Old 04-14-2014, 02:00 AM   #23535
jeffsides
AZ FRS 86
jeffsides's Avatar
In a few weeks I want to put together a lil get together/cruise. More of a half day type thing. I was even thinking a meet up then a scenic cruise and grab lunch type thing. Thoughts?
Sent from ARIZONA86 HQ
@AZFRS86
The Following 8 Users Say Thank You to jeffsides For This Useful Post:
bignrichlll (04-14-2014), chrisbfrs (04-14-2014), FReSh_86 (04-14-2014), Gusha0426 (04-14-2014), J. O'Grimm (04-14-2014), kavanagh (04-14-2014), Shad0ez (04-14-2014), SirBrass (04-14-2014)
Old 04-14-2014, 09:22 AM   #23536
AZFA20
Automotive Connoisseur
AZFA20's Avatar
Drives: too many cars
Originally Posted by JesseE View Post
alignment has nothing to do with noise... if its noisy something is wrong or not assembled correctly what type of noise... if its knocking noises over bumps most of the time its the top bearing plate not tight, could be other things like loose bolts, worn sway bar links, but the strut mount with bearing is common.
What type of coilovers do you have? do they have pre load helper springs? or when your car is in the air does the spring flop around?
This is a little misleading in regard to aftermarket suspension. It is true for stock suspension but coilovers and really aftermarket suspension in general, the train of thought and diag differs. I assume your shop doesn't work with aftermarket suspension often? An alignment can in fact also cause noise although not likely in this persons situation. The loose springs in coilovers are completely normal and if your suspension droop is that fast or you are air born that long then you have other issues (bad strut/shock/rebound valving/wanna be general lee stunt driver). Urethane dampened or heim joint components (control arms, end links, sway bars, tie rods) are just prone to NVH period and functionally they are working perfectly fine. Helper springs on some coilovers are really only there for NVH reasons and serve little to no other purpose. Some claim they are there for keeping continuous contact to the ground but again thats just marketing gibberish at the end of the day. That's more of a droop issue as previously mentioned.
Please don't take this as an attack as it is not . I just don't want people who get aftermarket suspension hearing their first click or pop and now feel that their car is falling apart when really it's just a reality of this particular modification in many cases (not all).
The OP needs to have the car aligned though without a doubt unless they have a vendetta against their tires and overall driving experience.
I was asked to help spread the word. Meet on the west side Attachment 74237
Literally seconds from my shop and I LOVE THIS PLACES BURGERS however, they have the WORST service, slow as can be, and NEVER get your order right, EVER!! completely stopped going there as a result along with just about everyone I know that use to go there. Makes me sad because they are delicious when they get it right
LSx Powered 86/ASE Master Certified Automotive Technician
AZFA20 is offline   Reply With Quote
The Following 2 Users Say Thank You to AZFA20 For This Useful Post:
Old 04-14-2014, 10:01 AM   #23537
Celadrielas
Celadrielas's Avatar
Drives: 2013 Asphalt Fr-S
Since these normally happen on weekend days, I would need enough notice to request time off for work (3 weeks ish). If I got the day off, Sign me up. If not, well then I will be sitting at work living vicariously through you all via the forum.
Old 04-14-2014, 10:06 AM   #23538
WithNolock
Drives: Scion FR-S
I'll just leave this here.
WithNolock is offline   Reply With Quote
The Following 4 Users Say Thank You to WithNolock For This Useful Post:
Celadrielas (04-14-2014), nelsmar (04-14-2014), Shad0ez (04-14-2014), SirBrass (04-14-2014)
Old 04-14-2014, 10:26 AM   #23539
captain_jack
captain_jack's Avatar
Haha. That's funny, made my Monday morning.
may the schwartz be with you....
Old 04-14-2014, 10:41 AM   #23540
RedLeader
RedLeader's Avatar
Drives: 2013 Firestorm FR-S
@Cross let me know what you find out from BRIDE (5204494756)
Do you think it'd be possible to get the stock rails off the stock seat and put those 'BRIDEs' on them? You've had the stock seats out more than I have..
Sent from...somewhere?
Old 04-14-2014, 11:39 AM   #23541
SirBrass
Trust me, I'm the Doctor
SirBrass's Avatar
Head up the 87 to Prescott. Have lunch there & then cruise down white spar & through Yarnell to Wickenburg & end in the West Valley. That'd be half a Saturday.
On phone I am. Therefore, if mistakes I make, Frank Oz blame you should.
^GT5 Replay Photo Mode^
The Following 2 Users Say Thank You to SirBrass For This Useful Post:
Gusha0426 (04-14-2014), OLLIS (04-15-2014)
Old 04-14-2014, 11:40 AM   #23542
TwoFourFive
TwoFourFive's Avatar
Drives: 13 HOT LAVA
It was just the sway bar end links that were a little loose in my case.
TwoFourFive is offline   Reply With Quote
Old 04-14-2014, 11:44 AM   #23543
Gusha0426
Gusha0426's Avatar
Drives: 2013 Pearl white FRS
Sounds like a good idea. Let's do it man
Gusha0426 is offline   Reply With Quote
The Following User Says Thank You to Gusha0426 For This Useful Post:
jeffsides (04-14-2014)
Old 04-14-2014, 11:54 AM   #23544
Cross
It's the Mad Cow
Cross's Avatar
Ok I called a local supplier and apparently copies have become so hard to tell that it can be a pain in the ass. However since I told them these are older and they have a lever they asked me to take pictures and look for specific tags on the bottom.
As for the seat rails I believe you can drill out the rivets and they come off. I know the Recarro's I use bolt on but I believe ours are riveted on.
Old 04-14-2014, 12:24 PM   #23545
Cross
It's the Mad Cow
Cross's Avatar
Hey Tucson guys looks like there will be an SCCA event at Marana Airport next weekend. I am going how about you guys?
@captain_jack @martin86 @brenesk91 @MaddBaggins @RedLeader @4azcats @amaciose @Cycotech
Still have the pav's to go to as well that evening could make for a fun day.
www.mindthecones.com
The Following User Says Thank You to Cross For This Useful Post:
Cycotech (04-15-2014)
Old 04-14-2014, 12:31 PM   #23546
Celadrielas
I like this route. Great scenery and enjoyable cruise. What does everyone's calanders look like?
EDIT:: If this route doesn't work, is there a route between here and Tucson? Maybe we can all meet in the middle and hang for that
The Following 4 Users Say Thank You to Celadrielas For This Useful Post:
Gusha0426 (04-14-2014), J. O'Grimm (04-14-2014), OLLIS (04-15-2014), SirBrass (04-14-2014)
Old 04-14-2014, 01:38 PM   #23547
amaciose
amaciose's Avatar
Drives: 2013 BRZ Limited
I'd love to go, but I'm already RSVP'd to another event (not car related) going on that afternoon. Sounds like fun though!
amaciose is offline   Reply With Quote
Old 04-14-2014, 04:11 PM   #23548
Cross
It's the Mad Cow
Cross's Avatar
Hey @captain_jack I got you 440cc Injectors 4 of them for 65.00 I also bought myself 4 of them for 65.00... gotta love buying V8 parts lol.
