Old 04-06-2014, 04:56 PM   #1303
Infamous Performance
Infamous Performance's Avatar
Drives: 02 WRX, 05 LGT, 08 LGT, 08 SpecB
The 12psi sensor is a Denso from a Honda.
Infamous Performance is offline   Reply With Quote
Old 04-07-2014, 09:03 AM   #1304
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Originally Posted by Reaper View Post
Anyone mount their mbc in a unique location?
You can kind of see it in this photo:
I mounted my Grimmspeed MBC to an existing bolt on the driver side strut tower near the ABS hard brake lines.
Old 04-07-2014, 06:09 PM   #1305
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
heres mine mounted to the alternator cover.
absolutely shortest vacuum lines possible. does it make a differance? not really, but theres less vaccuum lines to check for cracks, leaks etc.
Sent from my SAMSUNG-SGH-I747 using Tapatalk
The Following User Says Thank You to Reaper For This Useful Post:
Kiske (04-07-2014)
Old 04-07-2014, 06:37 PM   #1306
Dipstik-sportech
Dipstik-sportech's Avatar
Honda acura same thing
The Frozen North
Old 04-08-2014, 08:58 AM   #1307
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Drives: Whiteout Scion FR-S
If anyone is looking for a set of slicks
I'm selling 15x7 Rota Slipstream with Mickey Thompson 26x8.5
550 picked up or 650 shipped
Old 04-08-2014, 09:51 AM   #1308
sw20kosh
Drives: 2013 Black FR-S
Does it really make a huge difference? @kingtut
I was thinking of mounting mine in the cabin footwell for easy access while driving
Old 04-08-2014, 10:14 AM   #1309
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Yeah since I was using a vacuum manifold and not tees that was actually the shortest I could make it by mounting mine close to the vacuum manifold.
Old 04-08-2014, 10:38 AM   #1310
King Tut
NASA SpecE30 Racer
King Tut's Avatar
I wouldn't call it a huge difference. The longer the line or the more tees between the boost source (tapped housing or intake manifold) will change how much vacuum or boost the MBC and could change how quickly it is able to react and open/close the wastegate. If you really want in cabin access of a MBC then go with the Hallman and get the cable for it that you can run into the cabin.
Old 04-11-2014, 12:41 AM   #1311
Reaper
Reaper's Avatar
Drives: violent
well my thread got alot of views but im going to post it here anyway since until i did it no one could answer my question....
550cc injectors max out at 440ish whp on e85. There, now you know. Buy 1000s for e85 like LJ says.
FullBlown (04-11-2014)
Old 04-11-2014, 10:04 AM   #1312
Ironsquid
King of Kiwi Palace
Ironsquid's Avatar
Drives: Faster than you
bro just run more DI
Ironsquid is offline   Reply With Quote
The Following User Says Thank You to Ironsquid For This Useful Post:
SmsAlSuwaidi (04-11-2014)
Old 04-11-2014, 05:56 PM   #1313
ftc~brz
Done
Drives: WRB BRZ
do you need 1000s or do you have them already?
ftc~brz is offline   Reply With Quote
Old 04-11-2014, 07:14 PM   #1314
Reaper
Reaper's Avatar
Drives: violent
Need.
Old 04-11-2014, 08:03 PM   #1315
mike the snake
Boosted
Old 04-13-2014, 01:09 PM   #1316
Sterz
Great White
Drives: 2013 Whiteout FRS
Alright guys so I finally got an appointment in with Bill @DeliciousTuning. The date is Wednesday 4/16
Modlist:
FBM Stage 1 Base Kit
FBM Radiator
FBM Spal 12" Fans
FBM Oil Cooler w/ SS Lines
1000cc Injectors
Testing out Bill's new MAP sensor
ClutchMaster's FX350
E85
Will post up results as soon as I get home, shooting for 16 PSI.
Sterz' Great White 86
http://www.ft86club.com/forums/showthread.php?t=54533
Invidia Q300 Catback | Invidia Catless Frontpipe | Invidia Overpipe
Sterz is offline   Reply With Quote
best company ever, big fuck off turbo, blown, bow chicka wow wow, fbm, full, owners, powaaaaaa!, thread, will work for turbo
AVO Turbo Kit Owners Topic Sportsguy83 Forced Induction 1935 02-20-2023 10:46 AM
Full Blown FRS/BRZ Stage 1 Turbo Kit FullBlown Forced Induction 456 09-27-2021 03:10 AM
FA20Club Turbo Kit Owners Topic pixel67 Forced Induction 1531 09-09-2014 12:36 PM
Full Blown Turbo Kit! Unleashed Engine, Exhaust, Bolt-Ons 70 10-09-2013 09:46 AM
WTB: Full Blown turbo kit (used) whitefrs Engine, Exhaust, Bolt-Ons 12 03-29-2013 09:15 PM
