#3375 |
Just finished my trans/diff fluid swap.
For those that haven't done it yet, be careful when you open the transmission drain plug. I underestimated how far out the fluid would shoot and had a bit of a mess to clean up. |
| The Following User Says Thank You to jvincent For This Useful Post: | Slick (04-11-2014) |
#3376 |
Drives: 2013 BRZ Sport-tech
About to buy a BRZ - couple questions
First, hi! Long time lurker. I don't think I'll join the many of you on the track, but I am looking to tinker with the car on the less performance aspects of it.
I'm about to buy a new car, and I wanted to make sure not to forget to do any important things. I'm still a little on the fence about drilling for front plates vs re-locator, same with opticoat or some sort of clear bra (any negative with corrosion? just fender or whole front?), and even tint. I've heard to ask dealer not to wash the car or wax it, is that really important? Is that only if you opticoat? I've probably been reading too much and am a little confused now and worried of making some mistakes. I'd really appreciate suggestions from places in town to have that work done(tint, 3M films, etc)! I plan to drive it year-round, and I guess I have some time to consider rust-proofing- I plan on it, but I'll have to decide which kind and drilling/no drilling. And I will likely get the weathertech mats for the front, then look for something in the rear. I might also get the plastic trunk liner. Is there anything else that I should decide to do right away upon purchase that would be more complicated to do later on? Thanks. I hope to meet some of you during my (relatively simple) DIY adventures that are sure to follow. Last edited by PNA; 04-11-2014 at 12:28 PM. Reason: additions |
| The Following User Says Thank You to PNA For This Useful Post: | OrangeGuitar (04-11-2014) |
#3377 | |
Drives: Ultramarine Blue FR-S
Sent from my HTC One using Tapatalk
-- Kenny"I don't always use heel/toe, but when I do it's because racecar." |
#3378 | |
Drives: 2013 Scion FRS Raven
1. I wish I would have protected the whole hood and front fenders on the car along with the rear trunk lid ( many scratches now from hockey bag and golf clubs.) 2. look to buy your winter tires now ( tirerack ) as they will have some end of season clearance going on. 3. Krown. Have gone through 2 winters on mine and no rust underneath at all. Drilled by the way. 4. Unless your friends are smurfs don't bother with the rear matts. LOL
#3379 | |
Drives: FR-S Firestorm 6MT
#3380 |
#3381 |
Front license: you tied it with zip ties? I'd like to see a close up photo if you have one. Makes sense though, if I can figure out how to do it. I'll have to confirm that the holes haven't already been drilled! And if not then make a HUGE deal about it to make sure they don't when they prep it.
Who is Vlad? Any idea how much it costs to do the whole front? I'm guessing I would get a lot of dings from salt and rocks on these roads. It would be nice to keep it looking good. Does the car colour matter? (Black). Proper washing techniques would be appreciated. I'm sure I can search through many threads with conflicting information but clear info here would be appreciated. Otto Subaru. Any advice with them? Buying winter tires now makes sense. I'll start looking right after I buy the car. Thanks to all. |
#3382 | |
Here's the FRS setup typically. Mine: ![]() vs factory install: But forgot you have a BRZ so there's less room in the "grill" part. So either a sidemount or in grill installation for your car, unless you're okay with the factory location. Factory: Tow-hook sidemount: ![]() Lower grill location (unsure how mounted, looks like zipties): ![]() Another drill-less option in this thread: http://www.ft86club.com/forums/showthread.php?t=35261 |
#3383 |
Drives: 2013 Subaru BRZ WRB AT
I had Xpel (similar to 3M) done on my full hood, full front bumper and trunk lip. It was around $1500 to $1600 at Autotrendz in Stittsville. I had a buddy do only the first 12" of the hood (He has a Lancer) and regret it because he started getting dings past that point. I'd recommend getting full hood if you can afford it.
Vlad runs Upper Class Detailing which I plan to use in 11 days for a full detail but everyone says he's great and his work shows that. I bought from Ottos and didn't have a big problem. I did ask not to drill but they did anyways but I'm over it, it's not terrible to me. If you don't want them to drill, get it in writing. |
#3384 | |
Drives: FRS
I was going to say, if it was an FR-S from TG they are good about not drilling the bumper or putting dealer stickers on. at least i didnt even have to ask, they just did it 'correctly' by default. with a BRZ, different. PNA, I would also suggest to tell them not to put any stupid dealer stickers on the back. |
#3385 |
Just got back from some driving with the new fluid in the tranny/diff.
I'm going to miss the notchy shift into second.......... not. |
| The Following User Says Thank You to jvincent For This Useful Post: | FRSToyota86 (04-12-2014) |
#3386 |
Drifter
took mine out yesterday been loving life again... def need to swap all fluids tho!
| The Following User Says Thank You to SciOnDrifTtSlIdeR For This Useful Post: | 86gt? (04-12-2014) |
#3387 |
Drives: '13 Ultramarine
Spring cleaning! Does anyone else find the inside of the rear window a huge pain in the arse to clean? WeatherTechs are out, carpet mats are back in, and the summer wheels are back on. Next up is a fluid change for the trans and diff. I'm going back to Pentosin for the trans this time...I haven't found anything as good yet.
#3388 | |
Drives: asphalt 86
| The Following User Says Thank You to 86gt? For This Useful Post: | Pbrown (04-12-2014) |
