Old 04-05-2014, 12:34 AM   #1
evan
Drives: fr-s
PSA: ACT vs EXEDY street clutches
I'm going to make this short..
Avoid the ACT street clutch unless you want a non-drivable car and a frown on your face.
Replace with the EXEDY street clutch if you want to smile again.
The end.
Edited: For those not familiar with my build.. I put in an ACT clutch last year after I went FI. ACT full disc street clutch. Everything got replaced. Flywheel, disc, plate, bearing, etc. From the beginning I begin experiencing issues getting the car into gear (1st) from a stop. The clutch itself was holding the power and I was able to shift in and out of gear once I got moving. When the trans was cold, the issue masked itself. Once I reached operating temp, it came back. I tried the clutch pedal adjustment, swapping over to a SS clutch line, swapping fluids, etc to no avail. Eventually, the problem kept getting worse and worse as time progressed. I never tried to force it in gear when it wouldn't go. Instead I would either pump the clutch or try going into another gear before attempting 1st again, which would usually work. As of last month, the problem got so bad that I couldn't actually drive the car with any confidence once it reached operating temp. People honking because I'm struggling trying to get it in gear, etc. I really thought the transmission was toast (specifically 1st gear synchro).
I made the decision to have PRE drop the trans and inspect the ACT assembly a few weeks ago. Here is what they found: nothing. It was in great condition. Nothing wrong with the PP, clutch disc, flywheel, bearing. It all looked fine. I had done quite a bit of research on ACT clutches at this point and found that there was a high incidence of issues with the PP. I also got tips from others on diff platforms with similar problems on their ACT clutches. At this point, I made a decision to try the EXEDY full disc street clutch (stage 1). It also came with everything net new. After putting it in and no other variables in the equation, I can safely say that the problems are gone! The EXEDY holds the power just as well as the ACT and it shifts like butter. I also went with the Pentosin MTF2 trans fluid that I was previously running.
The next step is for me to take this up with ACT and see how well their customer service ranks. I don't have high hopes. I've been fucked so many times by various vendors in the 86 community. The Portland regulars who know me have heard some of the stories.
My recommendation is to avoid ACT. It's not worth the potential issues. EXEDY is the OE manufacturer and they build a damn good clutch. I hope to upgrade to their twin disc in the near future.
evan is offline   Reply With Quote
The Following 7 Users Say Thank You to evan For This Useful Post:
Jmonty (04-05-2014), lbroskee (04-07-2014), m.box.design (04-05-2014), MrAmalto (04-27-2014), SirBrass (04-22-2014), wu_dot_com (04-21-2014), ZionsWrath (04-05-2014)
Old 04-05-2014, 12:55 AM   #2
Tromatic
Or don't be a non-driving fuck?
The Following User Says Thank You to Tromatic For This Useful Post:
Old 04-05-2014, 01:34 AM   #3
evan
Drives: fr-s
Are you serious man?
The Following User Says Thank You to evan For This Useful Post:
Old 04-05-2014, 02:41 AM   #4
Tromatic
Yes. My post was as informative as yours. Racecar?
Old 04-05-2014, 02:44 AM   #5
evan
Drives: fr-s
Look. I don't know who you are or what your problem is. This will be the last time I respond to you.
The Following 2 Users Say Thank You to evan For This Useful Post:
pmccut (04-06-2014), ZionsWrath (04-05-2014)
Old 04-05-2014, 03:03 AM   #6
Tromatic
OK by me, but what was your OP about? I thought the court said you could not talk about your spouse abuse.
Old 04-05-2014, 03:11 AM   #7
Chen
Regional Moderator
Chen's Avatar
Drives: 00-AP1 20-A90 06-Z33 07-FA5 93-NA1
What the heck just happened?
