Old 04-13-2014, 01:52 PM   #15
Pneub
Drives: Dark Grey BRZ
Originally Posted by YMAA View Post
Your exhaust is plenty free-flowing. If you still can't get rid of the torque dip even with a supercharger AND uncatted headers, that's not a problem with restriction.
That's a tuning problem.
HKS Supercharger
Here's my dyno: http://i.imgur.com/mdz7Z3b.jpg
Pneub is offline   Reply With Quote
Old 04-13-2014, 02:13 PM   #16
FreshFRS
KCCO From Canada
Drives: Asphalt FRS
Originally Posted by Pneub View Post
The tune and install was done at Evasive Motorsports who have ample experience tuning. It's also been there a half dozen times and they don't seem to think its that loud. And it's not loud at it idle but on WOT you can hear this car a mile away.
even the canned tunes you get with any of the superchargers pretty much eliminate (most of) the dip, further optimizing that tune is only going to help. Evasives first tune looks like the dyno in post #37 http://www.ft86club.com/forums/showt...t+supercharger
Search any of the vendor threads for dynos; kraftwerks, jackson racing, vortech and even evasive's thread for the hks shows barely anything (~5lb/ft at most) for the torque dip with the canned tunes.
Wot with a header is going to be louder. even the stock catback gets pretty loud under WOT with a header/overpipe/front pipe.
FreshFRS is offline   Reply With Quote
Old 04-13-2014, 02:16 PM   #17
Pneub
I have a hard time believing it's Evasive's fault considering how experienced with tuning they are. I wouldn't even know how to approach them and say "people on forum say you guys didn't do a good job tuning". Are there any other possible reasons?
Old 04-13-2014, 02:18 PM   #18
FreshFRS
KCCO From Canada
Drives: Asphalt FRS
please re-read the post you quoted, i edited it with a dyno on a bone stock car. look at the discrepancy in the torque lines between the two.
Old 04-13-2014, 02:38 PM   #19
Apoc
Apoc's Avatar
Drives: Raven FR-S 6M
You should replace all your exhaust then it's obviously causing the noise and torque dip. No point in listening to few people on a forum when a reputable vendor has done your tuning.
“The World is Flat”
[||•]=(86)=[•||]
Apoc is offline   Reply With Quote
Old 04-13-2014, 04:51 PM   #20
Pneub
Good point. I guess I'll bring it up with them. Something clearly seems way off in comparison
Old 04-13-2014, 05:24 PM   #21
InvalidJohnny5
The Based God
InvalidJohnny5's Avatar
Drives: 87 Supra, 92 240SX, 13 BRZ Turbo
The quietest front pipe is the Milltek cat-delete. I run no cats in my car and it sounds like a stock STI.
Milltek Full Exhaust (Overpipe, Cat-delete, Catback), AVO Turbo kit , Perrin Crank Pulley , ACT Clutch Kit , ACT Prolite Flywheel 10.5lb , Axel-Exchange Driveshaft, Sparco Assetto Gara 17x7.5, Hankook Ventus V2s 225/45/17, Michelin Pilot Super Sports 225/45/17, Rally Armor Mudflaps, Viscontiproof tune Courtesy of Drift Office LLC
InvalidJohnny5 is offline   Reply With Quote
Old 04-13-2014, 05:45 PM   #22
wparsons
wparsons's Avatar
HKS Supercharger
Compare your dyno:
To this dyno:
The other dyno makes a lot better torque curve, but not as much top end as yours. Are you running a different pulley? Anything else swapped out? It seems strange that the power curve is that different of a shape with the same supercharger kit.
flickr
Old 04-13-2014, 05:50 PM   #23
Pneub
I'm running a different pulley. I have 11psi right now
Old 04-13-2014, 06:03 PM   #24
protpibe
protpibe's Avatar
Drives: 4-Runner Sport - 13' BRZ SportTech
Like others have said, if you still have a torque dip with a supercharger and that exhaust setup, the problem is your tune.
Top Tier Imports - Check out my build journal HERE
protpibe is offline   Reply With Quote
Entire car plasti dipped StormMcCloud FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 85 02-14-2015 12:06 AM
Plastidip Entire Car? who's done it? hmong337 Cosmetic Modification (Interior/Exterior/Lighting) 10 03-20-2014 07:26 PM
I want to buy BRZ OEM rim or entire wheel PPX Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 12-02-2013 11:10 PM
ENTIRE Audio System for Sale DatDudeLoso Audio/Visual, Electronics, Infotainment, NAV 6 11-20-2013 07:56 PM
ENTIRE Audio System for Sale DatDudeLoso Exterior Parts (Aero, Lighting, Etc.) 2 10-27-2013 08:24 PM
