CANADA Canada
Old 04-14-2014, 06:00 PM   #3403
UMB FR-S
UMB FR-S's Avatar
Drives: Ultramarine Blue FR-S
Originally Posted by Slick View Post
from an instructor school yesterday...
Something odd about lapping with snow on the shoulders haha
Sent from my HTC One using Tapatalk
-- Kenny
"I don't always use heel/toe, but when I do it's because racecar."
UMB FR-S is offline   Reply With Quote
Old 04-14-2014, 08:14 PM   #3404
OrangeGuitar
OrangeGuitar's Avatar
Drives: '17 BRZ Dark Grey Sport-tech 6MT
That's better
Originally Posted by OrangeGuitar View Post
Trac and ABS lights turn on and stay on when the brake pedal is first pushed - Cruise Control will not turn on. Brake lights do not come on at all - makes it fun for whoever is following. STOP fuse is fine. Guessing a wheel sensor or brake switch.
FYI: Had the brake switch replaced. It was stuck in so the car shut down nannies completely and brake lights would not work. 'Fixed' with a smack on the side for short term and replaced today.
Ran into Josh from Trackwerks just picking up a brand new STI to trick out.
He mentioned a show day at Trackwerks April 27 and amateur night at Calabogie June 6.
OrangeGuitar is offline   Reply With Quote
Old 04-14-2014, 08:51 PM   #3405
CarGuy
Track Rat
CarGuy's Avatar
Drives: '14 Subaru BRZ
LOL! That's me missing apexes in my instructor student's STI hatch. It's his job to teach me the track and my job to make it hard on him.
I had the BRZ out on the track at 5/10th in the morning when the track was still wet. I LOVE MY BRZ!!!! Even at low speed I can tell I'll be having a ton of fun driving it this season!
If you're not interested in track stuff you can leave this post with dignity now.
If you're still here, welcome to my addiction. You can follow on the video with my attempt at describing the experience below. Hope you enjoy it!
The new DDT track is loads of fun and flows much better. However, it is still challenging and very technical. Also, don't let the wider pavement fool you because some exits in the new corners are narrow if you don't apex properly or if you carry too much speed. Turn 1 is the first corner off the front straight, turn 2 is the oval turn and so on.
Turn 1-2:
At the end of the front straight you'll need to brake but not too hard as the turn 1 right hander will be fast with plenty of corner exit. Just watch out for the blend line - look at the old/new pavement line in the video as this is about where the blend line will be. So starters should take note that if a driver apexes too early they might end up crossing the blend line so releases will have to be well timed. The banking on the oval is just runoff space. At the exit of the old oval (just after late 3/4 apex) the banking actually goes from "banked toward the apex" to off-camber or "banked away from the apex". It's a weird sensation because a small rise in the pavement gives us a nice blind exit reminiscent of turn 6-7 Big Rock-Candy Mountain at Calabogie; except the track continues straight instead of turning left.
Turns 3-4-5 and 6-7:
The next corner complex 3-4-5 is a triple apex that requires hard braking and a mid apex in the first corner, then track wide under hard acceleration, sacrifice the corner two apex and late apex the third corner so the car runs parallel to track right. The next left hander (turn 6) requires some braking and a late apex. If you apex too early the exit here is very narrow. If you hit the apex correctly the left hand sweeper (turn 7) can be taken at high speed and apexed late turning it into a double apex with a smooth arc.
Turns 8-9:
Lighter braking is required after the straight as the turn 8 left hander is deceptively fast. Exit this one under hard acceleration and head toward the next apex at turn 9 tracing yet another smooth arc double-apex. This takes you onto the old part of the track where the portable classroom used to be. The rest of the corners (turns 10-11-12-13) are as before only on a wider track until the back straight. This part of the track feels exactly the same a before.
Turns 14-15 and 16, 17:
Turn 14 enters the back straight and flows really well because the sharp angle has been removed and the wider track in the straight provides plenty of exit space. If you thought the back straight was short before it will be even shorter because of higher speed now. In turn 15 at the end of the back straight some cars will be able to simply lift and turn into a very fast corner going uphill. The kink on the exit of turn 15 is now gone and as a result uphill speeds will be much higher than on the old track. That speed will have you using all the track in turns 16 and 17 going uphill.
Turns 18-19-20:
Since there was no curbing installed we couldn't use "all" the track. Therefore the chicane (18-19-20) onto the front straight cannot be straightened out. I'm hoping that curbing will change that. I settled on apexing at the mid point or slightly late at every apex but could not see much difference in exit speed.
So that's my brain dump of the new DDT. It's well worth the trip for a lapping day.
