go_a_way1
Old 04-13-2014, 04:44 PM   #4257
Jac
Drives: Fiat Abarth
Originally Posted by fenton View Post
That is to connect the two dump packs together I believe.
Ah yes, thanks, now i see that in the instructions -_-
I installed it and saw a few sparks while i was doing so, normal?
Jac is offline   Reply With Quote
Old 04-13-2014, 04:50 PM   #4258
Robftss
Drives: VW
You should disconnect the main red connector first, then bolt on the copper bar...then reconnect the red connector.
If the red connector was connected during the bolting of the copper bar, then yes you will get a spark, it is the Caps charging.
Instruction are done in order for a smooth install.
Robftss is offline   Reply With Quote
Old 04-13-2014, 08:04 PM   #4259
Jac
Drives: Fiat Abarth
Smile
Now i'm completely installed and had my first drive I thought I'd share my first impressions.
Install
  1. Took me just under 3 hours, although I'm pretty mechanically inept. Now i've done it once pretty sure i could do it again in about an hour.
  2. The install is super easy and trouble free if you follow the instructions
  3. Hardest part was bringing harness/wiring through the firewall and setting up throttle switch
  4. Easiest part was tuning, used OFT + Shiv's Phantom SC tune.
  5. Need to spend some time organising cables and tying them down
  6. Make sure you follow the instructions
Super Pursuit Mode via switch next to center console
Using sound tube ties to keep wires away from over pipe
Initial driving impressions
  1. Wow, I can't describe the difference this makes. I must've been giggling like a little girl for the first 30mins of my initial drive, with various "OH S**T!" moments as i hit boost.
  2. Learned NOT to activate mid-corner, lots and lots of oversteer (which is fun)
  3. There's a little lag between activating the pedal switch and hitting boost. Suspect tweaking the throttle switch to activate at maybe 70% could help.
  4. Coming from a stock tune there's numerous improvements in Shiv's map that improve general drivability. Car just feels generally happier/smoother.
  5. 2nd gear pulls from 2K RPM are awesome, hitting what feels like peak boost between 3-4K. 5k+ you do feel the torque drop off a little.
  6. Heat. I tripped the fail safe twice. I need to fix this.
  7. I like the fact this kit removes the sound tube, reduces cabin noise/drone.
Props to Rob and everyone that were involved in developing the Phantom SC, its a complete no brainer for the price and install time. Purchasing this was probably the best decision I've ever made.
Expect another update next week once batteries have broken in and I've had some dyno time
The Following 6 Users Say Thank You to Jac For This Useful Post:
fenton (04-13-2014), Gums (04-16-2014), Robftss (04-14-2014), robwbright (04-14-2014), Shiv@Openflash (04-13-2014), SloS14 (04-14-2014)
Old 04-13-2014, 08:08 PM   #4260
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
Full throttle Electric Supercharger Build Thread
Install
Three things. You may want to route all your cables to the passenger side of your car. There are multiple points to zip tie your stuff. Like this:
Next since you tripped the fail safe. How much stuff do you have around your controller?
Also zip tie the drag reduction tube to the cables and off any thing that heats up.
Installed Mods:
Old 04-13-2014, 09:50 PM   #4261
Sojhinn
Sojhinn's Avatar
@Robftss,
If we add ducting to pull air from the front of the car and point it at the controller would this lower the occurrence of the fail safe tripping?
Installed Mods:
Old 04-13-2014, 11:28 PM   #4262
Urmyson
There is an extra 2 wire connector coming out of the control box, does anyone know what thats for?
Urmyson is offline   Reply With Quote
Old 04-13-2014, 11:31 PM   #4263
fenton
Pretty sure that is for the aux charger if you wanted to add it.
It doubles the recharge rate.
Sent from my HTC One using Tapatalk
fenton is offline   Reply With Quote
Old 04-13-2014, 11:34 PM   #4264
Urmyson
Thanks
Old 04-13-2014, 11:42 PM   #4265
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Install
It's great to see more and more people getting and enjoying their Phantom ESC kit. Rob has really done a fantastic job with it and we are just happy to help out what little we can
Shiv@Openflash is offline   Reply With Quote
The Following 3 Users Say Thank You to Shiv@Openflash For This Useful Post:
Gums (04-16-2014), Robftss (04-14-2014), Sojhinn (04-14-2014)
Old 04-13-2014, 11:43 PM   #4266
Gary in NJ
Gary in NJ's Avatar
Drives: WR Blue BRZ, 240Z
Is the rubber tube connected to the controller? This is for the sensor for the drag reduction. You'll want this connected.
And as mentioned above; reroute the cables/wires to the passenger side and zip-tie them together. No harm in getting some wire loom to encase the entire bundle.
Phantom ESC, ECUtek Tune, Nameless Front Pipe & Axle Back, Enkei RS+M 17x8 et35, OEM+Ref
Gary in NJ is offline   Reply With Quote
Old 04-14-2014, 12:52 AM   #4267
shif7i7down
Erected Member
Drives: frs
How's the noise? Hopefully the esc is not too loud when spooling.
shif7i7down is offline   Reply With Quote
Old 04-14-2014, 12:53 AM   #4268
Sojhinn
Sojhinn's Avatar
Not loud at all. More like a whoosh.
Installed Mods:
Old 04-14-2014, 01:05 AM   #4269
HSayaovong
HSayaovong's Avatar
Drives: blk;2dr;rwd;fun
I wonder if an aftercooler would help the esc and would there be plans to test such a system in the future
Life is like taking a dump, sometimes it's easy and other times its hard. But it always stinks
HSayaovong is offline   Reply With Quote
Old 04-14-2014, 01:52 AM   #4270
sw20kosh
Drives: 2013 Black FR-S
No. This thing produces low boost and does not have a hot turbine driving it.
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras Circuit Motorsports Member's Car Journals 4 03-21-2013 05:45 PM
Subaru BRZ : Full Throttle, powerslide, hard revving & ride ESBjiujitsu BRZ Photos, Videos, Wallpapers, Gallery Forum 20 05-30-2012 07:43 PM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 08:07 AM
