Old 04-07-2014, 10:48 PM   #1
natesparxxx
natesparxxx's Avatar
Drives: 2013 Whiteout Scion FR-S
Deciding on LCA's.
I'm in an indecisive struggle between the three.
Voo doo
Stance
Agency power
Agency powers are the most expensive. But does that mean they're the best?
And voo-doo & stance are very similar.
I know that the stance ones have been out for awhile and a lot of people are riding them.
But voo-doo's just released and it seems like everyone has them pretty hyped up.
There might be threads about this. But I just wanted to know the highest rated out of the 3 alone.
Thanks
natesparxxx is offline   Reply With Quote
Old 04-08-2014, 01:11 AM   #2
boredom.is.me
Custom User Title
boredom.is.me's Avatar
Drives: Asphalt FR-S MT
Why do you want LCA's?
Old 04-08-2014, 01:13 AM   #3
natesparxxx
I'm lowered and my Tires are rubbing. Mainly because I need more camber.
Old 04-08-2014, 01:20 AM   #4
boredom.is.me
Custom User Title
AP
Voodoo
Stance
If it is JUST for camber correction, SPC are $200 and get the job done. (I have them.) All of the others will increase NVH a little, but I'm not really one to talk about it. Just dropping these pics here.
Ninja edit: I'm not sure if the SPC will give you more camber.
Old 04-08-2014, 01:24 AM   #5
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
Vodoo and stance to note drop position by near an inch. That means for STs, KWs they're beneficial to add stroke. Now that said what could you have anyhow? Cause if mono tube could like a BC, etc then go with something more conventional like Cusco, white line etc...
The Following 2 Users Say Thank You to OICU812 For This Useful Post:
CSG David (04-08-2014), ThatManAnt (08-17-2014)
Old 04-08-2014, 11:01 AM   #6
natesparxxx
I have yonaka. And can drop up to 4 inches on them. I'm not maxed out but plan to be if I can tuck more from camber.
I'm just really sketched out by fender rolling. Especially since our cars are so new.
Old 04-08-2014, 11:02 AM   #7
natesparxxx
I only rub on hard bumps and turns at a decent speed.
Old 04-08-2014, 06:05 PM   #8
*KID*
86-er
*KID*'s Avatar
Drives: BRZ tS
What about the Buddy Club LCA. I want to flatten my rear axles as much as I could.
2018 Subaru BRZ ts 020/500 - My Daily, work car, and track car
*KID* is offline   Reply With Quote
Old 04-08-2014, 06:20 PM   #9
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Drives: Whiteout Scion FR-S
what about Parts by maxi?
Old 04-08-2014, 06:51 PM   #10
wparsons
wparsons's Avatar
If you don't want bling, just function, get the SPC arms. They look like OEM, and are like 1/3rd the price of other options. They also retain the stock bushings, so you don't have increased maintenance of spherical bearings.
flickr
unsurety (04-09-2014)
Old 04-08-2014, 09:01 PM   #11
Cjymiller
Original 2013 Owner
Cjymiller's Avatar
Drives: 13 BRZ, Galaxy Blue Silica
I'm lost when it comes to the differences in control arms. Does someone have some literature I can use to educate myself. I'm trying to determine how different brands provide different value.
Anything helps.
Perrin Headerback, OFH, OFT, Ohlins R&T MI20, 17x9 Weds TC105N, Hankook RS4 (235/40), TOM's JDM Tails, PCV AOS, Perrin Crank Pulley, Perrin Rear Trans. Mount, Whiteline Shift Bushing, SS brake Lines, Hawk DTC60, Bayson R Lip Kit, LED Lighting , Smoked JDM Sidemarkers, Rear Fog Enable, Carsmo Armrest, Grimmspeed Plate Relocater
φφκα
Cjymiller is offline   Reply With Quote
Old 04-08-2014, 09:14 PM   #12
CSG David
CSG David's Avatar
Anything helps.
Every one of those listed that are not Cusco, Whiteline, or SPL, will not be so good for any type of performance use. If you don't drive the car, however, any of those LCAs will work fine because it doesn't see any type of load.
The Following User Says Thank You to CSG David For This Useful Post:
JohnJuan (05-23-2014)
Old 04-08-2014, 10:21 PM   #13
wparsons
wparsons's Avatar
Not a fan of SPC's? I thought I saw your (or maybe Mike) recommend them in other threads.
flickr
Old 04-08-2014, 11:44 PM   #14
supramkivtt2jz
PROUD OF BOXER
Drives: Raven FR-S
to the best of my knowledge, they have never recommended SPC over any of the other three for any reason what-so-ever. whiteline, spl, and cusco are far superior in every way. If simple adjustment is the driving factor behind the purchase, nearly any arm will do.
supramkivtt2jz is offline   Reply With Quote
Need help deciding on Exhaust DannyFRS Engine, Exhaust, Transmission 1 02-23-2014 06:10 PM
Deciding on an exhaust JohnAyySays Engine, Exhaust, Transmission 32 12-29-2013 12:31 AM
What other car did you consider before deciding on the BRZ? txeng86 BRZ First-Gen (2012+) — General Topics 132 10-30-2013 04:49 AM
Deciding between... (help appreciated) rainmonkey Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 38 08-27-2013 04:53 PM