CarGuy
'12 BMW 128i (daily driver)
'14 Subaru BRZ (track car)
Racing is life. Anything before or after is just waiting. - Steve McQueen
CarGuy is offline   Reply With Quote
Old 04-14-2014, 11:24 PM   #3406
CarGuy
Track Rat
CarGuy's Avatar
Here's a video of the new DDT at speed in a Lancer Ralliart (non-turbo).
[ame="https://www.youtube.com/watch?v=D-lvDBEW7ms&sns=fb"]Lapping the new DDT on the RE11A tires. - YouTube[/ame]
CarGuy
Old 04-15-2014, 02:19 AM   #3407
SciOnDrifTtSlIdeR
Drifter
Send a message via MSN to SciOnDrifTtSlIdeR
hey guys and possibly gals? just wondering who's hitting um MNM's Friday i have the day off thinking of cruising down?
SciOnDrifTtSlIdeR is offline   Reply With Quote
Old 04-15-2014, 02:33 AM   #3408
AznKirby
Are you 20/20?
AznKirby's Avatar
Drives: Hopes and dreams
All the way from Cornwall? How far is that?
2014 FR-S Monogram
2005 Acura RSX Type-S
IG: @MonKehC
Old 04-15-2014, 03:04 AM   #3409
SciOnDrifTtSlIdeR
Drifter
cornwall is dead center of ottawa and montreal
Old 04-15-2014, 07:01 AM   #3410
Pbrown
Drives: 2013 Scion FRS Raven
I'll be there
Pbrown is offline   Reply With Quote
Old 04-15-2014, 09:59 AM   #3411
Slick
Slick's Avatar
Drives: FR-S Firestorm 6MT
I'm a maybe, have parents coming to town to visit this weekend and we're doing a big dinner on Friday.
Summer tires and wheels are already on, hopefully no issues today getting home. I have a bit less tread on the tires than I expected.
Oh and since everyone has been modding, Open Flash Combo has been ordered too. Gotta keep up with the Jones'....
Slick is offline   Reply With Quote
Old 04-15-2014, 11:29 AM   #3412
FRSToyota86
FRSToyota86's Avatar
From what I have learned from fellow forum members @UMB FR-S and @Pbrown, castles headers and tune makes a for wise mod. I wonder if it would also make a noticeable power increase with the stock exhaust ? What budget brands should I look at for the biggest bang for the money? How much power increase should I expect?
Thanks in advance. Cheers
FRSToyota86 is offline   Reply With Quote
Old 04-15-2014, 11:34 AM   #3413
Pbrown
OFT & OFH
Oh and since everyone has been modding, Open Flash Combo has been ordered too. Gotta keep up with the Jones'....[/QUOTE]
I 'm in the same boat on the tire front today. Could be interesting. Are you planning on installing the OFT a little before the header. The reason why I am asking is I would love the opportunity to hear that noise at 4 K. It's the only thing keeping me from buying it. Won't be doing the header until next year. Perhaps we can meet for lunch or I'll drive out to your house after work. Let me know. Oh Yeah. Congrats on the purchase. Should be awesome.
Old 04-15-2014, 11:36 AM   #3414
FRS_Ken
((•||=(86)=||•))
FRS_Ken's Avatar
Drives: '13 FR-S Ultramarine 6AT; '13 Yaris
I'll be there
Cusco Suspension Braces | Eibach F & R sway bars | aFe/Takeda Intake | GReddy EVO3 | D2 RS Sport Coil-overs | TSW Interlagos | Centric Front Discs | Hawk HP+ (F) / HPS (R) | Goodrich SS brake lines | TSW & OZ Racing wheels | Continental & Hankook tires | JDP CF Front Lip | Rexspeed CF ground-effects kit | APR CF parts | Winjet headlights & fog lights | Valenti Smoked Reverse | TOM's LED taillights | CF interior upgrades | LED upgrades | and much more
FRS_Ken is offline   Reply With Quote
Old 04-15-2014, 11:51 AM   #3415
Slick
Slick's Avatar
I 'm in the same boat on the tire front today. Could be interesting. Are you planning on installing the OFT a little before the header. The reason why I am asking is I would love the opportunity to hear that noise at 4 K. It's the only thing keeping me from buying it. Won't be doing the header until next year. Perhaps we can meet for lunch or I'll drive out to your house after work. Let me know. Oh Yeah. Congrats on the purchase. Should be awesome.[/QUOTE]
Yeah, will install the OFT tune as soon as I get it. Header is probably 4-6 weeks away.
We could do lunch, I visit the A&W on Hawthorne frequently.
Old 04-15-2014, 12:20 PM   #3416
Pbrown
Sounds good
We could do lunch, I visit the A&W on Hawthorne frequently.[/QUOTE]
Ah yes A&W. One of my favs. I think you go there because the store manager owns the Genesis and you kind of want to rub it in a little. Let me know.
