Old 04-08-2014, 03:45 PM   #1
post_break
Professional Smartass
post_break's Avatar
Drives: White Out FRS
Question about wideband and software tuning
This is kind of a dumb question, but are widebands only used as a gauge? Like, they are only used for you to observe, not to actually implement into a tune as a variable correct?
So I guess I'm asking that if I were to install a wideband gauge, it does not connect to the car other than power and ground, and the tune is none the wiser.
I've been reading up on the technology but so far it's all been theory. Care to enlighten on a noob?
post_break is offline   Reply With Quote
Old 04-08-2014, 03:48 PM   #2
nelsmar
Typically they are not incorporated with the tune its self. However some people (myself included) wire in a wideband to the ECU for easier datalogging. A few of us have made custom tables in ecutek (and other platforms) to log and trigger maps etc based on wideband events. It is possible for example to make a failsafe for lean conditions in positive boost conditions.
But most tunes typically do not utilize the wideband its self.
My flickr - Canibeat
Local magazine scout
The Following User Says Thank You to nelsmar For This Useful Post:
post_break (04-08-2014)
Old 04-08-2014, 03:49 PM   #3
xjohnx
Grip>Slip
xjohnx's Avatar
The wideband's 5V output can be connected to the OEM ecu by using the rear o2 harness. This at the very least gives the your ECU the abilitiy to read and log actual wideband afr, not sure what capabilities this extends to the tuner beyond that point though. @moto-mike, @DeliciousTuning?
Old 04-08-2014, 03:50 PM   #4
AdrianG
Generally Well Liked
Drives: '08 STi Hatch, '11 Outback 3.6R
What tuning platform are you using?
With Tactrix you can log it directly, the op2 has it's own input. With Ecutek you can connect it to the secondary o2 sensor and have a custom map to handle the input. OFT support is going to be similar to Ecutek and is going to be ready very soon as a package from Vishnu.
- AdrianG
AdrianG is offline   Reply With Quote
Old 04-08-2014, 03:54 PM   #5
post_break
post_break's Avatar
Secondary O2 sensor will be a no-go since that's what my tuner uses for E85 content for flex fuel. I'll have to see about the Evap wire he tapped in the glove box. Thanks for the info so far!!!
Old 04-08-2014, 10:53 PM   #6
Xero-Limit
Xero-Limit's Avatar
Drives: JDL Turbo FRS, 335SC BRZ (ret)
Originally Posted by xjohnx View Post
The wideband's 5V output can be connected to the OEM ecu by using the rear o2 harness. This at the very least gives the your ECU the abilitiy to read and log actual wideband afr, not sure what capabilities this extends to the tuner beyond that point though.?
With that being an input, we can actually do full time closed loop based off of the wb02, and also do compensation maps to err on the side of safety. So this would be something like this: AFR >12, Boost > 8, then timing drops by an x amount or fueling is enriched by x. So all those AEM failsafe features that (work really well) can be emulated from within the ECU.
Xero-Limit is offline   Reply With Quote
The Following User Says Thank You to Xero-Limit For This Useful Post:
xjohnx (04-09-2014)
Tuning Software CaptivaBlueTeg New England 4 09-17-2015 04:16 AM
EcuTek Announce FT86 Retail Tuning Software EcuTek Software Tuning 326 05-17-2015 02:31 PM
EcuTek End User/Retail Tuning Software Release! Dustin@Dynosty Forced Induction 27 12-19-2013 10:17 AM
FS: Unichip w/download cable and tuning software carlitosway6891 Engine, Exhaust, Bolt-Ons 7 10-07-2013 12:21 AM
Innovate Wideband Air/Fuel Ratio LC-1 Wideband Kit **Special Price** Titanmotorsports Audio/Visual, Electronics, Infotainment, NAV 2 09-14-2012 01:42 PM
