Old 04-12-2014, 10:52 PM   #1
ricerocket93
STI Cluster Install
1. First remove the Phillip's screw.
2. Lift the gauge cluster hood at 45 degree.
3. Pull hard the cluster surround towards you. No need to unplug the ODO Trip connector.
4. Remove the 2 screws located on top of the cluster.
5. Pull the cluster and unplug the connector.
6. Install the new cluster.
7. Reinstall the cluster connector. You will need to push the cable back into that hole.
8. Follow the instructions in reverse to reinstall everything.
The gear indicator, shift light and shift indicator works perfectly.
You don't need to stop at your Subaru dealer to pair it with onboard key radio code. It is plug and play for the model with the push start.
As for the odometer, you need Subaru to but it back.
If the cluster is already paired with another vehicle, I don't think you can paired it back. You will have to take it apart and transfer the face and needle to your old one.
I was also unable to switch from MPH to KM/H, C to F and mp/g to km/l. The top button is now useless.
ricerocket93 is offline   Reply With Quote
The Following 5 Users Say Thank You to ricerocket93 For This Useful Post:
GaN-MaN (04-16-2014), illmatic (04-15-2014), SuperDave (04-14-2014), Trap63 (04-15-2014), ucsmfu (04-12-2014)
Old 04-12-2014, 11:52 PM   #2
DaJo
FT86Club Vancouver
DaJo's Avatar
Drives: BRZ Sport-Tech; Drove: MR-S, AE86
Nice!
So the only problem so far is that you cannot switch from KM to Miles?
Was also thinking of getting this...
When you say Plug and Play, does it still read your original KM?
1984 AE86 BT 20V 5MT 2007-2012
2000 MR-S 5MT
2010-2012
2013 BRZ Sport-Tech 6AT
Since '12 (OEM+ STI tS Build)
2015 Lexus IS250 AWD F-Sport 2 2015-2018
2018 Lexus NX300 F-Sport 3 Since '18
DaJo is offline   Reply With Quote
Old 04-13-2014, 12:12 AM   #3
Mr.
Supra Senior Member
Mr.'s Avatar
Drives: AE86 & BRZ
sexy as phoooooooooo. Thanks man. I might have to take a stab at this.
Build Thread
YouTube Channel
IG - Fwankyhong
Subscribe
Mr. is offline   Reply With Quote
Old 04-13-2014, 12:40 AM   #4
qijian
Drives: FRS
There's a gear indicator option on the FRS so I would assume it's just turned on, but that cluster looks great! Not sure if I would do it just got the STi logo though
qijian is offline   Reply With Quote
Old 04-13-2014, 09:00 AM   #5
ricerocket93
It will not keep your original KM. You start back to zero.
Old 04-13-2014, 09:19 AM   #6
DaJo
FT86Club Vancouver
DaJo's Avatar
This means you will HAVE to go back to the dealership to get it reprogrammed so the cluster matches the ACTUAL mileage in your ECU...
2000 MR-S 5MT
2010-2012
The Following User Says Thank You to DaJo For This Useful Post:
Trap63 (04-15-2014)
Old 04-13-2014, 09:59 AM   #7
charged86
charged86's Avatar
Do you think they would actually do it?
INSTAGRAM @Rcf_700 www.youtube.com/boostindub
Old 04-13-2014, 02:43 PM   #8
DaJo
FT86Club Vancouver
DaJo's Avatar
Probably, but at a cost... Lol
You know how stealerships are...
2000 MR-S 5MT
2010-2012
charged86 (04-14-2014)
Old 04-13-2014, 03:08 PM   #9
mikeTee
Yup.
mikeTee's Avatar
Drives: MT Subaru BRZ '13
It's okay, just drive the amount of miles that was on your old ECU. Bam, problem solved.
mikeTee is offline   Reply With Quote
The Following User Says Thank You to mikeTee For This Useful Post:
MemphisR (04-15-2014)
Old 04-13-2014, 06:37 PM   #10
protpibe
protpibe's Avatar
Drives: 4-Runner Sport - 13' BRZ SportTech
Thanks for this! I've been thinking of getting one for a while, but wasn't sure if it was PnP or not.
Has anyone contacted the dealer to see if they can change the odometer to match the vehicle? I've worked for a Toyota dealer for a number of years and remember a tech telling me that cluster odometers are independent of the ECU. I could be mistaken though
Top Tier Imports - Check out my build journal HERE
protpibe is offline   Reply With Quote
Old 04-14-2014, 12:43 AM   #11
SuperDave
SuperDave's Avatar
Drives: DAT Rally Blue BRZ
Might as well get a frs gauge cluster instead or hopefully find someone with the same mileage and swap
SuperDave is offline   Reply With Quote
Old 04-14-2014, 08:30 PM   #12
luv85
Drives: Grey GT
which STi cluster is that?
luv85 is offline   Reply With Quote
Old 04-14-2014, 08:31 PM   #13
DaJo
FT86Club Vancouver
DaJo's Avatar
BRZ tS
2000 MR-S 5MT
2010-2012
Old 04-14-2014, 08:40 PM   #14
SirBrass
Trust me, I'm the Doctor
SirBrass's Avatar
Maybe it doesn't switch because the tS clusters aren't able to since they're not sold in standard-unit countries like the US.
^GT5 Replay Photo Mode^
Gauge install, dash cluster light cable, Tach RPM cable help... Sportsguy83 Electronics | Audio | NAV | Infotainment 99 08-07-2016 10:36 PM
How-to: Install JPM Coachworks Stitched Alcantara Gauge Cluster Hood JPM Coachworks DIY (Do-It-Yourself) Guides 109 05-01-2015 01:19 PM
led cluster help Grip Ronin Cosmetic Modification (Interior/Exterior/Lighting) 12 02-14-2014 12:29 PM
BRZ cluster on FRS? Shipwreck Electronics | Audio | NAV | Infotainment 6 03-07-2013 11:09 AM
Scratches on my Cluster. Superhatch BRZ First-Gen (2012+) — General Topics 5 08-21-2012 07:50 AM
