Old 04-07-2014, 08:35 AM   #15
AdamBomb518
Stealth ***e
AdamBomb518's Avatar
Originally Posted by unvevo View Post
On the topic of legality. How often are yall driving in reverse on a public road? Although I agree you should not delete your backup lights I'm just wondering how often you are backing on public roads.
Anytime you ever back out of a parking spot or space anywhere... Also, for passing inspection you need to have working reverse lights.
I'd be more worried about not having them, someone smashing into me while I'm backing up, ruining my car, and getting sue'd because I didn't have working reverse lights.
AdamBomb518 is offline   Reply With Quote
Old 04-07-2014, 12:36 PM   #16
STS-V
Please guys, troll elsewhere. I asked for a suitable replacement, IE leaving the lights intact and removing the red "V" as instructed. If I wanted to spray paint it black, I would.
Even if there was a housing that fit, or came close to fitting, that was the reverse lights only it would look much better.
STS-V is offline   Reply With Quote
Old 04-07-2014, 12:40 PM   #17
AdamBomb518
Stealth ***e
You could probably just use ABS plastic and cut to size/heat/bend how you wanted it to fit the space. Or 3M it over the factory piece, or even with cutouts for the reverse light part.
The Following User Says Thank You to AdamBomb518 For This Useful Post:
STS-V (04-07-2014)
Old 04-07-2014, 12:58 PM   #18
Turbo95eg6
Turbo95eg6's Avatar
Drives: 2014 BRZ SWP LTD
To be fair, the title and your posts ask how to remove the reverse lights.
The Following 2 Users Say Thank You to Turbo95eg6 For This Useful Post:
Husker BRZ (04-08-2014), Tuan (04-07-2014)
Old 04-07-2014, 01:23 PM   #19
Tuan
Tuan's Avatar
Drives: Whiteout FRS
Send a message via AIM to Tuan
Maybe you should clarify your original post which implies you want to get rid of the entire reverse lamp assembly, not "leaving the lights intact"
Don't see any clear reverse lamp lenses available for the FRS. Some people have tinted the entire assembly red to remove the red triangle if that works do for you.
Tuan is offline   Reply With Quote
The Following User Says Thank You to Tuan For This Useful Post:
STS-V (04-07-2014)
Old 04-07-2014, 01:38 PM   #20
STS-V
Thank you two for the helpful responses. That might be the best idea.
Old 04-07-2014, 01:44 PM   #21
Turbo95eg6
Turbo95eg6's Avatar
I like the triangle… Just get a fog light conversion for it, it will look nice.
Old 04-07-2014, 08:24 PM   #22
unvevo
unvevo's Avatar
Drives: 3-240sx, supra, brz, 2500hd dmax
You could always have it shaved off. If you are worried about being legal, you should only need a white light emitted when the car is in reverse. You could do a small led strip on the license plate or something.
unvevo is offline   Reply With Quote
The Following User Says Thank You to unvevo For This Useful Post:
STS-V (04-07-2014)
Old 04-08-2014, 05:45 PM   #23
HotSauce
Drives: 2013 Scion Fr-s Firestorm
I'm about to do this http://www.ft86club.com/forums/showthread.php?t=45762 and remove the oem reverse light and paint it black to match the bumper if the hole it leaves if it is to out of place
HotSauce is offline   Reply With Quote
Old 04-08-2014, 06:39 PM   #24
Wonderbar
Driveway labs.
Wonderbar's Avatar
Drives: '13 BRZ Limited, 6sp, SWP
I've got all my parts for a tiny led light bar. Expect photos this week.
-'13 Subaru BRZ Limited, SWP. (Mods: Driveway Labs full aero, MCA, etc)
-'06 Mitsubishi Eclipse 3.8L, UV blue. (Mods: turbocharged, full suspension, too much to list)
-'13 Town and Country Limited (Mods: too many kids)
Wonderbar is offline   Reply With Quote
The Following User Says Thank You to Wonderbar For This Useful Post:
mokinbird87 (04-10-2014)
Old 04-08-2014, 08:15 PM   #25
unvevo
unvevo's Avatar
That DIY is nice! Good find.
Old 04-08-2014, 09:51 PM   #26
STS-V
in for photos
Old 04-09-2014, 07:48 PM   #27
ShutterSpeed
Drives: Olive Drab/Army FRS
Just installed the Intec Japan tail lights that have the reverse lights inside the of them. So i'll be removing the triangle bar and replacing with a black wire mesh. Hoping it'll act similar to the Golden Eagle diffuser holes on civics. My bumper is a big parachute with the Tomei 60R hanging out back there.
QUALITY OVER QUANTITY
ShutterSpeed is offline   Reply With Quote
Old 04-09-2014, 08:28 PM   #28
STS-V
pics of mesh over triangle please
Zeta Performance - Lights (HID, LEDs, LED Taillights, LED Reverse Light, Trunk Light) ZetaPerformance Exterior Parts - Lighting 172 11-13-2015 10:25 AM
reverse light jdmblood Cosmetic Modification (Interior/Exterior/Lighting) 8 09-08-2013 07:17 PM
For Sale: Smoked/Red/Clear Reverse Light + Brake Light Bars Brand New! Vicious LED Exterior Parts (Aero, Lighting, Etc.) 9 08-25-2013 07:26 PM
**Valenti Japan LED Tail Light & Rear Bumper Reverse LED Light** nigel-jdmparts Exterior Parts - Lighting 13 04-30-2013 12:14 PM
