Old 04-07-2014, 12:28 AM   #1
huy_tx
Drives: scion fr-s asphalt metallic
how to control led with GND wire ?
Hi,
I bought this nice push button on/off switch on ebay and can control an LED with 12V+ fine with their suggested "ON light ON, OFF light OFF" diagram:
http://www.ebay.com/itm/New-16mm-12V...-/231195939188
However, i also have an LED that turned on with GND signal instead. The LED similar to the DOME light:
from battery ---> DCC --- My_GND_LED ------> GND_wire
If i connect that GND_wire to GND on card, the my_GND_LED will be on alright.
Any electrician could help me out to connect this button to my_GND_LED to "ON light ON, OFF light OFF" ?
Thank you in advance.
huy_tx is offline   Reply With Quote
Old 04-07-2014, 03:21 AM   #2
huy_tx
Originally Posted by huy_tx View Post
Hi,
Ha ! I figured it out . It works.
How to disable Traction Control (TC) and Vehicle Stability Control (VSC) Completely Sigh-on-Rice DIY (Do-It-Yourself) Guides 58 03-02-2015 01:48 PM
WTB: Front Lower Control Arm and Rear Upper Control Arm YDNA Brakes, Suspension, Chassis 0 11-10-2013 04:40 AM
best way to install 12v wire for amp?? derka-derka DIY (Do-It-Yourself) Guides 5 03-17-2013 12:57 PM
Reverse Wire Tap wire Location? Norkoastal Electronics | Audio | NAV | Infotainment 2 10-19-2012 10:22 AM
Disabling Traction Control (TC) and Vehicle Stability Control (VSC) Completely BabyGodzillaGTi-R BRZ First-Gen (2012+) — General Topics 40 04-25-2012 11:20 AM
