Old 04-14-2014, 08:38 PM   #141
Deathalo
Drives: 2013 WR Blue Limited Manual BRZ
Originally Posted by DC2R View Post
You could just buy obd2 extension ribbon flat cable from Amazon and pout module wherever
Sent from my GT-N5110 using Tapatalk
For me, it's more that their OBD connector costs twice as much as one from Amazon =/
Deathalo is offline   Reply With Quote
Old 04-14-2014, 09:30 PM   #142
chimmy
Because BOXER
chimmy's Avatar
Drives: Asphalt FR-S
Is there an overall equalizer? As in front/rear/left/right?
Edit
Oh nm. Found it.
chimmy is offline   Reply With Quote
Old 04-14-2014, 09:43 PM   #143
xjohnx
Grip>Slip
xjohnx's Avatar
got it installed, sounds great. i'll provide more thoughts after i've had some time to get to play with it.
Old 04-14-2014, 10:54 PM   #144
SHIFTER
SHIFTER's Avatar
Drives: Scion FR-S
Cool! did the ipod connector work? If not - you'll need to swap those pins around (#13 and #14)
Andrew
2013 Scion FR-S MT (Silver)
2011 Toyota Rav4 Sport V6 4wd (Silver)
SHIFTER is offline   Reply With Quote
The Following User Says Thank You to SHIFTER For This Useful Post:
j2digit (07-21-2014)
Old 04-14-2014, 11:35 PM   #145
ir1064
Drives: 6MT, C7P
I'm going to assume they used grey instead of the violet.
mine also has gray and blue wire and swapping the wire solved my iPod problem, the one that you have is the correct pin position.
does anyone one know how to change the default music app (from default home screen) for Mirco SD, USB and iPod, the little complain i have is the build in default music player doesn't support "playlist", and iPod doesn't show album art and also confirm with Ca-Fi that bluetooth module doesn't support mp3 tag too, i'm little surprise....
ir1064 is offline   Reply With Quote
Old 04-14-2014, 11:49 PM   #146
Stormalong
Drives: Firestorm FR-S AT
For those asking, 3rd party OBD adapters do work. I have one of the super mini bluetooth ELM 327 thingies from Amazon, it works fine. I recommend it in fact. I have one of the full size ones (like Ca-fi sells), but I think it protrudes too much (due to the OBD port location on the FRS) and there is a danger of hitting it with your leg and maybe damaging it. With the mini one you can't even tell its there unless you stick your head under the dash.
My Dashlinq4 arrived today and I installed it this evening.
Stormalong is offline   Reply With Quote
The Following 2 Users Say Thank You to Stormalong For This Useful Post:
Deathalo (04-15-2014), Prog (04-15-2014)
Old 04-15-2014, 12:47 AM   #147
chimmy
Because BOXER
chimmy's Avatar
Originally Posted by SHIFTER View Post
GPS is whatever you want to run - its an android device. Google Maps, Tom Tom, Waze, Sygic... whatever. They all work.
Navigation is something I haven't tinkered with yet. But downloading one of these apps and using it as my Navi, wouldn't that just be using my phone hotspot, and therefore more data, instead of the GPS antenna?
Old 04-15-2014, 01:17 AM   #148
DC2R
Drives: 2014 Scion FR-S
Cable was less than $10 iirc.
Sent from my SM-N900T using Tapatalk
DC2R is offline   Reply With Quote
Old 04-15-2014, 07:23 AM   #149
xjohnx
Grip>Slip
xjohnx's Avatar
Would be interested in this, as well as alternatives to the radio app. mine seemed to jump channels on its own on the way to work this morning, not sure what's up with that. I'll play around with it more tonight.
Old 04-15-2014, 08:38 AM   #150
Deathalo
Use Sygic maps and nav from the playstore if you don't want to use data. There are some other paid options as well.
The Following User Says Thank You to Deathalo For This Useful Post:
chimmy (04-15-2014)
Old 04-15-2014, 08:45 AM   #151
Prog
Prog's Avatar
Drives: 2016 Cadillac CTS
How long did they take to ship for you guys? I still haven't gotten a shipping notification. I know their site says up to 2 weeks before it even goes out, but it seems like you guys are getting it faster than that.
Prog is offline   Reply With Quote
Old 04-15-2014, 09:36 AM   #152
AtlasMick
Drives: FR-S 2013 Asphalt
Does it have auto switching to rearview camera when you put it in reverse?
Does it have any optical or digital audio outputs?
AtlasMick is offline   Reply With Quote
Old 04-15-2014, 09:46 AM   #153
Prog
Prog's Avatar
Oh hey, I just realized I never got an answer to this question - how does the unit work with your phone? Can you accept calls over bluetooth easily?
Old 04-15-2014, 09:50 AM   #154
DC2R
Also interested in this. One thing the bespoke has going for it is Bluetooth -solid performance, solid connection, graceful auto pausing/resuming of all media when a call comes in.
REVIEW: Ca-Fi Toyota Universal - Stock Fitment ANDROID Stereo SHIFTER Electronics | Audio | NAV | Infotainment 16 06-13-2017 06:23 PM
Android, bluetooth, Music, and the FR-S stock pioneer stereo JayNutter Electronics | Audio | NAV | Infotainment 27 12-18-2014 03:54 AM
How to: Torque on an android powered stereo with no hacking v. Ca-Fi Dashlinq4 SHIFTER Electronics | Audio | NAV | Infotainment 29 04-07-2014 04:58 AM
