Old 03-31-2014, 08:37 AM   #1639
steve99
Drives: FT86
Originally Posted by Kodename47 View Post
Does the OFT not have qan ECU reset function?
not that i have found
Old 03-31-2014, 10:39 AM   #1640
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
As soon as the AFR goes out of whack, the ECU will begin changing short term fuel trims. Then soon it will change the long term trims. No real need to reset. It might happen a bit faster with a reset ECU. Not sure. It should happen pretty quickly either way. The OFT Roms also, I believe, have a wide range of adjustment, so they can deal with a lot of variables.
Old 03-31-2014, 08:35 PM   #1641
zeppy
Drives: subaru brz-limited
Just got my car porn from @vishnu and loaded stage one map.
First log here, any opinions, i do understand i got to get some miles under the tune?
http://www.datazap.me/u/zeppy/stg1-b...ata=1-2-8-9-12
zeppy is offline   Reply With Quote
Old 04-12-2014, 07:41 PM   #1642
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
So I attempted to lean out the STG 2 EL E85 1.55b tune for my bone stock FR-S by adjusting the Fuel Map and Closed Loop AFR A and B. After loading the leaned out tune I did a couple of pulls, and the AFR is just as rich as before. What gives? Where else do I need to modify? I just want to lean it out a little bit across the board.
Here what it looks like against the stg1 tune on Virtual Dyno for reference. Seeing that the stock O2 reads lean at the lower AFR's this is really rich for a E85 tune.
Old 04-12-2014, 09:25 PM   #1643
steve99
Drives: FT86
If you trying to lean it out at full throttle you will need to modify the OL fuel table ? not the CL
Old 04-12-2014, 10:28 PM   #1644
solidONE
solidONE's Avatar
Isn't that what the "fuel map" table is, the OL fuel table? Besides that I don't see a open loop afr table in tuner pro.
Old 04-12-2014, 11:10 PM   #1645
steve99
Drives: FT86
I have always used rom raider, are the tunepro defs still up to date ??
in RR the table is called OL fuel table, not sure with tunepro.
Could be that the changes your making for cl are being counteracted by fuel trims in ol,
as shivs uses the trims to compensate for E%, might be best to ask shiv
Old 04-12-2014, 11:21 PM   #1646
Tromatic
IN for pics of grenade!
Old 04-13-2014, 01:00 AM   #1647
solidONE
solidONE's Avatar
Yeah I checked it on rom raider and it's the same thing, Fueling Primary Open Loop and Fuel Map (on tuner pro).
I went ahead and reflashed the same modded rom and gave it a few miles to relearn, filled up the tak with fresh E85 then went to take some more logs. Here are the results.
So basically I see no appreciable gain in power at all. Only benefit I see is possibly fuel consumption. May have to play with the timing advance to get any more power. The AFR are still pretty conservative particularly in the mid range around the dip (still very rich) and IAM pegged at 1. Notice how the AFR curve and the torque curve matching each other. So....... I have 0 worries of grenading this motor. mmkay?
Hey thanks..., buddy.
Old 04-13-2014, 02:45 AM   #1648
Kodename47
Kodename47's Avatar
Drives: UK GT86
Why so lean? I've just done a bit of digging that suggests 0.75-0.85 lambda is ideal for E85. As we don't have it over here though I'm not sure. Have you just bumped the whole map up by the same amount??
If E85 is like petrol, you'll gain more by advancing the tune than you will by going leaner. Thats why its beneficial to see if making a tune richer will reduce knock before removing timing.
.: Stealth 86 :.
Kodename 47 DJ:
Old 04-13-2014, 03:58 AM   #1649
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
+1
Our E85 maps only run slightly less rich than our gasoline maps. Trying to make them run considerably richer will just cause a power loss and result in a less responsive engine. You can even hear the engine sound strained when running too lean. I don't think you will ever cause damage running too lean on E85 (on an NA engine). The bigger concern I have with people street tuning on E85 is running too much ignition advance. You can easily run so much ignition advance (without knock) that you will start to lose power (and put unnecessary load on your rods.) Custom E85 tuning is truly best left for the dyno when you can actually see what makes most power since the usual telltale sings of an overly aggressive tune don't manifest themselves.
Cheers,
shiv
Shiv@Openflash is offline   Reply With Quote
Old 04-13-2014, 05:30 AM   #1650
solidONE
solidONE's Avatar
Originally Posted by shiv@vishnu View Post
+1
Cheers,
shiv
If you looked at where the AFR's are running with the Stg2 E85 tune on a stock car, you'll see makes it run super rich. What I did was try to bring it closer to what you stated 'slightly less rich' or rather about the same AFR as on gasoline tune.
And no, I did not just increase the AFR target values on the entire map, the low load and lower RPM areas I left mostly alone.
This is what I'll be trying to do next in terms of adjusting the fuel. But before that I may add a bit of timing advance to the OTS E85 tune and see if any more power is realized. And if there is more power to be had that way, I will then start to dial back the fuel again.
Old 04-13-2014, 06:12 AM   #1651
steve99
Drives: FT86
I can see your logic , but it may be worth heeding shiv,s advice.
With the extra variable of E% being compensated by fuel trims these tunes are likely to be a fine balancing act and a compromise due no flex fuel sensor.
Old 04-13-2014, 06:52 AM   #1652
Kodename47
Kodename47's Avatar
Drives: UK GT86
0.8 lambda is 11.76:1 AFR on gasoline so based on that it looks like you want targets of around 11.7-12. I have absolutely no idea of what is ideal though and as Shiv has said, you can hit MBT with Ethanol so without real testing it's not ideal.
General consensus is that if you start advancing timing and the power gain is minimal without knock, you're around MBT and it's best to back off the timing to the last known with the biggest gain. This is done for reliability rather than searching for that last few bhp. As Shiv has done his testing, I wouldn't go too mental.
It's also going to be difficult to do any form of MAF scaling/calibration if the E% content is varying.
.: Stealth 86 :.
Kodename 47 DJ:
cat overtemp
OpenFlash Tablet Rombinhood@OpenFlash Software Tuning 1838 07-29-2023 06:35 PM
OpenFlash Tablet Stg 2 Tune (Dyno Progress) Rombinhood@OpenFlash Software Tuning 26 10-24-2013 01:19 PM
FBM Tuning fixed my issue, FA20 and Visconti didn't work as well whitefrs Forced Induction 253 08-19-2013 12:39 PM
