in orbe terrum non visi
Drives: violent
Leaning out!
FBM base kit with gtx2867r and 550cc injectors on e85. Made over 460 on the dyno then the failsafe kicked in after a few runs. Car was over 18.5 psi if I remember correctly. Figured we hit the limit of the fuel system. Backed it down to 450 and car ran great on the street. Then after a week or so it started breaking up in 4th under boost. I turned the boost down to 16.5 and the problem went away. Then it came back. Lean conditions almost randomly in boost. Usually after a hard shift. It will pull to redline just fine 9 out of 10 times but leans out when back on the throttle after shifting and almost only after shifting. Once in awhile at 4500 under load the failsafe kicks in in 4th. Thankfully the failsafe in my tune is great, stays at 13.1 and 8psi with my foot to the floor but wont climb in rpms. So slowly Ive had to lower the boost. Made me think the fuel pump was dying since it made over 460 at one point and has been tapering off. (I do not have an ecutek cable yet but am on the verge of overnighting one from jaaapan so I can pull a damn log and be done) so I called lj @FullBlown and he set me up with the awesome walbro 485. Great setup, tight fit though. I had the boost turned down to 15 prior to the new pump instal and hadnt had any issues other then being slower.With the new pump in I turned it up to 16.5 again and the failsafe kicked in at around 5000. My guess now without a log is sparkplugs, or injectors. Has anyone for sure maxxed out the 550s on e85 and at what power? Im sure i was at the limit but why has it tapered off slowly over a week or two? Its actually been getting warmer since we made more power before the problem. Anyone want some 550s?
Sent from my SAMSUNG-SGH-I747 using Tapatalk
I have E85 where there isn't E85, that's my secret.
http://www.ft86club.com/forums/showt...t=reaper+build |
#2 | |
Drives: Scion FRS
| The Following User Says Thank You to FullBlown For This Useful Post: | Sportsguy83 (04-09-2014) |
#3 |
Drives: violent
Still dont have an ecutek cable.
#4 |
Drives: violent
#5 |
Motorsports
Drives: 19BRZ PP, 16 M4
PI duty was 93% @ 1.2bar. I made an Ecutek custom map setup that is manifold pressure vs Wbo2 that cuts the TFQ if afrs and boost are not within an acceptable range. This car dyno'd 440ish whp on e85 with 550cc injectors. It is clearly out if PI injector and needs larger ones installed to work with current fuel system .
550cc injectors without a rising rate fpr are only equivalent to 400ish cc injectors under full load because of the pressure differential. Posting from my phone so excuse any errors. Doug
Douglas W.
| The Following 2 Users Say Thank You to DBW For This Useful Post: | Reaper (04-10-2014), Sportsguy83 (04-10-2014) |
#6 |
Motorsports
Also wanted to add reason it's leaning out now and not before is now you have run more tanks of E85 through it. I guaranty the E85 content now is much higher then previously.
Doug
Douglas W.
| The Following User Says Thank You to DBW For This Useful Post: | Sportsguy83 (04-10-2014) |
#7 |
Boosted
Drives: Not a supra....yet
What he said ^
I don't know where you reside but maybe since winter is almost over, the blend of e% is way higher.
#8 |
Drives: violent
well damn! I didnt even think about E content. That explains why my cold start changed again. I really need an ecutek cable. All of that would have been painfully obviouse. Thanks doug @TopSpeed. I tried calling to get the PI duty but you're always on the dyno on days ive gotten out of work early enough to call.
#9 |
NASA SpecE30 Racer
I know LJ recommends swapping to the 1000s when you decide to run E85 and more boost on the FBM kit.
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z |
#10 | |
Drives: violent
#11 | |
Drives: 2013 GBS BRZ Limited
I have a tactrix and a ELM327 bluetooth adapter. I believe you can still log from a ecutek tune with one of those, but not sure. I live in the "mountains" too (N. CO.) |
#12 |
Drives: violent
i appreciate it. Im in georgia. If you like translate whats under my name and it might make more sense.
#13 |
Drives: Pile of junk
#14 |
What is your ethanol content currently, just out of curiosity?
| leaning to the side from turns? | Gilwith1l | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 13 | 02-15-2014 04:54 PM |
| i'm leaning toward BRZ but will it be easier to get a FR-S? | stlgrym3 | BRZ First-Gen (2012+) — General Topics | 28 | 03-30-2012 01:07 PM |
