Old 04-10-2014, 02:42 PM   #1219
Racecomp Engineering
Originally Posted by gramicci101 View Post
So what you're saying is to find a new WRX and swap their LCAs for ours? I feel like the owner of the WRX might get upset at that, so it's best if he doesn't know.
Haha, well I don't think those would swap over easily.
It would be awesome though.
- andy
Old 04-10-2014, 02:55 PM   #1220
stockysnail
Just the tip
stockysnail's Avatar
I'm guessing the only difference between the RCE yellow and RCE tarmac springs is the spring rate? The website lists yellow at 250lbs/in and the tarmac at 5kg. Could you fix it so they are in the same unit of measure so I and others have a better point of reference? I currently have the yellows mated to the Koni yellows and love them. I got them before the tarmac springs came out however so not sure if I'd like the tarmacs even more.
Old 04-10-2014, 03:00 PM   #1221
Turkish
Serial Cone Killer
Turkish's Avatar
Drives: '14 BRZ - WRB Premium 6MT
280 lb/in
For those who hear him call...
... his name is...
C'THULHU
Turkish is offline   Reply With Quote
Old 04-10-2014, 03:26 PM   #1222
That is a good point...sending a note to have them both listed in lbs/in.
And yes it's 280 lbs/in for the Tarmacs, same drop.
- Andy
Old 04-12-2014, 01:12 PM   #1223
Turkish
Serial Cone Killer
Turkish's Avatar
So I am exchanging the koni yellows for bilstein b8's to be paired up with RCE Tarmac springs. Should I expect to need to have the shocks revalved or will they be good to go for autox and daily driving out of the box?
... his name is...
C'THULHU
Old 04-12-2014, 01:45 PM   #1224
gramicci101
Off Topic
- Andy
You might as well put both measurements on there. People will want to compare them to other companies' springs and every company does it differently.
The Following 3 Users Say Thank You to gramicci101 For This Useful Post:
major quicknap (04-16-2014), Racecomp Engineering (04-12-2014), Turkish (04-12-2014)
Old 04-12-2014, 09:07 PM   #1225
I wouldn't expect to need the revalve. It would give you a little more of an edge, but I'd probably try it first.
- Andy
Old 04-15-2014, 05:17 PM   #1226
Panman
Panman's Avatar
Drives: 86 GTS
Recommended "fast road" alignment
I'm looking for input on recommended "fast road" alignment for my car, effectively stock suspension, happy to add camber bolts either the Subaru Crash bolts or the Whiteline ones.
Would @Racecomp Engineering or @CSG Mike have any suggestions.
Panman is offline   Reply With Quote
Old 04-15-2014, 09:32 PM   #1227
CSG Mike
CSG Mike's Avatar
What do you like and dislike about your car's current setup? What kind of tires are you running? What kind of driving do you do? There's no one-size-fits-all with alignments.
Old 04-15-2014, 09:44 PM   #1228
Panman
Panman's Avatar
Drives: 86 GTS
Not unhappy with current setup particularly, but looking to optimize turn in a little more.
Tyres are currently Federal 595 RS-R in 225/40/18, going to Nitto Invo or NT05 on 17" when new wheels arrive. (225/45/17).
Driving: Occasional track, lots of canyon carving (Twisty hill driving), HPDE.
Currently on STI Pink springs (15mm Drop) on std Shocks, whiteline front tower bar, will be adding either Subaru or Whiteline camber bolts to the front.
Old 04-15-2014, 10:28 PM   #1229
CSG Mike
CSG Mike's Avatar
Maximize that from camber with the bolt. Zero toe front/rear, but you MAY want to consider a tiny bit of toe-out to promote rotation. Try zero toe first; it may already be a bit looser than you're used to.
You won't have any adjustment except toe in the rear.
-Mike
Old 04-15-2014, 10:28 PM   #1230
I'd say max out the camber bolt up front (keep it even), zero toe front, and a hair of rear toe-in. Rear camber is nonadjustable with your current set-up.
You won't have too much front camber, especially if you use the subaru camber bolt.
It will help turn-in and front/overall grip.
- Andy
Old 04-15-2014, 10:30 PM   #1231
-Mike
I think Mike likes more oversteer than me.
He's right though, if you can, try zero toe in the rear and see what you think.
- Andy
Old 04-15-2014, 10:45 PM   #1232
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
- Andy
I think Mike likes more oversteer than most people who like oversteer. lol
Air Suspension Discussion Thread - Let's Get Nerdy Andrew@ORT Suspension | Chassis | Brakes -- Sponsored by 949 Racing 174 02-13-2016 03:17 PM
RallySport Directs Everything Suspension thread!! RallySport Direct Brakes, Suspension, Chassis 21 07-02-2014 05:31 PM
The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension ModBargains.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 63 05-22-2013 08:15 AM
2012 Team USA vs the 1992 Dream Team ERZperformance Off-Topic Lounge [WARNING: NO POLITICS] 1 09-14-2012 06:19 PM
Team build thread; PROJECT.STH trueno86power Other Vehicles & General Automotive Discussions 0 03-02-2010 10:13 AM
