Old 04-09-2014, 12:28 PM   #15
CSG David
CSG David's Avatar
Originally Posted by wparsons View Post
Not a fan of SPC's? I thought I saw your (or maybe Mike) recommend them in other threads.
SPC is fine if you daily. Don't do performance driving on them. SPC arms have been known to snap for performance driving on multiple platforms. The same thing will happen to the lower end LCAs.
Old 04-09-2014, 12:47 PM   #16
RYU
RYU's Avatar
Drives: really slow...
Which part of the LCAs you mentioned will fail? Is the heim joint or the actual aluminum structure itself?
I'm looking at the "lower" LCAs myself to add stroke.
RYU is offline   Reply With Quote
Old 04-09-2014, 01:19 PM   #17
CSG David
CSG David's Avatar
Usually the joint itself. To reduce cost, the rod end material, sizing, and strength rating are compromised. There is a prototype LCA being tested right now that addresses the stroke issue, but we can't talk about it.
Old 04-09-2014, 01:21 PM   #18
Deadspool
Much title. Wow.
Deadspool's Avatar
Drives: 2013 BRZ Sport-Tech
Slot the stock LCA's
kekekekekekekeke
༼ つ ◕_◕ ༽つI PUT A SPELL ON YOU ༼ つ ◕_◕ ༽つ
Deadspool is offline   Reply With Quote
Old 04-09-2014, 02:17 PM   #19
RYU
RYU's Avatar
I just noticed the Buddy Club rear LCA also lowers the damper mounting point. Anyone care to guess by how much? My guess is around ~15mm
The Following User Says Thank You to RYU For This Useful Post:
CSG David (04-09-2014)
Old 04-09-2014, 02:17 PM   #20
wparsons
wparsons's Avatar
Even the new design ones that are essentially the same construction as stock? I've read bad things about the old style, but have heard the new style ones are much better.
For reference, the ones pictured are the new ones, both styles shown in the video:
http://ft86speedfactory.com/spc-rear...e-kit-891.html
flickr
Old 04-09-2014, 02:25 PM   #21
RYU
RYU's Avatar
Well, it's about time!
Old 04-09-2014, 04:32 PM   #22
CSG David
CSG David's Avatar
My concern is how SPC still released a bad product into the market knowing it was bad to begin with. Only until there were sufficient issues did they decide to change the design. The engineering ethics involved in that release is like the Space Shuttle Challenger. Either way, I would not consider SPC to be a high quality design. While it might look the part, it does not always perform the part.
On another note on LCAs, most LCAs on the market have setting creep. The less camber change, the higher quality the LCA. SPL is probably the best LCA out on the market right now since it has had zero alignment creep after going through multiple track days. That's our experience after testing multiple LCAs already on the market.
The Following 4 Users Say Thank You to CSG David For This Useful Post:
fx35s (12-08-2014), serial gixxer (04-10-2014), Turkish (05-23-2014), wparsons (04-10-2014)
Old 04-09-2014, 04:36 PM   #23
gramicci101
Off Topic
Would it be feasible to drill safety wire holes in the adjustment nuts and safety wire them to keep them from creeping?
Old 04-09-2014, 04:45 PM   #24
CSG David
CSG David's Avatar
Possibility but not a guarantee. Something else is giving which causes the creep.
Old 04-09-2014, 04:48 PM   #25
gramicci101
Off Topic
That's unsettling. The only part that should be changing length is the adjustment mechanism. That's why I don't like the slide adjustment LCAs or offset bushings. Or camber bolts, for that matter. They have the potential to work themselves out of position with time.
Old 04-09-2014, 04:51 PM   #26
CSG David
CSG David's Avatar
Most people won't notice the changes. We're kind of a different species when it comes to really operating at the limit........................
Then again...that's what we're here for.
The Following User Says Thank You to CSG David For This Useful Post:
Old 04-09-2014, 04:54 PM   #27
gramicci101
Off Topic
If you look at some of the steel LCAs like the Buddy Club example posted earlier or Cusco, they don't even look that difficult to make. Have you considered just making your own to better fit your needs?
Old 04-09-2014, 05:47 PM   #28
CSG David
CSG David's Avatar
We did, but the market is too saturated and we feel it's not necessary to design something that has been addressed by multiple large manufacturers. We have a design developed if we want to pursue, but right now we'll push the Cusco, Whiteline, and SPL parts. SPC is fine for people who need a LCA but don't intend to do performance driving at all.
Need help deciding on Exhaust DannyFRS Engine, Exhaust, Transmission 1 02-23-2014 05:10 PM
Deciding on an exhaust JohnAyySays Engine, Exhaust, Transmission 32 12-28-2013 11:31 PM
What other car did you consider before deciding on the BRZ? txeng86 BRZ First-Gen (2012+) — General Topics 132 10-30-2013 03:49 AM
Deciding between... (help appreciated) rainmonkey Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 38 08-27-2013 03:53 PM
