Old 08-10-2013, 09:18 AM   #15
WolfSongX
WolfSongX's Avatar
Drives: 2013 Subaru BRZ Limited SWP
I am swallowing a bit of pride here, but I got the amp working this morning. I was adjusting my suspension last night and the door speakers started to work intermittently when we took the car for a test drive. I removed the camera power wire this morning and it was working properly after that.
Obviously, I had a short in the camera that was causing my issue. So the good news is that I don't have to rush into the audio upgrade. The bad news is that I'll have to figure out what happened to the camera and decide if it's salvageable.
I guess the moral of the story is to not assume that my work was faultless.
Derek
2013 BRZ Limited SWP
Professional driver in search of closed course..
WolfSongX is offline   Reply With Quote
Old 08-10-2013, 11:21 AM   #16
rbizzle004
I have the same problem. I just installed new door speakers and an amp. the amp turns on and "pops" the speakers when it turns off. but I'm not getting any noise like the pre out is bad. I even tried two different cables.
Sounds like a bad ground.
rbizzle004 is offline   Reply With Quote
Old 08-10-2013, 03:40 PM   #17
Leonardo
Country Boy 4 Life
Leonardo's Avatar
I thought the same thing. But after checking my 2aug ground, it was good. I found a headphoone to rca cable and connected it to my cell phone and amp. I hook my door speakers up correctly, the work. I figured out the pre out on my deck does not work. I spliced onto the small amps stock input, and converted it to rca, now it all works. Not how I was planning on hooking it up.... Lanzar 6.5 midbass drivers in the doors, 4" lanzars in cash, a 4 channel poweracoustic amp hooked to the doors, and an old Pioneer 5.25 inch powered sub. Sounds better than I thought... Sorry for thread jacking ...
Old 04-05-2014, 11:42 PM   #18
blewclouds
blewclouds's Avatar
Drives: Galaxy Blue Silica BRZ 2013
Turns out I had the same problem with my door speakers. I ended up bypassing the amp since clearly it was a blown out POS. FYI: all my connections were intact, all my fuses was intact. Factory amp was the problem.
2013 Galaxy "Your My Boy" Blue Silica / blewclouds / Build Thread:
http://www.ft86club.com/forums/album.php?albumid=1401
blewclouds is offline   Reply With Quote
Old 04-06-2014, 04:05 AM   #19
blewclouds
blewclouds's Avatar
Originally Posted by kberkel View Post
Cool cool, thanks for the info. Good luck!
I'm also not used to more than 4 speakers in a car. Hoping it won't be too hard to amp some speakers and still have everything sound good. I'm not even sure if there's even a crossover for the dash speakers I'm gonna lurk the electronics forum for a few weeks.
So you're running the dash speakers and the rears on the HU? So I guess you'll run RCAs to an amp to power the doors? Just learning here
From what I had gathered from other posts on the forums is that the factory dash speakers have a built in crossover. Don't quote me on that if it's true. However, I've installed aftermarket Alpine 4" speakers.
As far as I'm concerned with my aftermarket HU there are RCA's for amp. However, since the car has outputs for eh factory amp to run the door speakers, So I'm just going to use those outputs and replace my amp with an Alpine thanks to zdr93523 post listed here:
http://www.ft86club.com/forums/showthread.php?t=42239
I don't plan to install a separate amp for my speakers but will install a separate amp once I decide to get a sub, at this point I would probably use the RCA's.
The Following User Says Thank You to blewclouds For This Useful Post:
kberkel (04-07-2014)
Old 04-07-2014, 09:06 PM   #20
kberkel
kberkel's Avatar
Cool thanks for the info
kberkel is offline   Reply With Quote
Old 04-09-2014, 03:43 AM   #21
blewclouds
blewclouds's Avatar
So turns out after I installed the Alpine amp I'm getting some feed/hissing. After I did some troubleshooting, I thought it was from the amp but it isn't. Obviously when I increase the gain from the amp the hissing noise is louder which sucks because I was hoping the gain would just make my speaker bump more. So turn out the brand new aviv-8000nex is a piece of shit. For some reason the front speaker feeds produce a hissing sound to the speakers. I tried grounding the HU wires to actual chassis but no luck. I even went as far as adding some resistors which helped a mili-bit. I guess after looking at forums, they weren't kidding about pioneer head units (beware). If you might know something I don't know or if anyone has any suggestions I would greatly appreciate it!
Old 08-27-2014, 09:40 AM   #22
sunrisecirrus
sunrisecirrus's Avatar
Drives: 2014 BRZ Limited
My "AMP" 15 amp fuse was blown when i got my new 2014. I was wondering why it didnt sound right. I put the spare in and replaced the spare with a new fuse from autozone. Thanks for the post, it was how i figured the issue out. The speakers in the door now work and sound great.
sunrisecirrus is offline   Reply With Quote
Old 04-03-2022, 06:48 PM   #23
Zeith
Drives: 2015 BRZ
Thumbs up Thank you
Originally Posted by jpit View Post
There is a fuse dedicated to the door speaker amp and it is in the fuse box on the driver's side. It is labeled AMP and it is number 15 right on the edge.
In all honesty I thought I was going crazy. Just bought my 2015 BRZ a week ago, and had no sound in the door speakers. Had them in the front and back though. I checked the amp fuses under the hood and they where perfect, didn't realize there was one more under the drivers dash.
Thanks man!
Zeith is offline   Reply With Quote
The Following User Says Thank You to Zeith For This Useful Post:
soundman98 (04-03-2022)
Old 04-03-2022, 07:03 PM   #24
soundman98
ProCrastinationConsultant
soundman98's Avatar
thanks for searching!
interior light DOOR mode not working shaoster Electronics | Audio | NAV | Infotainment 11 01-24-2020 03:10 PM
wire routing for door speakers derka-derka Electronics | Audio | NAV | Infotainment 6 12-13-2012 09:49 PM
Front door speakers. Calum Electronics | Audio | NAV | Infotainment 5 08-11-2012 04:49 PM
Just replace door speakers? industrial Electronics | Audio | NAV | Infotainment 0 08-02-2012 02:57 PM
Installed new in-dash, lost sound from door speakers Nitro Electronics | Audio | NAV | Infotainment 2 06-04-2012 08:53 PM
