Old 04-05-2014, 03:52 PM   #1
OURO3OROS
Drives: 2013 Asphalt FR-S
Windjet Problem?
Should I be able to see the wires through the housing?
OURO3OROS is offline   Reply With Quote
Old 04-05-2014, 04:27 PM   #2
Mooseknuckle44
Mooseknuckle44's Avatar
I'm no expert, but l've NEVER seen the wires thru any headlight housing. OEM or aftermarket.
2013 FRS-Asphalt-M6-Invidia N1, K&N drop in, plasti dipped emblems, debadged FRS, Spyder II tails, 5000K Bi-xenon HID's, red demon eyes, Quad halo's, switchbacks w/Tapturn mod,Grimmspeed hood struts, led everything exterior, H&R 25mmF/15mmR spacers, Sportlines, SPC LCA's..(FUN car)
Mooseknuckle44 is offline   Reply With Quote
Old 04-05-2014, 04:28 PM   #3
OURO3OROS
I yanked them through the grommet, and it helped a bit, but they're visible up close. Heat issue down the road?
Old 04-05-2014, 06:14 PM   #4
beaver_scott
beaver_scott's Avatar
Drives: 2013 FRS hot lava
My winjets were the same as were some other winjets I have helped to install. When you remove the bulb access cap you can pull the wires back and out of the field of view.
beaver_scott is offline   Reply With Quote
Old 04-05-2014, 07:50 PM   #5
OURO3OROS
Windjet Problem?
Thanks. I forgot to hook the turn signals in, so I've got to take the bumper back off anyway
Anyone know if it's possible to do so without removing the bumper? I have the harness plugged into the turn signal, but now the other end.
Old 04-05-2014, 08:00 PM   #6
beaver_scott
Whoa, don't take the bumper off again. Just undo the clips in the wheel well and pull back the black plastic in the fender to access your turn signals. As far as the wires in the lights, just open the hood and look at the back of your winjets. Unscrew the big round bulb access cap that has wires going into it. You can stick your fingers in the light access hole to move the wires around and pull 'em closer to the access hatch and away from the projectors.
The Following User Says Thank You to beaver_scott For This Useful Post:
OURO3OROS (04-05-2014)
Old 04-05-2014, 09:44 PM   #7
OURO3OROS
I'll try that in the morning. Thanks
Old 04-06-2014, 09:31 AM   #8
OURO3OROS
Do I need to use the relay from the stock headlights and splice the turn signals into the green and white wires?
This is unrelated to the first issue, so I'm going to make a separate thread.
Old 04-06-2014, 10:02 AM   #9
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Drives: Whiteout Scion FR-S
how hard was headlight installation?
do u have to remove front bumper?
Old 04-06-2014, 11:31 AM   #10
MPI_Jack
Drives: '13 FRS, '02 BMW 530i(550HP, turbo)
Bumper has to be removed. There is a few DIY's in the DIY section. It can be done with basic hand tools and some friends with mechanical experience to help guide you through the process.
MPI_Jack is offline   Reply With Quote
Old 04-06-2014, 11:43 AM   #11
OURO3OROS
All you need is a 10mm socket, and Phillips screwdriver, and something to remove those plastic clips. The hardest part was removing the side markers.
Old 04-06-2014, 11:52 AM   #12
-Ozzy-
Drives: Raven FR-S - Chevy Cobalt Coupe
I am not experienced with working on cars. I installed my winjet headlights, and it was a piece of cake. Taking the bumper off was fun (just watch any video on it), popping out the side markers was a piece of cake! I even just replaced my side markers yesterday when my darksmoke and LED set came in. Took less than 3 minutes to do both.
To the OP: When you stand "above" my headlights or look over them, the wires are showing. I need to adjust my Winjets so that they aren't uneven and pointing at the ground today, so I will try to pull back the wires a bit. So I would say this is normal from Winjet, but you should be able to hide them yourself.
-Ozzy- is offline   Reply With Quote
Old 04-06-2014, 12:25 PM   #13
OURO3OROS
Do you remember a bumper removal video with footage of unplugging the turn signals? I'm looking for where those attach.
Old 04-06-2014, 02:27 PM   #14
-Ozzy-
You should be able to rotate the bulb's harness and pull it out of the Turn signal housing. The side markers work the same way. To install these headlights I actually just left the turn signal's plugged in, and let the front bumper sit right in front of the car. Getting the headlights in and out easily only requires the bumper be out of the way.
First problem with the STX Brz Simmons Tracking / Autocross / HPDE / Drifting 94 06-23-2014 12:05 AM
Problem with car Atticus808 Other Vehicles & General Automotive Discussions 1 02-19-2014 11:14 PM
E85 problem asher187 Engine, Exhaust, Transmission 4 08-27-2013 10:37 PM
A bit of a problem Gost Other Vehicles & General Automotive Discussions 13 02-12-2013 07:07 PM
ABS Problem chrislee2423 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 2 07-09-2012 04:06 PM
