Old 04-04-2014, 12:21 PM   #925
AustinTX
Pawn in game of life
AustinTX's Avatar
Drives: 19 STX BRZzz
I don't believe I'm hitting them at full length.
Autocross nut
AustinTX is offline   Reply With Quote
Old 04-04-2014, 02:40 PM   #926
jam0o0
Drives: 2013 FR-S, hot lava
congrats john. you blew us all out of the water.
jam0o0 is offline   Reply With Quote
The Following User Says Thank You to jam0o0 For This Useful Post:
AustinTX (04-04-2014)
Old 04-04-2014, 02:43 PM   #927
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
you would not know it if you did though... their engagement is smooth and the rate progressive for another inch/inch and half. The fronts actually get engaged quite a bit at any hint of spirited cornering.
when one "feels bumpstops" its when they compress the entire thing going over a big bump, obviously not a scenario at an autocross.
Old 04-04-2014, 04:27 PM   #928
AustinTX
AustinTX's Avatar
Funny how you almost always believe that everyone else is either wrong or they don't understand. You are posting in a thread full of people who have been there and done that many times, so don't discount their opinions for your own so easily. Either way, you are free to trim them. I don't plan on it, though.
Autocross nut
The Following User Says Thank You to AustinTX For This Useful Post:
Wepeel (04-04-2014)
Old 04-04-2014, 06:25 PM   #929
xwd
With my MCS CS shocks I ran them with no bump stops initially, which was technically not legal. They have no dust boots, and I used the tie wrap around the shaft trick to find out my shock travel was. According to some "stock" experts (at former national champs) just using the tie wrap would actually qualify as a valid bump stop for stock class...
I would have been on the bump stops on a couple courses, but for the most part I wouldn't have hit them even with the MCS shocks compression set fairly low, which was just a small amount above stock based on shock dyno charts. This was with 245 Hoosiers and the parts where I thought I would be close was in heavy transition courses, and also one where there was a large ridge in the course.
So no this car is not like a Miata where the bump stops are hit all the time and more critical to suspension performance. I would say at least on street tires it would be rare to hit them.
The Following 2 Users Say Thank You to xwd For This Useful Post:
jdrxb9 (04-05-2014), Wepeel (04-04-2014)
Old 04-04-2014, 07:35 PM   #930
n8dog11914
n8dog11914's Avatar
Drives: 2013 WRB Subaru BRZ 6MT
Hey Guys,
Check out my setup here for CS.
http://www.ft86club.com/forums/showthread.php?t=62401
Any help on the tire pressures would be greatly appreciated!
n8dog11914 is offline   Reply With Quote
Old 04-04-2014, 10:37 PM   #931
vroom4
Lower.
vroom4 is offline   Reply With Quote
Old 04-07-2014, 05:36 PM   #932
cy1clown
Took my FR-S to her first autoX yesterday. It was the most fun you can have with your cloths on. I have autoxed before but in front wheel drive cars. The difference in fun factor is huge. Rear wheel drive is just sooo much more fun.
I have not seen the results yet but I am a terrible driver, and I was on stock tires.
Still Grinning
Jon
cy1clown is offline   Reply With Quote
The Following User Says Thank You to cy1clown For This Useful Post:
malave7567 (04-07-2014)
Old 04-07-2014, 05:41 PM   #933
malave7567
malave7567's Avatar
Drives: (formerly) 2013 Raven FR-S
Still Grinning
Jon
That's the best part of auto-x, the fun factor, especially in this car. I can't wait til I can get back out there myself, although my car is in STX class.
malave7567 is offline   Reply With Quote
Old 04-07-2014, 08:25 PM   #934
Thrustin
Drives: 2014 BRZ Limited, 2013 Focus ST
I took the BRZ out for the first event (that wasn't in the low 30's, raining and miserable) yesterday. I was very impressed with the car. Only having 215/45/17 (ZIIs), I thought the ass end might get a little squirrely. While it did move, it felt very controllable.
Here's a video of the my best run yesterday. It was good enough for 5th in CS. There were some fast drivers out there. The course was huge and sweeping. Beautiful day as well.
[ame="http://www.youtube.com/watch?v=lW_qMkxg05E"]Justin Best Run Wilmington 4:6:14 - YouTube[/ame]
Thrustin is offline   Reply With Quote
Old 04-07-2014, 08:57 PM   #935
engee
Drives: Subaru
I have a question for some of you guys with koni's installed.
How on earth did you torque the top lug nuts to spec? I can't seem to get them to torque because the shaft has been spinning as well. I was hoping that maybe after I put them on the car it might be easier. Any thoughts or comments on how you guys got it done?
engee is offline   Reply With Quote
Old 04-07-2014, 09:22 PM   #936
Sccabrz192
Detroit Region, MI
Sccabrz192's Avatar
Drives: 13 BRZ, 13 Volt, 02 WRX
I use craftsman Max Axess sockets and ratchets, they allow you to put another socket through it to hold the anti-rotation feature on the rod. Once its seated and snugged up, you should be able to drive the torque to spec with a standard socket and torque wrench, just watch the rod closely to make sure it doesn't clock with your torque.
http://www.sears.com/craftsman-80pc-...4&blockType=G4
one of the best tool kits I own, handy for all kinds of stuff.
Detroit / NWOR SCCA Member
2005-06: #192 ES 91 MR2 N/A Hardtop
2007-08: #54 STX 05 WRX Sedan
2009-12: #92 BSP/ASP 07 Solstice GXP
2013-14 : #192 CS 13 Subaru BRZ
Sccabrz192 is offline   Reply With Quote
The Following User Says Thank You to Sccabrz192 For This Useful Post:
engee (04-07-2014)
Old 04-07-2014, 09:33 PM   #937
Sccabrz192
Detroit Region, MI
Sccabrz192's Avatar
The countdown is on to the Wilmington Match Tour at the end of the week. CS looks like it will be a blast... we're up to 13 entries, and I'm looking forward to my first runs on the Wilmington concrete!
Anyone have any plans to grab a bite either friday or saturday night?
Old 04-07-2014, 09:35 PM   #938
engee
Drives: Subaru
That definitely helps. I have the 3/8 max access set. I could've sworn I couldn't get a socket through the pass through hole though. I'll try again this weekend. Hopefully, I'll be able to get it done. I'm trying to finish prep before a test and tune and the national tour. :/
Cinco De Mayo SCCA SOLO Ryeong86 NY / NJ / CT / PA 0 04-23-2013 05:22 PM
Koni Sports in SCCA SOLO Ryeong86 Tracking / Autocross / HPDE / Drifting 4 04-22-2013 12:58 PM
2013 Preliminary SCCA SOLO and PRO SOLO National Schedule Scooby South Tracking / Autocross / HPDE / Drifting 13 12-05-2012 08:08 AM
Houston SCCA Solo #9 - 5 FRS, 1 BRZ hankster Tracking / Autocross / HPDE / Drifting 0 10-09-2012 01:35 PM
SCCA Solo Car Class for the FR-S/BRZ? MrVito Scion FR-S / Toyota 86 GT86 General Forum 31 06-15-2012 10:03 AM
