Old 04-05-2014, 12:57 AM   #631
86SPEED
86SPEED's Avatar
Drives: The silvertrooper 10 series
Originally Posted by Fett4Real View Post
In theory you could wire them to a relay so when the car was on they were on...
Sent from my SCH-I545 using Tapatalk
you can always do this or even connect them direct to a ignition power - add a fuse and done - it will work and stay on every time the car is on -
But this is not the correct way to do it - IMO
We spent a lot of time to design and test what we offered to the market -
Our design does not change the way the factory DRL functions - so when the E brake is up the DRL bar turns off -
We quoted this out and asked someone to make these for us and the quote to manufacture these in bulk was up towards 75.00 our cost - it is not the parts that cost a ton - but they do cost for the right ones and quality ones - it takes about 30-45 minutes to build a set of these and solder it up the correct way -
Here is the link - and again anyone who got lights from us we can work with you and anyone who buys this we offer full support -
86SPEED is offline   Reply With Quote
Old 04-05-2014, 01:00 AM   #632
86SPEED
86SPEED's Avatar
Also our piece does not cut into any factory wires - this is pretty important to a lot of 86 owners -
We are not saying other ways are bad - we are offering a solution that we think is good and proper. As we are also a part of this community and trying to help
Feel free to ask us any questions
Old 04-05-2014, 02:12 AM   #633
clayrush
Drives: FRS,09 370z, 00 CelicaGT-S, 85 300Z
I feel bad for people who paid full price for winjets bought hid 's bought different projects and drl kit.
clayrush is offline   Reply With Quote
Old 04-05-2014, 09:19 AM   #634
tonystewart
tonystewart's Avatar
Drives: 2013 Scion FR-S Raven
Yes, they ended up with this, such a pity!
Wired correctly and visually stunning
Incredible cutoff, no glare, no hotspot, terrific cutoff
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
tonystewart is offline   Reply With Quote
The Following User Says Thank You to tonystewart For This Useful Post:
clayrush (04-05-2014)
Old 04-05-2014, 10:27 AM   #635
Brody602
Drift King
Brody602's Avatar
Drives: '13 Firestorm FR-S 6MT
Which projectors? Mini D2S?
'13 6MT Firestorm FR-S
Brody602 is offline   Reply With Quote
Old 04-05-2014, 10:31 AM   #636
tonystewart
Yes with Osram 66240 CBI's
Old 04-05-2014, 10:32 AM   #637
Brody602
Drift King
Brody602's Avatar
Yeah, I jumped the gun and bought xb 35 H7's for my winjets, I'll see how they perform but will most likely go the same route as you
Old 04-05-2014, 10:56 AM   #638
frskid
frskid's Avatar
Drives: 2013 Scion FR-S 6 MT Raven
Where do you guys get these done?
frskid is offline   Reply With Quote
Old 04-05-2014, 11:03 AM   #639
Brody602
Drift King
Brody602's Avatar
Question about Winjet Headlights
I'll be retrofitting myself, but Thomas at Illuminating Lightworx does awesome work and great customer service!
@Gixxersixxerman
Old 04-05-2014, 11:08 AM   #640
frskid
frskid's Avatar
@Gixxersixxerman
If you are doing it yourself do you actually have to take the winjets apart?
Old 04-05-2014, 11:10 AM   #641
Brody602
Drift King
Brody602's Avatar
Well for now I bought HID bulbs as I already have an HID kit with my stock headlights, but most likely will do a retrofit and change the projectors.
Yes to change the projectors to a better quality one you have to bake the headlights and split them apart to access the internals.
Old 04-05-2014, 11:12 AM   #642
frskid
frskid's Avatar
Lol I'll just stick with the HID kit for now it sounds like a lot of work
Old 04-05-2014, 11:14 AM   #643
Brody602
Drift King
Brody602's Avatar
Not too bad, but it's not my first time either. Mind you @Gixxersixxerman is a perfectionist and will make sure the new projectors are installed perfectly, I'm just going to bolt them in and call them a day!
The Following 2 Users Say Thank You to Brody602 For This Useful Post:
86SPEED (04-05-2014), frskid (04-05-2014)
Old 04-06-2014, 02:23 PM   #644
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Drives: Whiteout Scion FR-S
Winjets dont work witg fbm turbo kit
I love boost!!!!!!
Winjet Headlights and HIDs HakunaMiata Cosmetic Modification (Interior/Exterior/Lighting) 27 07-18-2017 10:24 PM
New Winjet Headlights LED FLICKER?! Jeremehh Cosmetic Modification (Interior/Exterior/Lighting) 4 03-08-2016 03:26 PM
Winjet headlights fogging up? Frs32907 Cosmetic Modification (Interior/Exterior/Lighting) 23 05-17-2014 01:26 PM
Has anyone modified the winjet headlights to keep led's on? 86black Cosmetic Modification (Interior/Exterior/Lighting) 0 01-24-2014 12:42 AM
Custom Purple Winjet and Black Winjet Headlights xclusive_brett Cosmetic Modification (Interior/Exterior/Lighting) 35 12-17-2013 08:28 AM
