Old 03-17-2014, 02:11 PM   #365
VuDism
NASIOC: AzNSTiImpreza
VuDism's Avatar
Originally Posted by leicaboss View Post
Nice, I'm interested in seeing more white twins on the gunmetal RPF1's...
VuDism is offline   Reply With Quote
The Following 2 Users Say Thank You to VuDism For This Useful Post:
fooddude (03-19-2014), newports (03-24-2014)
Old 03-18-2014, 05:30 PM   #366
KDad2
KDad2's Avatar
Drives: 2013 Raven
I just ordered my set of 17x9 +35 RPF1 in gunmetal! Also got the RPF1 center caps and Muteki SR48 open in blue.
KDad2 is offline   Reply With Quote
The Following User Says Thank You to KDad2 For This Useful Post:
VuDism (03-18-2014)
Old 03-23-2014, 02:44 PM   #367
Squishy86
Squishy86's Avatar
Drives: Your Car
A member PM'd me and asking to see a couple more pictures of how my wheels fit and whether it tucked or not. Decided I'll post them on here to help people out. The wheels are 17x9 +35 on 245/40 Hankook v12s. I'm on Fortune Auto coils dropped about 1.75 inches. My front camber is 2.5 degrees and the rear is 2.3 degrees. Camber on the front is from the OEM camber bolt and close to max camber plates. The rear is natural. I really should learn how resize pics before posting...
That's my ride height. I would say its about a 1.75 inch drop. I'm on Fortune Auto coils.
That's my top view of the front. My camber settings in the front is 2.5 degrees. I used the oem camber bolts plus close to max on the camber plates. The top of the tire is tucked in but you can see the bottom pushing out quite a bit.
Here you can see some more of the camber and how much it pokes out.
The rear is about the same deal in height.
The clearance from tire to fender in the rear is basically the same as the front. I only have 2.3 degrees of camber and it fits very nicely without the top of the rim poking out of the fender.
The tire sticks past the mudguards on both the front and rear and it gets sort of annoying because it throws water all over my white car so I'm forever dirty.
And one more pic of dat ass. I don't think I'm on level ground for this one though.
Squishy86 is offline   Reply With Quote
The Following 2 Users Say Thank You to Squishy86 For This Useful Post:
hmong337 (04-12-2014), MyEvilMonkeys (08-17-2014)
Old 03-23-2014, 10:53 PM   #368
Fishbone
Drives: 2024 GR86
....for taking the time to take these awesome pictures and posting.
Fishbone is offline   Reply With Quote
Old 03-23-2014, 11:53 PM   #369
1Cor10:23
1Cor10:23's Avatar
Drives: '13 Whiteout FR-S (M/T)
One thing I never fully understood, is the whole "tucked" look just for aesthetics? This might answer my own question but I guess it had slight better Aero and perhaps necessary for spring travel when you're lowered?
1Cor10:23 is offline   Reply With Quote
Old 03-23-2014, 11:54 PM   #370
JS + BRZ
Drives: 2010 MS3
You mean running negative camber? It gives you more grip on the corners.
Sent from my SCH-I605
Old 03-23-2014, 11:56 PM   #371
1Cor10:23
1Cor10:23's Avatar
No, I get the camber but just the tucking in itself. I'm planning on running my +35 9" on stock with just camber bolts so I know it will poke out a bit. Wondering if it causes any issue other than aesthetics. Thanks
Old 03-24-2014, 12:20 AM   #372
Squishy86
Squishy86's Avatar
Drives: Your Car
It affects the scrub radius but I don't know the science and effects behind changing this variable. Try to google it and within an hour you'll understand.
Old 03-27-2014, 09:12 PM   #373
Jaylyons1
Jaylyons1's Avatar
Drives: 2022 WRB BRZ; 1993 Skyline GT-R
Word from home says my wheels arrived! 17x9, +35 in gold. I can't wait to get home and play!
Just need some tires now! I'll have to update with some pics once I get home in a month or so.
Jaylyons1 is offline   Reply With Quote
The Following User Says Thank You to Jaylyons1 For This Useful Post:
fooddude (03-27-2014)
Old 04-06-2014, 07:10 PM   #374
CladMonitor
CladMonitor's Avatar
Drives: 2013 FR-S Asphalt
Just got my GunMetalGrey put on. Here's the look Against Asphalt FR-SName:  ImageUploadedByTapatalk1396825797.527139.jpg
Size:  184.2 KBName:  ImageUploadedByTapatalk1396825843.711639.jpg
Size:  149.2 KBName:  ImageUploadedByTapatalk1396825858.513531.jpg
CladMonitor is offline   Reply With Quote
The Following 4 Users Say Thank You to CladMonitor For This Useful Post:
fooddude (04-06-2014), hasanaltan (10-27-2015), karma003 (04-06-2014), RToyo86 (07-10-2018)
Old 04-06-2014, 07:43 PM   #375
fooddude
Drives: 04 Toyota Tacoma Prerunner Reg Cab
@CladMonitor: Very lovely! 245s or 255s? Which springs/coilovers?
fooddude is offline   Reply With Quote
Old 04-08-2014, 02:10 AM   #376
Andreas83
Andreas83's Avatar
Drives: 2013 Subaru BRZ
Wrapped with 245 PSS tires.
Pokes in the front, going to get some more camber dialed in.
Andreas83 is offline   Reply With Quote
Old 04-12-2014, 02:06 AM   #377
CladMonitor
Wheel Directory: Enkei RPF1 17x9.0 +35
Sorry, RCE yellows 255/40/17 ~2.0 camber all around.
The Following User Says Thank You to CladMonitor For This Useful Post:
fooddude (04-12-2014)
Old 04-12-2014, 01:57 PM   #378
fooddude
@CladMonitor: Nice! ...btw, did you paint your own tails? Looks really good, oem(not dark red) and shiny. Which red paint and clear coat did you use? Enamel mixed clearcoat?
Wheel Directory: Enkei RPF1 17x9.0 +45 LevinPhan Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 265 06-04-2024 11:13 AM
Group Buy: Enkei RPF1 17x9 +35, 17x9.5 +38, 18x9.5 +38 ***In Stock*** LSD Motorsports Groupbuys 246 08-29-2013 01:35 PM
WHITE Enkei NT03+M 18x9.5 / Enkei RPF1 17x9 Touge Factory Wheels and Tires 2 02-05-2013 04:53 PM
