Old 04-04-2014, 11:22 PM   #1191
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Originally Posted by cdrazic93 View Post
32 way dampening
1 dunk
2 drench
3 rinse
4 saturate
5 soak
6 sprinkle
7 squirt
8 steam
9 wash
10 wet
11 bathe
12 dip
13 humidify
14 lick
15 mist
16 moisturize
17 shower
18 sop
19 splash
20 splatter
21 spray
22 steep
23 water
24 rain on
25 wetten
26 water down
27 waterlog
28 flood
29 bath
30 douse
31 hose
32 submerge
Old 04-04-2014, 11:49 PM   #1192
gramicci101
Off Topic
1-32
I don't know if I need a cigarette or a bath after reading that.
Old 04-05-2014, 12:03 AM   #1193
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
1 dunk
2 drench
3 rinse
4 saturate
5 soak
6 sprinkle
7 squirt
8 steam
9 wash
10 wet
11 bathe
12 dip
13 humidify
14 lick
15 mist
16 moisturize
17 shower
18 sop
19 splash
20 splatter
21 spray
22 steep
23 water
24 rain on
25 wetten
26 water down
27 waterlog
28 flood
29 bath
30 douse
31 hose
32 submerge
there's somethin else goin on there lol
Old 04-06-2014, 07:12 AM   #1194
Captain Snooze
Drives: Red Herring
Mike and Andy.
I was just about to order some ball-jointed front lower control arms but I started thinking about the way in which impact forces would be distributed. I can't but help think that even small front impacts to the tyre/wheel would result in damage to the car frame in the long term and goodness knows what would happen in a larger impact. Given that my car is a daily driver I have decided that it would be best to leave the oem arms in place. (I replaced the bushes long ago with Avo units.) I track my car on Kumho V710 and I do not know if the standard front lca are up to the task. Should I be looking at reinforcing the stock arms or should I just wait and see what happens?
Old 04-06-2014, 07:59 AM   #1195
puma
crew chief
puma's Avatar
Drives: Race car FR-S
yeah i have the same concern as Captain, still debating about doing racerx front control arm for the race car. We have had a couple of hits before in the wheels and i was pissed i had to change a LCA on our car but thinking about it, it was better than trying to put the car straight again.
Is there a real benefit to those compared to doing Perrin offset bushing and Buddy club extended ball joint?
puma is offline   Reply With Quote
Old 04-08-2014, 10:46 AM   #1196
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Hi guys, need some opinions on whether I should get adjustable LCA's (thinking of SPC) to correct my rear camber. I've sent my car for alignment work and this was the result:
Camber/Toe:
LF: -1.4/0.2 RF: -1.6/0.0
LR: -1.8/0.0 RR: -2.1/0.2
I was told that my final rear camber couldn't be corrected any further (via toe adjustment) as I initially wanted to keep them under -1.5mm. I'm lowered only half inch from stock so I would have thought the rear camber wouldn't change that much from factory spec.
Was recommended the whiteline LCA camber bush, but the labour charges to remove and fit these bushes were ridiculous. Getting the SPC arms would cost more but I'm sure I should be able to swap them out on my own.
Car is a daily driver, no intention of track use. Advice?
Fizz is offline   Reply With Quote
Old 04-08-2014, 03:30 PM   #1197
SubieNate
SubieNate's Avatar
Drives: 2013 FR-S Ultramarine
For daily you're probably just fine. Does it drive straight?
SubieNate is offline   Reply With Quote
Old 04-08-2014, 03:41 PM   #1198
Zenith/Nadir
Drives: 2013 GBS BRZ Limited
Camber/Toe:
I would do whiteline camber bolts up front and H&R bolts in the rear just to even them out side to side, but I'm super weird about stuff like that.
Zenith/Nadir is offline   Reply With Quote
Old 04-08-2014, 06:29 PM   #1199
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Camber/Toe:
Haha I had to read that over, cause somehow I read "camel/toe" the first time. What do you use to measure camel toe anyhow? A depth gauge?
Old 04-08-2014, 06:41 PM   #1200
CSG Mike
CSG Mike's Avatar
Camber/Toe:
If it drives straight for a daily driver, I w ouldn't worry about it. IMO, getting toe set proper is more important than camber for a daily driver, and you have toe adjustability.
CSG Mike is online now   Reply With Quote
Old 04-08-2014, 09:46 PM   #1201
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Old 04-08-2014, 09:49 PM   #1202
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
If it drives straight for a daily driver, I wouldn't worry about it. IMO, getting toe set proper is more important than camber for a daily driver, and you have toe adjustability.
Thanks....yeah it drives straight as an arrow.
By the way, how much camber adjustment can I get out of the SPC arms if used without the included offset toe bushings?
Old 04-08-2014, 10:22 PM   #1203
CSG Mike
CSG Mike's Avatar
The exact range will depend on your right height, and how you set it up, but I'd expect to get more than you'll ever need
Old 04-08-2014, 10:27 PM   #1204
Dimman
Kuruma Otaku
Dimman's Avatar
Feeler gauge.
Because titanium.
Air Suspension Discussion Thread - Let's Get Nerdy Andrew@ORT Suspension | Chassis | Brakes -- Sponsored by 949 Racing 174 02-13-2016 03:17 PM
RallySport Directs Everything Suspension thread!! RallySport Direct Brakes, Suspension, Chassis 21 07-02-2014 05:31 PM
The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension ModBargains.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 63 05-22-2013 08:15 AM
2012 Team USA vs the 1992 Dream Team ERZperformance Off-Topic Lounge [WARNING: NO POLITICS] 1 09-14-2012 06:19 PM
Team build thread; PROJECT.STH trueno86power Other Vehicles & General Automotive Discussions 0 03-02-2010 10:13 AM
