go_a_way1
Old 04-14-2014, 03:24 PM   #4285
Robftss
Drives: VW
Originally Posted by Jac View Post
What happens when I lift off throttle at say 5-6K RPM and my intake butterfly closes? I don't see a recirc/bov on the compressor, does it need one?
Compressor brakes
Robftss is offline   Reply With Quote
Old 04-14-2014, 03:26 PM   #4286
fenton
Originally Posted by Robftss View Post
Compressor brakes
Oh that's right. The DC motor brakes the compressor very quickly to stop surge.
Sent from my HTC One using Tapatalk
fenton is offline   Reply With Quote
Old 04-14-2014, 03:28 PM   #4287
robwbright
Drives: '13 BRZ Limited WRB Phantom ESC 1.5
@Robftss messaged you on the Phantom Website for info re: ordering. Thanks.
'13 BRZ Ltd MT WRB Phantom ESC 1.5
2012 Honda Accord Coupe
2006 Saab 9-3 2.0t
1997 Honda Accord Coupe
1995 Honda Prelude VTEC
robwbright is offline   Reply With Quote
Old 04-14-2014, 03:29 PM   #4288
Robftss
Drives: VW
Now i'm completely installed and had my first drive I thought I'd share my first impressions.
Install
  1. Took me just under 3 hours, although I'm pretty mechanically inept. Now i've done it once pretty sure i could do it again in about an hour.
  2. The install is super easy and trouble free if you follow the instructions
  3. Hardest part was bringing harness/wiring through the firewall and setting up throttle switch
  4. Easiest part was tuning, used OFT + Shiv's Phantom SC tune.
  5. Need to spend some time organising cables and tying them down
  6. Make sure you follow the instructions
Super Pursuit Mode via switch next to center console
Using sound tube ties to keep wires away from over pipe
Initial driving impressions
  1. Wow, I can't describe the difference this makes. I must've been giggling like a little girl for the first 30mins of my initial drive, with various "OH S**T!" moments as i hit boost.
  2. Learned NOT to activate mid-corner, lots and lots of oversteer (which is fun)
  3. There's a little lag between activating the pedal switch and hitting boost. Suspect tweaking the throttle switch to activate at maybe 70% could help.
  4. Coming from a stock tune there's numerous improvements in Shiv's map that improve general drivability. Car just feels generally happier/smoother.
  5. 2nd gear pulls from 2K RPM are awesome, hitting what feels like peak boost between 3-4K. 5k+ you do feel the torque drop off a little.
  6. Heat. I tripped the fail safe twice. I need to fix this.
  7. I like the fact this kit removes the sound tube, reduces cabin noise/drone.
Props to Rob and everyone that were involved in developing the Phantom SC, its a complete no brainer for the price and install time. Purchasing this was probably the best decision I've ever made.
Expect another update next week once batteries have broken in and I've had some dyno time
Please leave, use the cable routing as per instructions. Early testers have slightly longer main cables due to the earlier 4kW controllers box exit. Routing the main cables along the fender may put to much strain on the cables exiting the control box.
Cheers! Rob.
The Following User Says Thank You to Robftss For This Useful Post:
Sojhinn (04-14-2014)
Old 04-14-2014, 04:42 PM   #4289
DAEMANO
Time Traveller
Compressor brakes
Can confirm this is a thing, and it works.
Old 04-14-2014, 05:03 PM   #4290
Jac
Drives: Fiat Abarth
Compressor brakes
What is this, and how does it protect the turbine (fins?) from air coming back into the compressor? Just don't want to be ignorant of how this whole thing works.
Jac is offline   Reply With Quote
Old 04-14-2014, 05:24 PM   #4291
TM
TM's Avatar
Drives: DGM BRZ 6MT
Originally Posted by fenton View Post
OThe car feels amazing as the oft tune continues to learn. Right now I have the dump and a half pack and I think for most people that is going to be the next upgrade. No battery relocate required and you get about 95% the performance of the double dump plus relocate.
The addition of the half pack adds about 7 to 10 HP and one you get the standard system wrote up it is a dead simple upgrade.
Both Rob and butang were very impressed with my cars torque with the oft tune and a dump and a half. The new found torque really makes the car fight for traction in first and second gear.... It is a great feeling.
That's awesome! I don't want to go through the hassle of relocating the battery.
Where is the extra half dump located? Any pictures?
TM is offline   Reply With Quote
Old 04-14-2014, 05:28 PM   #4292
fenton
Like this
And then when it is wired up it looks like this. Keep in mind my wires are not as long so we couldn't make it as neat as the production kit will allow.
The Following User Says Thank You to fenton For This Useful Post:
TM (04-14-2014)
Old 04-14-2014, 05:37 PM   #4293
TM
TM's Avatar
Drives: DGM BRZ 6MT
Like this
That's pretty awesome. Any disadvantage to the smaller starter battery? Any idea when this would be ready for production units?
Rob told me I'm 4th in line last week. Hopefully, I'll receive my ESC by the end of next week, just after I come back from NYC. With some time to break in the batteries before the Toronto meet in May.
Old 04-14-2014, 06:43 PM   #4294
Robftss
Drives: VW
Instead of dumping excess pressure the energy is stored in a set of caps by a controlled regen.
The Following 2 Users Say Thank You to Robftss For This Useful Post:
DAEMANO (04-14-2014), Jac (04-14-2014)
Old 04-14-2014, 06:46 PM   #4295
Moletheus
Moletheus's Avatar
Drives: Raven 2014 FR-S
I'm definitely sold on this kit and will be purchasing within the next few months. I am just not sure how the single starter battery will hold up to my amplifiers. I'm pulling a decent amount of power when cranking my music. I have an amp powering a 12" sub and a 4 channel amp for 6 powerful speakers. At least a few hundred watts at any given time.
Will this affect the esc? Will the esc affect my stereo? Any experiences?
Anyone know how many amps the car pulls from the starter battery under load?
How many amps the stock alternator puts out?
How much I can pull from the starter battery?
I am also thinking about going ahead and getting the OFT now. Is there a stock tune I can take advantage of until I get the ESC? I feel like the tune just isn't right. I also have an abundant supply of e85 in my area..
Moletheus is offline   Reply With Quote
Old 04-14-2014, 06:53 PM   #4296
DAEMANO
Time Traveller
Your Phantom Supercharger, now with more KERS.
Old 04-14-2014, 06:54 PM   #4297
Gary in NJ
Gary in NJ's Avatar
Drives: WR Blue BRZ, 240Z
You might be a good candidate for a battery relocation to the trunk. This would allow you to maintain the stock (or larger) battery. The added benefit is this configuration will also allow you to run two dump packs
Phantom ESC, ECUtek Tune, Nameless Front Pipe & Axle Back, Enkei RS+M 17x8 et35, OEM+Ref
Gary in NJ is offline   Reply With Quote
Old 04-14-2014, 06:58 PM   #4298
fenton
Butang runs a stereo I believe. During recharge the ESC pulls 25A and the FRS alternator puts out 130A.
The OFT is a great device and until you get the ESC you can run their stage 1 e85 tune for more power over stock. That being said you could just run stock or standard stage 1 as well.
The Following 2 Users Say Thank You to fenton For This Useful Post:
DAEMANO (04-14-2014), Moletheus (04-14-2014)
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras Circuit Motorsports Member's Car Journals 4 03-21-2013 05:45 PM
Subaru BRZ : Full Throttle, powerslide, hard revving & ride ESBjiujitsu BRZ Photos, Videos, Wallpapers, Gallery Forum 20 05-30-2012 07:43 PM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 08:07 AM
