Old 04-09-2014, 04:27 PM   #71
Grassroots_BRZ
Drives: Pearl White BRZ
Ride looks fantastic. Can't wait to see the numbers after your dyno.
Grassroots_BRZ is offline   Reply With Quote
Old 04-10-2014, 12:32 AM   #72
rb6freak
rb6freak's Avatar
Drives: 23 BRZ
Originally Posted by JS + BRZ View Post
Don't think I said this before.
Awesome work and awesome turbo-ed BRZ man.
Thanks!
rb6freak is offline   Reply With Quote
Old 04-10-2014, 09:43 PM   #73
AllDayJonRay
Drives: 2013 Ultramarine FR-S
Man. All this stuff going on right under my nose, and I didn't even notice... I've hardly seen a single 86 with what I might think was a car person since we arrived in OC. (Yea, I know there is a local forum, but I don't browse very much)
Only noticing this because I was searching around for a better variety of pics of ptuning kit. Looks great man. Great work with the photo documenting of your install. It will be very useful for others when they tackle the DIY install.
'13 Ultramarine 6MT FR-S || K&N Drop-In, SpeedFactory V1 Cat-Back || Moto-East tuned
Join the 86 Owners Clan on Clash of Clans: "86 Owners" Password: "fa20" || Help us take over the world || Thread
AllDayJonRay is offline   Reply With Quote
Old 04-10-2014, 10:15 PM   #74
rb6freak
rb6freak's Avatar
Drives: 23 BRZ
Thanks for reading and comments. I'm going to put together a video of the install sometime soon for even more viewing pleasure :-)
The Following User Says Thank You to rb6freak For This Useful Post:
AllDayJonRay (04-10-2014)
Old 04-10-2014, 11:54 PM   #75
SnapOv3st3r
Drives: 400whp Scion tC
Where did you get the intake plug to do a vac leak test?
SnapOv3st3r is offline   Reply With Quote
Old 04-10-2014, 11:58 PM   #76
rb6freak
rb6freak's Avatar
Drives: 23 BRZ
3" PVC pipe cap at your local hardware store.
SnapOv3st3r (04-11-2014)
Old 04-11-2014, 09:25 AM   #77
SnapOv3st3r
Do you know if they make a 4"? Because the PTuning intake on my tC is 4".
Old 04-11-2014, 01:26 PM   #78
rb6freak
rb6freak's Avatar
Drives: 23 BRZ
So is mine. Trust me, you want a 3" cap. PVC uses ID or Inner Diameter. Therfor the plastic on the outside is bigger than 3". Lastly, add on that its a 3" cap, so that is even bigger than the pipe. It turns out to be an exact fit for the intake pipe.
SnapOv3st3r (04-13-2014)
Old 04-13-2014, 12:22 AM   #79
SnapOv3st3r
Good point. Thanks man for the info. And yea, I thought the PTuning intake was 4" for the FR-S also, so it kinda thru me off when you said to get a 3" cap.
So you just tap it for the pressure adapter?
Old 04-13-2014, 12:37 AM   #80
rb6freak
rb6freak's Avatar
Drives: 23 BRZ
Yup. I drilled a hole just the right size and then shoved it in with some JB Weld... Although I'm sure your basic hot melt or silicone rubber filler will work just fine. Start low PSI and work your way up. You may or may not hear oil churning or even the scavenging pump making noise. I was able to find one leak due to a broken screw clamp on a coupler that wasn't tight enough. I went up to about 20 psi at the most. No need to go higher. You will be able to hear and feel any leaks by getting up close and placing your hand over each coupler. If you can't reach but can see - use dish soapy water in a spray bottle and look for bubbles. Its best to do this when everything is cold.
The Following 2 Users Say Thank You to rb6freak For This Useful Post:
Hicklinc (01-30-2018), SnapOv3st3r (04-13-2014)
Old 04-13-2014, 12:40 AM   #81
rb6freak
rb6freak's Avatar
Drives: 23 BRZ
Oh and don't be alarmed as your tank will lose pressure continuously and it may not be a leak. I think the common is loosing 1 psi a second. But if its coming from a pipe you'll hear the difference.
Old 04-14-2014, 01:12 AM   #82
rb6freak
rb6freak's Avatar
Drives: 23 BRZ
Fire extinguisher mounted. Bracket shipped from SpeedTech NZ.
Old 04-14-2014, 10:32 AM   #83
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
@Visconti Flex Fuel?
Old 04-14-2014, 11:41 AM   #84
rb6freak
rb6freak's Avatar
Drives: 23 BRZ
Lol. Modified fuel, air and oil system I'd say its a must. Couple hundred to save thousands is worth it in my eyes.
AVO turbo kit for BRZ - initial build thread AVOturboworld Forced Induction 3109 12-01-2019 03:55 PM
My trip to FBM - FBM Premium Turbo Kit build brzaapi Forced Induction 170 11-12-2013 06:04 PM
400hp build and other turbo questions. Ludacrits Forced Induction 22 10-26-2013 09:01 AM
Just wanted to show off my turbo build sw20kosh Forced Induction 5 04-01-2013 03:16 PM
Turbo engine build, and parts No Limit Motorsport Forced Induction 30 12-11-2012 07:32 PM
