| Software Tuning Discuss all software tuning topics. |
#15 |
Calle Atun
Drives: 13 FRS, 93 Mr2, 85 ae86
I am very interested in this too. This system is so complicated that most professional tuners are not really sure what to do with the DBW tables. I wanted to log and see if the throttle really does start to close myself.
#16 |
^^ If you look at the log in my original post you can see the throttle closing as the revs climb. It's pretty consistent in all the logs I've pulled.
If anyone happens to poke around my datazap logs and see one with 100% throttle it's because I edited it for virtual dyno and uploaded the wrong version.
#17 |
Calle Atun
I logged my stock frs last night and the throttle position showed 80.4% the whole time. Does anyone know why it's not at 100%?
#18 | |
Drives: FT86
http://datazap.me/u/steve99/brz-g-se...zoom=1737-2172 |
#19 | |
Drives: FT86
#20 |
Throttle plate opening position is different to the Throttle pedal position for reasons jamesm stated earlier referencing mad_sb's thread.
Toyota John probably hadn't differentiated between the two. |
#21 |
Calle Atun
I was looking at "Throttle position" using ECUTek. There is also "accelerator angle" which I think is the peddle position. MY car is completely stock other than I am using ECUTek. I wonder if because I am stock with no power adders like an exhaust I am not making enough power for the ECU to pull the power back at the higher RPM range? I am also using the stock DBW tables from B01C. It seem to me from reading about the DBW tables that it is torque based and maybe when it sees the high torque in your cars it is closing the throttle to limit the torque output? List what parts you have added and if you are using the stock DBW table.
#22 |
Mostly stock, just a 2.5" perrin catted front pipe and resonated cat-back and OFT. Mine doesn't fall off to 80%, but it definitely tapers off to about 90% consistently. Running the 1.56b Stage 1 OTS map, no tweaks yet.
#23 | |
Drives: UK GT86
.: Stealth 86 :.
#24 | |
My Other Ride's a Jeep
Drives: 2013 BRZ Limited
I did realize that I am not pushing the throttle 100% though. I used to bury it into the floor and I noticed that full throttle is not as WOT as buried in the floor WOT. Here is an old log that goes over 100% http://www.datazap.me/u/luckrider/hi...oom=9912-10226 |
#25 | |
Calle Atun
#26 |
Calle Atun
I have been told that 80% throttle opening on ECUTEK is WOT.
#27 |
That's not the case with OFT, unless it opens more than 100% at times. Mine peaks at about 98%, but tapers to 90% as the revs climb.
#28 |
Drives: 2013 Firestorm FRS
this just confirms my undying hatred for DBW
| The Following User Says Thank You to continuecrushing For This Useful Post: | roddy (06-30-2014) |
