#43 |
Drives: SWP BRZ Limited MT
I believe in this thread, there are different users talking about different things...
If you experience the "engine dying" "bogging/rattling", just try and maintain 1500RPM at 3rd - 6th gear to reproduce it. You'll feel the car struggling, and I believe this is quite normal for this car, it likes high revs that's for sure. If you hear metal "clicking", it might be the metal piece on the shift knob or just the frame holding the nav/radio or even the volume knob. Try holding onto them when you hear it and see if it goes away. If you hear the back of car is making this popping noise, fix it with some WD-40 @ the trunk area. Completely got rid of that sound in my car. See this thread. |
#44 |
Drives: 2013 frs
I hear it but it's coming from the rear left wheel ... I was driving the car and my buddy was following and said it was the rear left wheel
It's a metallic rattle noise Sent from my SM-N900W8 using Tapatalk |
#45 |
That actually might be the trunk popping noise then, go spray some WD-40.
#46 |
Drives: 2013 frs
#47 |
Drives: 2013 frs
Ok guys brought my car in and I found out that the noise was coming from inside the wheel.
The place where I had my enkei rpf1 mounted did not properly tighten one of the nuts on the aluminum valve stems and the nut got loose and made noise inside the wheel Took it out and place it back but couldn't fit 2 wrenches to tighten it it all the way..hopefully it doesn't get loose again or else I'll just switch to regular valve stems Sent from my SM-N900W8 using Tapatalk |
#48 |
Subaru <3
Drives: BRZ WRB 14
I have the same problem sadly
| The Following User Says Thank You to JordGTA For This Useful Post: | awhatzable (06-10-2015) |
#49 | |
Drives: Panda FR-S
Vortech SC on 9psi Pulley, Invidia Catless Front Pipe, Invidia N1 Catback Exhaust
![]() 242whp/197ft-lb on Mustang Dyno (91 octane water) 284whp/223ft-lb on Mustang Dyno (E85) Delicious Tuning |
#50 |
Drives: 2013 frs
I got that yesterday and brought it in. They said it was engine knocking due to a MAF sensor. They ordered a part and are installing it tomorrow. I'll follow up after.
The sound is really weird, it's like a loose part rattling around on the drivers side but only when under load at low rpm. |
#51 | |
Drives: 2013 frs
The dealership says it's engine knock... so what's the fix? They changed the MAF sensor and no change.
#52 |
Drives: 2013 frs
Rattle at low RPM under load.
The mystery is solved. Injector seals from direct injection side disintegrated, burnt and or disappeared. I have video and images of the noise and a video explaining the air in the combustion chamber and voila pop crackle pop.
https://drive.google.com/file/d/0B3O...ew?usp=sharing Replacement injectors may be more resistant. Alextouring |
#53 |
Drives: FRS
Does anyone have a sound recording of this "jar of Marbles" sound? I get it after the car is warmed up, usually downshifting to second around 2k. But after I notice the sound lingers on acceleration in 1st and second even when I shift into neutral and roll to a stop.
#54 |
Drives: 2013 frs
Rattling in 2nd or 3rd at low rpms
https://drive.google.com/folder/d/0B...FKa0RDYkk/edit
It sounds different in the car but you get the idea. |
#55 |
Drives: 2015 halo FR-S
My Frs makes a similar sound... notice it usually going up a slight incline prolly at 1.5-2k rpm. (To me) sounds like a clicking/grinding kind of noise either coming from the trans or diff? Idk i feel as though its normal at least for these cars.
| RPMS!! | Spencer Strayer | Engine, Exhaust, Transmission | 82 | 09-15-2011 10:51 AM |
