Old 04-07-2014, 10:54 AM   #15
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Originally Posted by Fuco View Post
I just had mine installed about two weeks ago. First FRS/BRZ to get one besides the prototype. I love it. Sounds like a jet engine and it can get up to 80 in a couple seconds. It can go up to 12 psi, but I have it set to 8 psi right now.
There is one problem. The engine stalls out occasionally when I'm going about 5 m.ph., I'm not giving it any gas, and it doesn't stall out at 5 psi. Currently the shop that installed it and STS are trying to figure out what's going on.
Sounds like the tune to me. What tune are you running?
Old 04-07-2014, 11:31 AM   #16
Fuco
Italian Stallion
Fuco's Avatar
Drives: Scion FR-S
Originally Posted by midnight23 View Post
Did you modify the fuel system?
Yes.
They've tuned it twice and it still happens. I'm thinking maybe the back pressure could be causing it.
"Insurrection is the most sacred of the rights and the most indispensible of duties."
Fuco is offline   Reply With Quote
Old 04-07-2014, 11:35 AM   #17
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Yes.
Who is they? STS? How many FA20s have they tuned? Are you using EcuTek? They probably don't have the MAF scaling correct or their intake design has put the MAF in a bad location.
Old 04-07-2014, 11:43 AM   #18
Fuco
Italian Stallion
Fuco's Avatar
Drives: Scion FR-S
Dyno is doing the tuning, but they are sending the data back to STS who is telling them what to do. It could possibly be the MAF and I'll bring that up when I take my car back in tomorrow. We've sent back pictures of everything, STS says that it is all installed correctly, and there isn't any sign of any leaks.
Old 04-07-2014, 12:20 PM   #19
Cross
It's the Mad Cow
Cross's Avatar
So yours is MAF based? Mine is MAP based now. I look forward to seeing your results and sharing mine should be a great comparison.
Old 04-22-2014, 06:42 PM   #20
SirBrass
Trust me, I'm the Doctor
SirBrass's Avatar
does this kit hook up to the stock front pipe, or is it a completely custom pipe running from the header outlet to the turbo?
^GT5 Replay Photo Mode^
Old 04-22-2014, 07:02 PM   #21
Cross
It's the Mad Cow
Cross's Avatar
Mine is from the Over Pipe back, could be different for the production STS kits though.
Old 04-22-2014, 07:13 PM   #22
SirBrass
SirBrass's Avatar
Which would suck for me if I got this, since I have a single piece fp/op.
Old 04-22-2014, 07:16 PM   #23
Cross
It's the Mad Cow
Cross's Avatar
Just cut the kit and have it start where you want to its not hard any exhaust shop can handle it
Sent from Spaceball 1
Old 04-22-2014, 07:18 PM   #24
swift996
swift996's Avatar
What is the estimated price?
Hmmm..I wonder if it could feed an innovate charger?
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
Old 04-22-2014, 07:20 PM   #25
Cross
It's the Mad Cow
Cross's Avatar
The innovate would build boost long before this kit would without the intercooler it's ok with the intercooler it's in the 3200 range.
Running a twin charger setup would spool the turbo faster and make it easier to run more boost.
Old 04-22-2014, 08:02 PM   #26
White64Goat
Good Grief............
You have this up front:
Now this in the back:
All you need is this in the car with a sunroof:
Old 04-22-2014, 08:10 PM   #27
Cross
It's the Mad Cow
Cross's Avatar
Strange mine sounds more like a turbo spooling and not a sewing machine....
The Following User Says Thank You to Cross For This Useful Post:
SirBrass (04-27-2014)
Old 04-27-2014, 08:07 PM   #28
SirBrass
SirBrass's Avatar
I have to wonder: why isn't a front mount ic included stock with the kit, but is an extra $1k on top?
Is this kit actually just fine without an FMIC in the desert heat near the super hot Asphalt?
On phone I am. Therefore, if mistakes I make, Frank Oz blame you should.
FBM Stage 1 Base Turbo Kit Starting @ $3995 Garrett or PTE Turbo Choices FullBlown Forced Induction 588 12-02-2015 02:41 PM
FRS Rear Turbo Roadstercycle Forced Induction 176 06-18-2015 06:13 PM
Free-Rear bumper cover (entire rear facia) replaced after slight rear-end collision n7011n Exterior Parts (Aero, Lighting, Etc.) 7 03-26-2014 04:46 AM
Turbo Tuesday 12/4/2012 (Dynamic Turbo Miami) F3dzo Southeast 46 12-06-2012 01:49 PM