Chen is offline   Reply With Quote
The Following 10 Users Say Thank You to Chen For This Useful Post:
Churg (04-21-2014), evan (04-05-2014), FRSBRZGT86FAN (04-09-2014), jarednoel (07-01-2014), Luis_GT (05-05-2014), R2RO (11-18-2016), radroach (04-08-2014), raven1231 (04-27-2014), VesperLynn (04-14-2014), ZionsWrath (04-05-2014)
Old 04-05-2014, 03:12 AM   #8
ZionsWrath
Thanks
ZionsWrath's Avatar
The Following 6 Users Say Thank You to ZionsWrath For This Useful Post:
evan (04-05-2014), FRSBRZGT86FAN (04-09-2014), Hyper4mance2k (05-16-2015), Luis_GT (05-05-2014), radroach (04-08-2014), Sportsguy83 (04-08-2014)
Old 04-05-2014, 06:27 AM   #9
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
The Following 13 Users Say Thank You to Andrew025 For This Useful Post:
evan (04-05-2014), evolution_sfv (04-08-2014), finch1750 (04-22-2014), FRSBRZGT86FAN (04-09-2014), JB86'd (04-23-2014), Luis_GT (05-05-2014), protpibe (05-05-2014), radroach (04-08-2014), raven1231 (04-27-2014), Sportsguy83 (04-08-2014), VesperLynn (04-14-2014), wparsons (04-08-2014), ZionsWrath (04-05-2014)
Old 04-05-2014, 09:00 AM   #10
Superhatch
AIM4APX
Superhatch's Avatar
Drives: 2013 WRB BRZ Limited
It looks like someone left the bar cranky last night.
Evan, could you possibly make your post a little more informative?
"It's very difficult to present technology as an overtly positive sales device to people who want an emotional car" -Chris Harris
Superhatch is offline   Reply With Quote
The Following 4 Users Say Thank You to Superhatch For This Useful Post:
evan (04-05-2014), Luis_GT (05-05-2014), radroach (04-08-2014), ZionsWrath (04-05-2014)
Old 04-05-2014, 09:44 AM   #11
Jmonty
Realtor/ Principal Broker
Drives: JRSC BRZ GBS LTD 2010 LTD Outback
Wow,
Evan it seemed right to the point to me?
Jmonty is offline   Reply With Quote
The Following 2 Users Say Thank You to Jmonty For This Useful Post:
evan (04-05-2014), ZionsWrath (04-05-2014)
Old 04-05-2014, 09:54 AM   #12
z3ro
z3ro is offline   Reply With Quote
The Following 8 Users Say Thank You to z3ro For This Useful Post:
chadstyle (04-08-2014), evan (04-05-2014), finch1750 (04-22-2014), Luis_GT (05-05-2014), Sportsguy83 (04-08-2014), VesperLynn (04-14-2014), wparsons (04-08-2014), ZionsWrath (04-05-2014)
Old 04-05-2014, 10:04 AM   #13
ramiram1984
Drives: 2016 STi DGM
-2014 SSM BRZ MT
ramiram1984 is offline   Reply With Quote
The Following 4 Users Say Thank You to ramiram1984 For This Useful Post:
evan (04-05-2014), Luis_GT (05-05-2014), Sportsguy83 (04-08-2014), ZionsWrath (04-05-2014)
Old 04-05-2014, 11:05 AM   #14
deucethemoose
Functionally Retarded
deucethemoose's Avatar
Drives: LinkECU V6 MR2 - MKVII Golf R
Avoid the ACT street clutch if you want a non-drivable car and a frown on your face.
The end.
Avoid it if I want a non-drivable car...
Which means if I want a drivable car, I'll go with an ACT clutch. I feel like the message you were trying to convey was the opposite of what you said...
1991 MR2 - T-tops - Crimson Red - 1MZ-FE 3.0L - Other Stuff
I'm not really an asshole, but I play one on the internet.
deucethemoose is offline   Reply With Quote
The Following User Says Thank You to deucethemoose For This Useful Post:
Exedy Clutch KAR Engine, Exhaust, Transmission 28 01-03-2016 07:27 PM
exedy clutch questions ft86me Engine, Exhaust, Transmission 8 02-13-2014 09:58 PM
Lets talk about clutches charged86 Engine, Exhaust, Transmission 26 08-30-2013 04:13 PM
Clutches... Synack Engine, Exhaust, Transmission 19 12-16-2012 04:15 PM
Exedy BRZ specs sheet ayau BRZ Photos, Videos, Wallpapers, Gallery Forum 2 11-07-2012 09:56 PM
