#1191 |
Because compromise ®
Drives: Red Herring
1 dunk
2 drench 3 rinse 4 saturate 5 soak 6 sprinkle 7 squirt 8 steam 9 wash 10 wet 11 bathe 12 dip 13 humidify 14 lick 15 mist 16 moisturize 17 shower 18 sop 19 splash 20 splatter 21 spray 22 steep 23 water 24 rain on 25 wetten 26 water down 27 waterlog 28 flood 29 bath 30 douse 31 hose 32 submerge
| The Following 8 Users Say Thank You to Captain Snooze For This Useful Post: | andrew20195 (04-07-2014), Calum (04-05-2014), Dimman (04-05-2014), fatoni (04-08-2014), finch1750 (04-05-2014), fooddude (04-05-2014), PikachuBRZ (03-02-2023), SubieNate (04-05-2014) |
#1192 |
Off Topic
| The Following 2 Users Say Thank You to gramicci101 For This Useful Post: | Captain Snooze (04-04-2014), cdrazic93 (04-05-2014) |
#1193 | |
Junior
Drives: a car
#1194 |
Drives: Red Herring
Mike and Andy.
I was just about to order some ball-jointed front lower control arms but I started thinking about the way in which impact forces would be distributed. I can't but help think that even small front impacts to the tyre/wheel would result in damage to the car frame in the long term and goodness knows what would happen in a larger impact. Given that my car is a daily driver I have decided that it would be best to leave the oem arms in place. (I replaced the bushes long ago with Avo units.) I track my car on Kumho V710 and I do not know if the standard front lca are up to the task. Should I be looking at reinforcing the stock arms or should I just wait and see what happens?
#1195 |
crew chief
Drives: Race car FR-S
yeah i have the same concern as Captain, still debating about doing racerx front control arm for the race car. We have had a couple of hits before in the wheels and i was pissed i had to change a LCA on our car but thinking about it, it was better than trying to put the car straight again.
Is there a real benefit to those compared to doing Perrin offset bushing and Buddy club extended ball joint? |
#1196 |
Senior Addict
Drives: 86 GT
Hi guys, need some opinions on whether I should get adjustable LCA's (thinking of SPC) to correct my rear camber. I've sent my car for alignment work and this was the result:
Camber/Toe: LF: -1.4/0.2 RF: -1.6/0.0 LR: -1.8/0.0 RR: -2.1/0.2 I was told that my final rear camber couldn't be corrected any further (via toe adjustment) as I initially wanted to keep them under -1.5mm. I'm lowered only half inch from stock so I would have thought the rear camber wouldn't change that much from factory spec. Was recommended the whiteline LCA camber bush, but the labour charges to remove and fit these bushes were ridiculous. Getting the SPC arms would cost more but I'm sure I should be able to swap them out on my own. Car is a daily driver, no intention of track use. Advice? Last edited by Fizz; 04-08-2014 at 10:58 AM. |
#1197 |
Drives: 2013 FR-S Ultramarine
For daily you're probably just fine. Does it drive straight?
#1198 | |
Drives: 2013 GBS BRZ Limited
#1199 | |
Drives: FR-S Whiteout
#1200 | |
#1201 |
Senior Addict
Drives: 86 GT
#1202 | |
Senior Addict
Drives: 86 GT
By the way, how much camber adjustment can I get out of the SPC arms if used without the included offset toe bushings? Last edited by Fizz; 04-08-2014 at 10:02 PM. |
#1203 | |
#1204 |
Kuruma Otaku
Feeler gauge.
Because titanium. |
| The Following 3 Users Say Thank You to Dimman For This Useful Post: |
| Air Suspension Discussion Thread - Let's Get Nerdy | Andrew@ORT | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 174 | 02-13-2016 03:17 PM |
| RallySport Directs Everything Suspension thread!! | RallySport Direct | Brakes, Suspension, Chassis | 21 | 07-02-2014 05:31 PM |
| The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension | ModBargains.com | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 63 | 05-22-2013 08:15 AM |
| 2012 Team USA vs the 1992 Dream Team | ERZperformance | Off-Topic Lounge [WARNING: NO POLITICS] | 1 | 09-14-2012 06:19 PM |
| Team build thread; PROJECT.STH | trueno86power | Other Vehicles & General Automotive Discussions | 0 | 03-02-2010 10:13 AM |
