Old 04-08-2014, 11:23 PM   #1205
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Feeler gauge.
Bore gauge?
Old 04-09-2014, 01:00 AM   #1206
SubieNate
SubieNate's Avatar
Drives: 2013 FR-S Ultramarine
Originally Posted by solidONE View Post
Bore gauge?
Hopefully it's not of the no-go variety.
SubieNate is offline   Reply With Quote
Old 04-09-2014, 08:24 AM   #1207
GTHachiRoku
Big in Japan
GTHachiRoku's Avatar
Drives: turBRZ
@CSG Mike - I installed a set of Tein Street Flex coilovers and set them up to the recommended specs in the manual for the frs/BRZ. I measured as close as I could get and only the front passenger needs a tiny adjustment.
It seems great so far, especially for the street.
The ride is quite smooth, yet refined and feels more planted.
However I'd like to hear your recommendations for a track setup.
I'm hoping to get about -2.0 front camber and -1.5 to -2.0 rear camber.
As far as spring preload and ride height I'm clueless... And that's why I used Tein's recommendations.
I waiting for my new wheel/tire setup before I get an alignment.
GTHachiRoku is offline   Reply With Quote
Old 04-09-2014, 12:45 PM   #1208
FR-S Matt
Hmm, I'm getting some clunking noises from my Whiteline LCA's... I just recently put on KW V3's as well. Top hats are pretty secure so I'm positive it is not those clunking. Seems like the LCA's are able to move a bit more than they should. Any advice when I lift up the rear end this evening? Probably just a torquing issue or lack of torque on the camber adjustment nuts?
The clunking \ clacking noise I'm hearing is when the load changes slightly on the car even going 1-2 mph, over small hills, moving the steering wheel hard left or hard right adjusting weight.
Old 04-09-2014, 12:56 PM   #1209
Turbo Den
Drives: FRS, IS300, 911sc
Dear suspension gurus,
Would a smaller diameter tire increase suspension travel?
i am thinking going extreme like 225/45/15 tire on 15x8 wheels.
Currently, it feels like i hit the rear bump stop exiting a corner with full throttle when the tire hooks up.
current setting: Tein H-tech, Koni yellow, whiteline subframe bushing.
Turbo Den is offline   Reply With Quote
Old 04-09-2014, 01:06 PM   #1210
gramicci101
Off Topic
It won't increase suspension travel at all. You'll have more clearance in the fender because that tire is 1.5 inches shorter than the OEM tire. You'll also decrease ground clearance by .75 inches and mess up the speedometer. Will a 15 inch wheel even clear the brakes?
Old 04-09-2014, 01:20 PM   #1211
Racecomp Engineering
Mike and Andy.
I was just about to order some ball-jointed front lower control arms but I started thinking about the way in which impact forces would be distributed. I can't but help think that even small front impacts to the tyre/wheel would result in damage to the car frame in the long term and goodness knows what would happen in a larger impact. Given that my car is a daily driver I have decided that it would be best to leave the oem arms in place. (I replaced the bushes long ago with Avo units.) I track my car on Kumho V710 and I do not know if the standard front lca are up to the task. Should I be looking at reinforcing the stock arms or should I just wait and see what happens?
A lot of performance cars have forged aluminum lower control arms, including the new WRX. Food for thought.
- Andy
Old 04-09-2014, 01:21 PM   #1212
gramicci101
Off Topic
So what you're saying is to find a new WRX and swap their LCAs for ours? I feel like the owner of the WRX might get upset at that, so it's best if he doesn't know.
Old 04-09-2014, 01:22 PM   #1213
No, it won't increase suspension travel. It is "free" lowering, meaning it doesn't alter suspension geometry or reduce suspension geometry (though there are other drawbacks).
You probably are on the rear bumpstops.
- Andy
Turbo Den (04-10-2014)
Old 04-10-2014, 03:19 AM   #1214
Turbo Den
- Andy
Then, how I reduce chances of hitting the rear bump stop? I wish to achieve this with minimum new parts?
Shall I have another set of stiffer springs?
Remove the subframe bushing?
Old 04-10-2014, 08:26 AM   #1215
SportInjected
SportInjected's Avatar
Drives: for the sake of driving
Did you try stiffening up the konis's?
'13 Argento FR-S
SportInjected is offline   Reply With Quote
Old 04-10-2014, 08:39 AM   #1216
Turbo Den
Stiffening rear Koni makes the car too tail happy.
Old 04-10-2014, 12:29 PM   #1217
A taller spring or slightly trim the rear bumpstops. I prefer a spring that comes with replacement bumpstops properly designed.
Old 04-10-2014, 01:10 PM   #1218
Turkish
Serial Cone Killer
Turkish's Avatar
Drives: '14 BRZ - WRB Premium 6MT
RCE Tarmac springs.
For those who hear him call...
... his name is...
C'THULHU
Turkish is offline   Reply With Quote
The Following User Says Thank You to Turkish For This Useful Post:
Racecomp Engineering (04-10-2014)
Air Suspension Discussion Thread - Let's Get Nerdy Andrew@ORT Suspension | Chassis | Brakes -- Sponsored by 949 Racing 174 02-13-2016 03:17 PM
RallySport Directs Everything Suspension thread!! RallySport Direct Brakes, Suspension, Chassis 21 07-02-2014 05:31 PM
The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension ModBargains.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 63 05-22-2013 08:15 AM
2012 Team USA vs the 1992 Dream Team ERZperformance Off-Topic Lounge [WARNING: NO POLITICS] 1 09-14-2012 06:19 PM
Team build thread; PROJECT.STH trueno86power Other Vehicles & General Automotive Discussions 0 03-02-2010 10:13 AM
