Old 04-10-2014, 03:23 PM   #43
Shit Luck
Drives: red frs
I swapped those awhile back...
I needed something that would clear bigger brakes. I miss the look though.
Shit Luck is offline   Reply With Quote
The Following User Says Thank You to Shit Luck For This Useful Post:
GuerillaRacing (04-10-2014)
Old 04-10-2014, 03:40 PM   #44
Boxer486
Drives: small
Originally Posted by Wayno View Post
Shame there's 2 threads for the same thing. Double the 16" publicity I guess!
Wheel Directory: Racing Hart CP-035R 16x7 +45 5.0Kg/11lbs
I just have to ask because the curiousity has been killing me, but you bought those used right or did you move them from your older car?
Boxer486 is offline   Reply With Quote
Old 04-10-2014, 08:19 PM   #45
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
They came from a yahoo japan auction and I don't know the history of them but they're in pretty good nic, besides 1 with slight gutter rash.
Old 04-11-2014, 01:22 AM   #46
Nico TURBO
Drives: 1986 Subaru LEONE TURBO
Originally Posted by SkAsphalt View Post
Any 16" clear the STI brembos?
no
Braid makes what ever size you want, I just got 5x100 16x8 et45 WINRACE A - tarmac rally, RallyCross, track
http://www.braidusa.com/wheels.htm
or
Enkei ES Tarmac 5x100 16x8 et45
http://www.irs.co.jp/oversea/products/es/index.html
http://www.rallispec.com/whe_whe_est16.html
Nico TURBO is offline   Reply With Quote
The Following User Says Thank You to Nico TURBO For This Useful Post:
flippy (04-13-2015)
Old 04-17-2014, 06:12 PM   #47
GuerillaRacing
GuerillaRacing's Avatar
Drives: Scion FR-S
Just fitted some new 16x8" +25 Compes to our FR-S shop car. Loving the look and feel of it.
GuerillaRacing is offline   Reply With Quote
The Following 3 Users Say Thank You to GuerillaRacing For This Useful Post:
dori. (05-09-2014), Fett4Real (04-21-2014), yo joshman (03-25-2015)
Old 04-17-2014, 06:27 PM   #48
CSG David
CSG David's Avatar
16x7 T66-F
The Following 2 Users Say Thank You to CSG David For This Useful Post:
drewbot (04-29-2016), GT86_PRAGUE (04-29-2016)
Old 04-18-2014, 03:07 AM   #49
stockysnail
Just the tip
stockysnail's Avatar
Originally Posted by CSG David View Post
16x7 T66-F
I see this on your website for sale but it doesn't say if it's $672 each or for a set of four. If it's for a set of 4 I will put these on the top 3 wheels to consider buying in the near future.
Old 04-18-2014, 03:10 AM   #50
stockysnail
Just the tip
Originally Posted by GuerillaRacing View Post
They are Enkei Compe wheels, 16x8 +25. I'm getting the same set for our FR-S! We are dealers for this wheel in case anyone wants some Enkei Compe
Edit: Owner is @Shit Luck
How much do these cost for a set of 4 and how much does each wheel weigh, both in reference to the 16x8 +25 variety. I'm liking the way the +25 looks. I assume it will clear stock suspension?
Old 04-18-2014, 03:35 AM   #51
CSG David
CSG David's Avatar
1 wheel is $672 retail. We have a GB setup right now.
Old 04-18-2014, 03:36 AM   #52
CSG David
CSG David's Avatar
They are not too pricey. In fact, I think 1 TWS wheel is essential a set of Enkei Compe...
Old 04-18-2014, 04:19 AM   #53
Trettiosjuan
Drives: GT86
The TWS is forged and 4,8kg (10.6lbs) while the Compe is like 8kg something and cast so quite a difference there too.
The +25 on the latter needs some neg camber otherwise they stick out a bit.
Trettiosjuan is offline   Reply With Quote
Old 04-18-2014, 08:49 AM   #54
Shit Luck
Drives: red frs
if you check my build thread there are some pics on stock suspension.
stockysnail (04-18-2014)
Old 04-18-2014, 11:38 AM   #55
stockysnail
Just the tip
I'm running some 18"x8 forged wheels that weight 17.8lbs if you know anyone that has used ones for a straight across to trade. They retailed for about the same amount too ($650). I got a set of 5 for $1200 (Neuspeed RS10). Basically looking for either a trade or less than $200 per wheel in 16" that weight under 15lbs. I guess I'll work on my baller status to get these wheels.
Old 04-18-2014, 12:40 PM   #56
GuerillaRacing
Drives: Scion FR-S
Cost is $720 shipped for the set. It should clear stock suspension yes, however we have only installed the set on our FR-S with Megan Racing Track Coilovers.
I believe each wheel weighs around 20lbs in the 16x8" +25 5x100
For the front, you will need a little bit of negative camber as the wheels do poke in this setup.
Wheel Directory: Styluz S006 18x7.5 +40 Pavel Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 23 01-22-2014 04:16 PM
FS [SYD] 16 inch GT wheels and tires! luv85 Australia Classifieds 3 11-04-2012 06:15 AM
Help! Two 10 inch vs One 10 (or 12) inch cyntage Electronics | Audio | NAV | Infotainment 7 09-27-2012 11:20 PM
I need 19 inch wheels today! benqld7 AUSTRALIA 16 08-07-2012 08:33 AM
16 inch wheels for the base model!!! Blokatos Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 12-07-2011 11:17 AM
