VVT noise under load around 5k. This engine is supposed to a "classic" rev happy N/A engine, yet it is far from it. The noises in the powerband )over 5k) IMHO are alrming. The interview with the Avo engineer posted in Dezoris's thread is what needs to be figured out not cricket. IMHO crickets means there is some mechanical wear, how much? No one knows for sure but it must be minmal as many higher milage cars are growing. A pump is easy to replace and not expensive. Only real concern is this engine is a one-off not being used in any other car and that can lead to ridiculous prices for simple parts. My concern has always been the power band, vvt noise, breaking camshafts, and the DI seal. My gut is that the DI seal and VVT are both people tuning who are still learning this complex engine control, however my stock FRS has the VVT noise (I am however stuck on a 2012 factory tune.) The interview with the Avo engineer is a bit scary, he tells us this is Subaru's 3rd attempt at VVT and there are situations where the VVT can starve the shortblock. That's what this forum needs to be concerned with, not crickets. Avo probably knows more about the FA20 than about anyone outside of Subaru. JMHO. Its ashame this engine when revved doesn't give a confidence inspiring feeling like the 2zz or F20c. Yes I know that's totally subjective, but there is a 2-stroke chain saw feeling to it over 5-6k rpm. Luckily the headgaskets seem to be lasting which is a miracle for modern Subaru's. Hope folks are wrong about all of this and these engine prove as bullet proof as the good ole' subby 2.2L/ As far as the 2nd gear issue in cold weather, it got down to 0F here this winter and I had know issues at all. I need to change the fluid and have Motul but I'm considering staying stock. Is it possible folks just aren't used to driving a precise manual gear box?
2013 FRS Argento Silver 6MT
Mods: Clear fender side lights Tactrix ZA1JB01C 2014 Calib |
#306 |
You're not helping, regal. Your concerns have been addressed. What you're hearing there is the cam profile changing on the intake side. Normal sounds of the engine breathing better. DI seals were not a problem, the transient knock was the issue & that's been fixed.
You're raving about nothing (again). On phone I am. Therefore, if mistakes I make, Frank Oz blame you should.
#307 |
Drives: small
Interesting, I had no idea people were mistakenly classifying the sewing machine sound as crickets till now. No wonder some of them keep changing pumps to no avail. That's like taking a suppository for a headache.
#308 | |
DI seals, axles breaking with modified suspension, oil starved motors and the cam sensor seems to still pop up every once and awhile. Good thing they didn't turn on the A/C during the test drive, the idle hunting would have been a huge turnoff as well. Helping is subjective, agreed that regal is probably the foremost chicken little but if an internet post turns you off a car that in the grand scheme of things has been pretty reliable it's probably a good thing. I know I wouldn't be happy with a car I worried about everytime I drove it regardless of reality. |
| Tags |
| camaro vs crickets, pushrodslol, trollmageddon, where's my popcorn |
| OEM lug nuts | Kamran | Wheels and Tires | 1 | 09-28-2013 06:31 PM |
| Lug Nuts | Overland'n'5thGEN | Northern California | 9 | 07-22-2013 04:16 PM |
| Lug Nuts BRZ | loogs | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 2 | 07-16-2013 11:09 PM |
| Lug nuts? | Ludacrits | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 5 | 06-24-2013 10:13 AM |
| Lug Nuts? | Reflex | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 10-21-2012 07:38 PM |
