| Software Tuning Discuss all software tuning topics. |
#15 | |
Drives: FR-S, BR-Z, 86
Arghx7 quoted me on it in another post, but I'll repost it here.
#16 |
if i went with an e85 tune can igo back and forth between e85 and 91? i am in cali so e85 is rare. and does e85 and 91 mix?
#17 |
No one can be 100% sure of the long term effects of E85 on the BRZ/FRS/e85.
So far so good, on top of that Subaru has a very good warranty so if anything did go wrong - they would cover it. As for the tune side of things - When running pump gas and wanting to switch to e85 you'll want to run the tank very low, then fill up on e85. I'm currently working on a flex fuel kit for these cars. I should have a few kits out in the wild for testing in the next few weeks With the flex fuel kit you won't have to switch maps, the ecu will automatically adjust for ethanol content. -John |
| The Following 2 Users Say Thank You to Visconti For This Useful Post: | KamalT (11-14-2012), LeavingNormal (11-13-2012) |
#18 | |
More power per unit of air, but less power per unit of fuel. Stoich for E85 is richer than gasoline so you get power at the cost of mileage.
#19 |
Drives: 2013 Asphalt FRS
This is a noob question. So if i am right, i could fuel up with E85 with no tune correct?
#20 | |
Drives: White 2013 FRS
So has anyone looked into what the fuel lines for this car are made out of? E85 likes to eat AL and rubber lines. Also this should be in the tuning section: @WingsofWar Last edited by Brick; 04-10-2014 at 10:57 PM. |
| The Following User Says Thank You to Brick For This Useful Post: | WingsofWar (04-11-2014) |
#21 |
Shibby!
Drives: '14 White FR-S, '01 turbo mini taco
most switches to E85 require an upgraded fuel pump, injectors, and fuel lines (I almost wanted to say fuel rail as well
). I'm actually quite amazed that just dumping a different fuel in the tank that burns at a different temperature and rate with a simple flash tune is sufficient to keep these cars running, power gains or not.
| Let's get tuning! EcuTek tuning now available! | carbonBLUE | Southwest | 6 | 06-29-2015 02:37 PM |
| DDM tuning HID kits | bcmakesiteasy | Cosmetic Modification (Interior/Exterior/Lighting) | 34 | 10-12-2012 07:27 PM |
| Anyone into DIY ECU tuning? | Saibot | Engine, Exhaust, Transmission | 26 | 04-25-2012 01:16 PM |
| Tuning | Jordo! | Engine, Exhaust, Transmission | 54 | 09-05-2010 05:29 PM |
